Thank you Alex. He was in a lot of pain overnight and went for surgery this morning. The surgeon was able to make a repair and so far he's OK.
The bistander thread
Originally posted by Quantum_well View Post
Originally posted by alexelectric View Post
His second sentence is false. He doesn't understand physics. You don't believe it, put a torque sensor between the motor (or prime mover) and the generator, run at no load on the generator, read the torque. It is not zero. Be smart. Don't believe anything Thane Heins has to say. Go to a reliable source for true information. Benchwork is nice, but it is easy to misinterpret results (be fooled) when you don't know what you're doing.
I shared the document, so that it will be studied and valued, by everyone, whether favorable or unfavorable, agree or disagree with Thane, their observations or conclusions.
That is, each one makes and exposes his conclusions, and evaluations.
We are all interested in studying and researching.
I read all the comments and positions, Research, conclusions, and I do not agree with everything, in others if I agree, and so on.
There is much to review, assess and experience.
Well, you read and you already gave your point of view and assessment, that's interesting.
So others will have the opportunity to express themselves, and we will learn something from everyone.
I check the point, and then I comment on it
With standard coil, it slows down to a few hundred RPM, still shows 270 watts into prime mover motor and 0.138 amps at 000.0 volts output per screenshot at 6:02 time marker. That right there is enough to tell you this guy doesn't know what he's doing and his experiment/demonstration is all screwed up.
I've said it before, don't believe anything you hear or see from Thane Heins.
Originally posted by Quantum_well View PostPatent application refused 2003.
However, Zahn later stated in an interview that "I can't understand how [Heins] can even breathe the words 'perpetual motion.' He plugs it into the wall." In a subsequent e-mail to Heins, Zahn wrote that: "Any talk of perpetual motion, over unity efficiency, etc. discredits you, now me, and your ideas." Zahn further stated that he would not endorse Heins' device until "the foolishness is stopped of hinting that your motor violates fundamental laws of physics."[12]
Conclusion
Heins appears earnest and basically honest, but persistently self-deluded. While some of the phenomena Heins demonstrates may be interesting, the evidence of a real and measurable effect appears to be lacking. Heins claims that the behaviour of his apparatus is contrary to what is predicted by known physics, yet he applies standard physics calculations to demonstrate his point. He sets up the motor to operate under extreme conditions, but applies analysis used for normal operation. He does not seem to understand the importance of demonstrating the response of the apparatus to an actual physical load, despite the fact that many people (including those who at one point were sympathetic to his project, but now have doubts) have recommended he do this, and even provided instructions. While the speed-up behaviour of the generator currently lacks an established explanation, there is no reason to think that it represents any challenge to currently known laws of physics.
"Heins appears ... persistently self-deluded"
First sentence in the conclusion hits the nail on its head squarely, 13 years ago.
http://www.ottawaskeptics.org/2008/0...hermodynamics/
Instead of funding Tesla got death threats and a lab burnt to the ground with millions spent on media smear shows. You really need to study with an open mind.Last edited by BroMikey; 04-13-2021, 01:36 AM.
Quantum,
I know far from everything. And once I am done testing coils I really am going to come here for help in trying to loop this machine before the conference to make a more impressive demo. I WILL need help doing that. But I CAN measure the watts going into my motor, and I can measure the watts going out to each coil. And I CAN add the watts produced by each coil together to get total output.
So telling me something cannot work that is sitting right in front of me with meters on it with NO lenz dragging the motor down and NO magnetic drag causing increased amp draw of the prime mover is all I need. The motor runs the machine at the required RPM with all the coils under load at no increased amp draw over what is required to basically turn the rotor with no coils in place. Each coil puts out what it should for the RPM the rotor is turning at with 22 magnets in place without affecting the prime mover.
Deriding my work or Thanes work to discredit what we know to be true is not going to change the truth. I don’t agree with everything Thane says, but I know that a properly wound coil CAN give you an advantage over Lenz at a specific frequency. As for everything else he claims, I haven’t proven it or disproven it on the bench so I keep my opinions to myself. But here is something you might want to think about. Lenz was taken to be a law and now we know it is a simple reaction that can be engineered around. What other “laws” can also be engineered around?
There are several EE’s on another forum right now working with these kinds of coils and coil shorting into a cap. Not something I have ever worked with, but the point is, all of them understand that avoiding Lenz is possible. The genie is out of the bottle and you can’t stuff it back in.
I am presenting my machine at the conference in public and if it does NOT work that will be quite the public embarrassment. My reputation. I don’t hide in the dark taking potshots at other people’s work. I put my name on my work and I stand behind it.
Yes bi, I can feel you getting all excited about the time I made a mistake about how many cells were inside a sealed battery and how they were arranged. But that mistake was a bit different than watching a generator on the bench in front of me being loaded down to produce output and seeing no change in the input to the prime mover. That’s measurable. I couldn’t measure the number of cells in a sealed battery or their connections from the outside.
The presentation at the conference will allow the truth to come out and the truth is all that matters. bi will do his best to discredit me until that happens and I’m fine with that. As I have said before, it’s mind over matter. I don’t mind and he doesn’t matter. until the conference I have no more to say about this. I have other walls to beat my head against and will divert my energy to the completion of THOSE projects. So you boys have fun.“Advances are made by answering questions. Discoveries are made by questioning answers.”
and
" I couldn’t measure the number of cells in a sealed battery or their connections from the outside."
That's not the way I recall it. In fact, your photo shows the "sealed battery" opened and connections visible. Your words indicated that you had further disassembled it. That thread is frozen so I snapped a screenshot of your post. Here it is:
Screenshot_20210413-231435.png Regarding your most recent post here, yes, by all means, let the truth be seen. And I'll help you loop it. Just ask.
Good luck.
And if you look at that picture the wrap is still all around the cells so you cannot see how they are connected, except that there are wires on top, nor can you see if there are more than six cells. So what's your point? That I was deliberately LYING to people about how the battery was put together? I have already said many times that I made a mistake yet you continue to bring it up every chance you get as evidence that I do not know what I am talking about. Does it make you feel like a big man? Does it make you proud? I really hope you are getting SOMETHING out of it. LOL“Advances are made by answering questions. Discoveries are made by questioning answers.”
