Hi,
I am still that taken with Alex Manzanero's idea that I had to keep nibbling away. I'm also hoping that the rotor might answer some questions I have about induction. Here is a shot of the stater.
Here is a clean shot of the rotor.
Here is a shot of where things ended up today, when I ran out of spacers and patients (not necessarily in that order ). Hopefully that will be enough pics to get the general idea.
There is probably only two major mistakes I can think of when assembling everything, and I managed to make both of them.
The first is not replacing all steel threaded rod with stainless. If it doesn't cause massive shorts in the flux circuit, it will cause unnecessary cogging.
The second is not making sure both magnet stacks are facing the same way, ie all norths up or all norths down. Failure to do this will result in the two stacks coupling causing a massive short across the center of the rotor, with only the left overs making it to the outside where it is needed.
cheers.
cheers.
