I won't change anything without talking to you first. Seriously. Once this is up and running with the new cores, I will work with everyone possible to get this to where it needs to be. I want the best machine I can get when I present at the conference.
From my friend tonight:
"When I said I have tons of this *%^#% I literally have tons. Most of these sizes we are not even using anymore. Should you choose to go this route there is no reason to buy any *%^#% I have straight 10 ft. lengths of all sizes and no money in it. It will sit till it oxidizes and turn grey and the scrap man gets it. I have machines set up to cut it and bend it with stops made and measurements known, If you like the design. I will cut it, bend it and ship it to you at no charge. All you got to do is glue em together. I have developed a simple glue and assembly process that is repeatable and works. Now point #2. You are testing permalloy. If that works out, we know the sizes and combos that fit the holes. We could order permalloy together in 0.120 or what ever we decide on and I can calculate the amount needed, cut and bend it and we could use this design. The adjustment part works great and I do believe each core/ rotor clearance will have to be set individually. It is the only way to be accurate. I cut all my plastic disks for my core adjustments today. I cut up all 3 sizes of *%^#% for 10 cores in under an hour tonight."
