Anti-gravity
Originally posted by aljhoa View Post
Posting an image proves nothing.
Originally posted by GoogleA rainbow is a meteorological phenomenon that is caused by reflection, refraction and dispersion of light in water droplets resulting in a spectrum of light appearing in the sky. It takes the form of a multicoloured circular arc. Rainbows caused by sunlight always appear in the section of sky directly opposite the sun.Last edited by vidbid; 07-08-2019, 04:47 PM.Regards,
VIDBID
VIDBID
The Difference between Reason and Rationality
[VIDEO]https://www.youtube.com/watch?v=3tvQna1ZhzU[/VIDEO]
Code:https://www.youtube.com/watch?v=3tvQna1ZhzU
Examples of logical fallacies in action:
[VIDEO]https://www.youtube.com/watch?v=m2TIpz2lClg[/VIDEO]
Code:https://www.youtube.com/watch?v=m2TIpz2lClg
[VIDEO]https://www.youtube.com/watch?v=3AMjtsY9i_M[/VIDEO]
Code:https://www.youtube.com/watch?v=3AMjtsY9i_M
VIDBID
DV = Quran states that Earth is flat.
CV = Bible states that Earth is flat and under a dome.
On the Earth of the New Testament,
An Atmospheric Pressure Next To Vacuum Without A Barrier Separating The Two Does Exists because,
vacuum doesn't suck and the atmosphere interacts with the "Ball" due to aether.
Al
Originally posted by aljhoa View PostIV = the New Testament implies the Earth is round.
Ipse dixit is an assertion without proof; or a dogmatic expression of opinion. The fallacy of defending a proposition by baldly asserting that it is "just how it is" distorts the argument by opting out of it entirely: the claimant declares an issue to be intrinsic, and not changeable. (Wikipedia)
You just can't make up sh*t as you go, man!
Not only that, you're misusing the variables in the scientific method.
The scientific method uses an experiment.
The purpose of an experiment is to determine whether observations of the real world agree with or conflict with the predictions derived from a hypothesis. If they agree, confidence in the hypothesis increases; otherwise, it decreases. (Google)
It's not for evaluating scriptural references.
If you're going to make an argument on the basis of scriptural citations, then cite the appropriate chapter and verse, and then show the scriptures to support your claim.
For example:
Genesis 1:7 (KJV): And God made the firmament, and divided the waters which were under the firmament from the waters which were above the firmament: and it was so.
Genesis 1:8 (KJV): And God called the firmament Heaven. And the evening and the morning were the second day.
Job 38:8 (KJV): Or who shut up the sea with doors, when it brake forth, as if it had issued out of the womb?
Psalm 19:1 (KJV): To the chief Musician, A Psalm of David. The heavens declare the glory of God; and the firmament sheweth his handywork.
Psalm 148:4 (KJV): Praise him, ye heavens of heavens, and ye waters that be above the heavens.
Revelation 7:1 (KJV): And after these things I saw four angels standing on the four corners of the earth, holding the four winds of the earth, that the wind should not blow on the earth, nor on the sea, nor on any tree.
Ephesians 1:17-23 (KJV): That the God of our Lord Jesus Christ, the Father of glory, may give unto you the spirit of wisdom and revelation in the knowledge of him: The eyes of your understanding being enlightened; that ye may know what is the hope of his calling, and what the riches of the glory of his inheritance in the saints, And what is the exceeding greatness of his power to us-ward who believe, according to the working of his mighty power, Which he wrought in Christ, when he raised him from the dead, and set him at his own right hand in the heavenly places, Far above all principality, and power, and might, and dominion, and every name that is named, not only in this world, but also in that which is to come: And hath put all things under his feet, and gave him to be the head over all things to the church, Which is his body, the fulness of him that filleth all in all.
.Last edited by vidbid; 07-10-2019, 06:23 AM.Regards,
VIDBID
Originally posted by vidbid View PostYou just can't make up sh*t as you go, man!
VIDBID:
Are bellows, shown above, of a barograph measuring a "Dead-Weight Load"?
Is a "Dead-Weight Load" exerting a "uniformly distributed load" on the walls of the above bellows filled with a fluid?
Al
Originally posted by aljhoa View Post...filled with a fluid?
Definition (according to Google) : substance that has no fixed shape and yields easily to external pressure; a gas or (especially) a liquid.
I prefer not to use the term fluid to refer to a gas because it is generally thought by most people that a fluid is a liquid, and I'm not wishing to cause confusion.
Gas can flow like a fluid. Consider liquid nitrogen. It's either a liquid or a gas, as determined by temperature and pressure. The main point about a fluid is that it easily flows. You could say that a fluid is fluid.
VIDBID
Water Pressure Depends Only on Depth, Not Container Shape
[VIDEO]https://www.youtube.com/watch?v=02fqJOJFpEY[/VIDEO]
Water Pressure Depends Only on Depth, Not Container Shape - YouTube
Code:https://www.youtube.com/watch?v=02fqJOJFpEY
VIDBID
In most circumstances atmospheric pressure is closely approximated by
the hydrostatic pressure caused by the weight of air above the measurement point.
https://en.wikipedia.org/wiki/Atmospheric_pressure
https://en.wikipedia.org/wiki/Pressure#Fluid_pressure
https://en.wikipedia.org/wiki/Hydros...fluids_at_rest
VIDBID:
Al
Originally posted by aljhoa View PostAre bellows shown above of a measuring a dead weight load?
No!
Bellows perform a function. The function of the bellows is either to expand or contract according to relative barometric pressure.
Look inside a barograph. What do you see?
The bellows are a component within a barograph. The barograph records barometric pressure over the time of a week on a roll of paper with lines and numbers and days of the week written on it.
[VIDEO]https://www.youtube.com/watch?v=aC5ptqVmKX4[/VIDEO]
Code:https://www.youtube.com/watch?v=aC5ptqVmKX4
Do you see any liquid in it?
There is no liquid in the cell.
.Attached FilesRegards,
VIDBID
Note that sealed aneroid [from Ancient Greek ἀ- (a-) + νηρός (nērós, “wet, damp”)] bellows
contain a compressible fluid calibrated to react an “incompressible” fluid column of 29.92 in Hg or about 10 m H2O @ Standard Temperature and Pressure.
VIDBID:
Is vertical deflection of bellows, shown above, of a barograph "measuring" a "Dead-Weight Load"?
Is a "Dead-Weight Load" exerting a "uniformly distributed load" on the walls of the above sealed bellows filled with a fluid?
Al
Originally posted by aljhoa View PostIs vertical deflection of bellows "measuring" a "Dead-Weight Load"?
Give me a citation for it, and demonstrate it in action.
Originally posted by aljhoa View PostIs a "Dead-Weight Load" exerting a "uniformly distributed load" on the walls of the above sealed bellows filled with a fluid?
What's the point of your question?
Are you saying that the ambient barometric pressure is the load?
Doesn't the term load imply some sort of work being performed?
No work is being done, unless you say that a measuring device is performing work of some kind. Maybe the measurement is the work?
eh?
Isn't the cell just seeking equilibrium with external barometric pressure by either increasing or decreasing its volume relative to pressure?
Simply state your claim.
.Regards,
VIDBID
