Originally posted by Peter Lindemann
"Locomotives in the early 19th century were the first machines to use variable-switched-reluctance (VSR) motors. "They did not perform satisfactorily," said George Holling, president of Advanced Motion Controls (AMC) in Princeton, Wis., "and they soon faded into obscurity."
But with the advent of new and better switching controls they are making a come back:
"The Department of Defense has pursued VSR-motor applications aggressively. The motors are now used in such military applications as generators for turbine engines and pump motors for jet fighters. Military planners and researchers liked the technology mainly because of their high reliability...."
"A four-phase, 1/2-horsepower variable-switched-reluctance motor, used in applications such as electric motor scooters and industrial fans, can run at more than 90-percent efficiency"
"A barrier to the rapid commercialization of VSR motors has been that few engineers are trained to perform the exacting and specialized design the technology requires."
They said that SR motors are durable, reliable, and could be improved with time.
"With the appropriate switching and energization of the stator coils, the rotor can be encouraged to rotate at any desired speed and torque.... It can maintain higher torque and efficiency over broader speed ranges than is possible with other advanced variable-speed systems....The optimal waveforms needed to excite a VSR motor...are typically the result of a fixed voltage applied to the motor coils at predetermined rotor angles. Such waveforms can be achieved at virtually any speed....
There are other pros and cons but efficiency is not one of them. By recycling the counter emf what was a draw back in typical AC/DC motors can be used as an added benefit in SR motors.
"VSR motors are not without their drawbacks, however. The most significant downside is the acoustic noise and large vibrations often caused by the motor's high pulsating magnetic flux."
"Another limitation is torque ripple. It can be difficult to give VSR motors a smooth torque profile...If torque ripple is of primary concern, the best alternative might be a permanent magnet motor instead."
"VSR motors work with relatively small air gaps. If the shaft is off-center, unbalanced tangential forces come into play, so shafts and bearing systems generally need to be of a higher quality than with other motors. Various motor designers are working on designs to widen the air gap."
"The adoption and proliferation of VSR motors is about 15 years behind brushless motors," said Dan Jones, a Thousand Oaks, Calif., consultant to the motion-control industry. "However, it appears that they are experiencing the same acceleration curve as permanent magnet motor. Although they will never be ideally suited for all applications, they are emerging as a viable competitor to ac induction motors and permanent magnet motors."
Those were some main points from the article.
PS here is something interesting the writer described the rotor with teeth. Teeth could make for stronger torque.
"Basically, the motor is a rotor and stator with a coil winding in the stator. The rotor, which consists of a laminated permeable material with teeth, is a passive device with no coil winding or permanent magnets."
