Aircar technology:PNEUMATIC OPTIONS
  • #31
    Hi all
    We disassembled the lawnmover motor and took out all the parts that we don't need for running on air.
    Now we need to cnc a new cover for the piston so that it seals off those valves from the compression chamber. The cover will have two holes in it, one for ait input and the other for the air output. We are now working on a mechanical timing valve that will allow to comutate the air input and output at precise timing, but till then we want to run this baby using electronic valves:
    I know that electronic valves can not switch fast enough to achieve high speeds, but it will do for testing purposes. So here is what we will try:
    So when the piston is on its highest point, the electronic valve #1 will switch on and let the air in allowing the piston to move to its lowest point, then the electronic valve #1 will switch off and the valve #2 will switch on, allowing all the air to escape when the piston moves back up due to its inertia. This all will be commutated by two optotrigers and a cluminum commutator wheel. Wi will try 50:50 duty cycle. Here is the circuit I am intending to use:
    Of course this setup will not be very efficient, because the air will move the piston only 50% of the time and inertia will do the rest. But it will teach us the basics. Also after these tests I could make a hole in the bottom part of the engine and arrange the air flow so that the first 50% of the period tha air pressure moves the piston down and in the rest time I could make the air flow in the bottom hole pushing the piston up from the bottom. That would be more efficient.
    These electronic valves have a coil in them and that will make some BEMF trouble, so I probably will need to attach a neon bulb in the circuit or a secondary charging battery to protect the transistors
    What do you think?
    Jetijs
    • #32
      Hi Jetijs,
      Looks great as usual!
      I hope you're not biting off too much considering your other projects. Or at least you r brother is doing his fair amount of the work
      If you study the alternative electronics and your brother alternative pneumatics
      I think you will really have something!!
      Did you ever notice one of the Teal patents has an air compressor attached to his motor? I don't know why he chose air and not something more popular.
      I'd be interested to know if he used compressed air to benefit his motor in some way like air cooling.
      • #33
        Air car hybrid
        This is a very cool and conventional but clever motor design. It is a shame that Jay Leno (who spends tons on cars of all kinds) doesn't use his millions to help a little company like this make a prototype.
        YouTube - How the Scuderi Air Hybrid Engine works
        • #34
          Someone has informed me that the Scuderi motor in this video is a lot of hot air they keep raising money but they still don't have a prototype build. This person said it all sounds good but why not a real engine after raising money fo r so long?
          We all have to be careful of those who would use our enthusiasm for swindles.
          • #35
            French Air Car - CAT - Compressed Air Technology
            The French Air Car... CAT (compressed air technology)
            Air/gas hybrid... 600 miles on a small tank of gas.
            YouTube - A car that runs on air
            • #36
              If you change the cam lobes like in many of the youtube conversion videos do you also need an electronic valve?
              Just curious....
              Tj
              • #37
                thanks Aaron.
                Looks good but still skeptical
                I hope I'm wrong
                Well with all the car companies belly up it may be the right time
