Anti-gravity
  • Originally posted by aljhoa View Post
    Since the Flat Earth is accelerating at 9.8m/s**2
    That's a begging the question fallacy that presupposes that the earth is a ball hurtling through the vacuum of space.
    You're can't prove that you're on a ball hurtling through the vacuum of space.
    Proof is not CGI pictures of space from NASA (Never A Straight Answer).
    That's just part of your religion of pseudoscience.
    Therefore, I go back to my original question.
    "Is there any evidence of gas pressure existing without the necessary antecedent of a container for the gas to press upon?"
    No. There isn't.
    There is no sky-vacuum.
    Case closed.
    VIDBID
      https://imgur.com/gallery/5YOi5WK
      https://i.imgur.com/5YOi5WK.gifv
      Since the Flat Earth is accelerating at 9.8m/s**2,
      VIDBID (or anyone), how far will it travel in four (4) years?
      https://www.theprinciplemovie.com/wp...arth-Mover.pdf
      Al
      [VIDEO]https://www.youtube.com/watch?v=bQSoRMrCRzk[/VIDEO]
      Code:
      "It is photoshopped, but it's, it's has to be." Robert Simmon AKA 'Mr. Blue Marble
      WHAT A LOAD OF BUNK
      VIDBID
      • [VIDEO]https://www.youtube.com/watch?v=erJCI_j_C5E[/VIDEO]
        Code:
        Do you believe in magic force fields?
        Affirming the consequent fallacy.
        https://www.logicallyfallacious.com/...the-Consequent
        VIDBID
          Skydivers poof it,
          they don't get hypoxia or die from it,
          but why they don't float in the sky?
          Al
            Skydivers poof it,
            Al
            What?
            What are you talking about?
            What do skydivers
            poof
            Your quote only proves that you don't know how to spell.
            Do you know the kind of logical fallacy that you're using?
            It's called a straw man fallacy.
            Originally posted by https://www.logicallyfallacious.com/tools/lp/Bo/LogicalFallacies/169/Strawman-Fallacy
            A straw man fallacy is substituting a person’s actual position or argument with a distorted, exaggerated, or misrepresented version of the position of the argument.
            I wasn't talking about skydivers.
            Originally posted by Skydiving Joke
            If at first you don't succeed...
            ...skydiving is not for you.
            So can you have gas pressure without the necessary antecedent of a container for the gas to press on?
            Of course, you can't.
            Do you know how a barometer works?
            What is a barometer?
            Originally posted by Google
            An instrument measuring atmospheric pressure, used especially in forecasting the weather and determining altitude.
            So, do you know how one works?
            In the above example, the barometer uses a sealed container that can either increase or decrease in volume, or remain the same, which is called an aneroid cell. The aneroid cell either expands or contracts, according to the atmospheric pressure.
            So, what is a citation for an aneroid cell?
            Originally posted by https://en.wikipedia.org/wiki/Barometer
            An aneroid barometer is an instrument used for measuring pressure as a method that does not involve liquid. Invented in 1844 by French scientist Lucien Vidi, the aneroid barometer uses a small, flexible metal box called an aneroid cell (capsule), which is made from an alloy of beryllium and copper.
            So, in order to measure air pressure, you must have a sealed, variable container known as an aneroid cell? Is that not so?
            Remember that in order to have gas pressure, you must have a container for the gas pressure to press on.
            Without a container, you can not have gas pressure.
            You can not have gas pressure next to a vacuum without having a barrier separating the gas pressure from the vacuum. Otherwise, the gas will fill the vacuum until gas pressure equilibrium was achieved.
            Boyle's Law.
            Second Law of Thermodynamics.
            Properties of gasses.
            Gases will fill the space available to them
            Gases have mass
            Gases are compressible
            Gases diffuse through each other very rapidly
            Gases exert pressure
            The pressure of a gas depends on its temperature
            Source: The Nature of Gases
            Gases will fill the space available to them inside a container.
            Also, in order to have a gas pressure gradient, you must first have gas pressure.
            You can't have a gas pressure gradient without first having the necessary antecedent of a container for the gas of the gas pressure gradient to press on.
            In order to have gas pressure, what are you required to have?
            You're required to have the necessary antecedent of a container for the gas to press on.
            Case closed.
            Do you know the real reason you're fighting acceptance of this idea?
            If you live in a container, then who put that container here?
            That's what you're trying to avoid.
            How are you going to deal with that Person?
            That Person is waiting for you.
            He's waiting for all of us.
            You better have something good to tell Him.
            You're going to have to give an account of your life to Him.
            Are you ready for that?
            Are you ready to meet Him?
            What are you going to say to Him?
            VIDBID
              Mercury Pressure Gauge
              Figure B: Pressure Decrease with Height Rapidly Above the Surface
              VIDBID
              At what "altitude" above and below the sea level shown above Hg pressure gage is useless?
              And why the air pressure is so high (1000mb) at sea level?
              Al
              • I never mentioned an Hg barometer.
                Your question is a straw man fallacy.
                Originally posted by https://en.wikipedia.org/wiki/Straw_man
                A straw man is a form of argument and an informal fallacy based on giving the impression of refuting an opponent's argument, while actually refuting an argument that was not presented by that opponent. One who engages in this fallacy is said to be "attacking a straw man.
                Who said it was "so high"?
                It's 1 Atmosphere.
                Is that high to you?
                Source: https://keisan.casio.com/exec/system/1224579725
                What is your point?
                VIDBID
                • No Fish Eye Lens
                  [VIDEO]https://www.youtube.com/watch?v=pvkGQVuNPsY[/VIDEO]
                  Code:
                  FLAT Earth High Altitude NO Fish Eye Lense - YouTube
                  No Fish Eye Lens
                  VIDBID
                  • Source:
                    Code:
                    https://youtu.be/a6ZYj-ve--8?t=68
                    VIDBID
                    • Code:
                      https://www.youtube.com/watch?v=ctRC3QpEBeA
                      According to the instruments, as shown above, at 110,013.04 FT, the barometric pressure is 0.20 inHG = 0.0982308 PSI = 0.00668421 ATM = 66.278 Pascal = 5.08 Torr. You still have gas pressure. To have a gas pressure gradient, you must have gas pressure.
                      Just some perspective, on the above values, because in ultra high vacuum, UHV, according to Wikipedia, ultra-high vacuum (UHV) is the vacuum regime characterised by pressures lower than about 10−7 pascal or 100 nanopascals (10−9 mbar, ~10−9 torr).*
                      5.08 Torr is how many magnitudes above 0.000,000,001 Torr?
                      5.08 Torr is 5,080,000,000 times larger than 0.000,000,001 Torr.
                      In other words, the atmosphere at 110,013.04 feet is five billion times more dense than the atmosphere in ultra high vacuum.
                      * https://en.wikipedia.org/wiki/Ultra-high_vacuum
                      I'm not saying there's a vacuum up there. That would be begging the question. What I am saying is you can't have gas pressure next to vacuum without a barrier separating the two.
                      Boyle's Law
                      https://en.wikipedia.org/wiki/Boyle%27s_law
                      The Second Law of Thermodynamics
                      https://en.wikipedia.org/wiki/Second...thermodynamics
                      In fact, the very definition of gas pressure requires a container.
                      VIDBID
                      • Spurs is a gas denier.
                        [VIDEO]https://www.youtube.com/watch?v=3lThMokXm_o[/VIDEO]
                        Code:
                        Flat Earth Debate 890 *LIVE* - YouTube
                        the presupposed sky-vacuum
                        VIDBID
                        • Pressure Measuring Systems
                          1 Standard Atmosphere (ATM) https://en.wikipedia.org/wiki/Atmosphere_(unit) is equal to
                          101325 Pascal (Pa) https://en.wikipedia.org/wiki/Pascal_(unit)
                          1.01325 Bar https://en.wikipedia.org/wiki/Bar_(unit)
                          14.6959 Pound-force per square inch (PSI) https://en.wikipedia.org/wiki/Pounds_per_square_inch
                          760 Torr https://en.wikipedia.org/wiki/Torr
                          1013.25 Millibar (mbar) (1mbar = 1 one-thousandth bar)
                          29.921331924 (inHg) https://en.wikipedia.org/wiki/Inch_of_mercury
                          https://www.unitconverters.net/pressure-converter.html
                          VIDBID
                            And there is no atmosphere under a dome.
                            Al
                              What?
                              What do you mean by
                              Who said that?
                              It was Gambeir.
                              Originally posted by Gambeir View Post
                              dome
                              That person apparently doesn't mind putting his words into other people's mouth, so in that case, it was a straw man.
                              In case you need reminding what a straw man fallacy is, here is a definition of what that is:
                              A straw man is a form of argument and an informal fallacy based on giving the impression of refuting an opponent's argument, while actually refuting an argument that was not presented by that opponent. One who engages in this fallacy is said to be "attacking a straw man."
                              However, after demolishing several fallacious arguments, if they can even be called arguments, more like feeble mutterings, we're left with nothing more than a red herring fallacy, which does what dead fish do⁠—stink.
                              Originally posted by https://www.logicalfallacies.info/relevance/red-herring/
                              The red herring is as much a debate tactic as it is a logical fallacy. It is a fallacy of distraction, and is committed when a listener attempts to divert an arguer from his argument by introducing another topic.
                              VIDBID
                              • Fata Morgana
                                Code:
                                https://www.metabunk.org/debunked-fata-morgana-hovering-boat-mirages.t9112/
                                Originally posted by https://en.wikipedia.org/wiki/Fata_Morgana_(mirage)
                                A Fata Morgana is a complex form of superior mirage that is seen in a narrow band right above the horizon.
                                VIDBID
