I have a lot of faith in Matt's path. Earlier this evening a friend of mine invited me over to watch Energy From The Vacuum #14, which is must view documentary, and about 1:15 into it, Walter Rosenthal discusses the pitfalls of measuring "overunity" devices. It was a bit of a wake up call for me. He talks about the inherent energy savings by pulsing a DC circuit in the megahertz range compared to running lights (as a measure of output) on AC current. He explains how street lamps could be operated at 33% of their current draw, simply by pulsing and how, often, coil pulsed circuits are not overunity at all, rather they are energy saver circuits and the output measuring mechanisms are tainted by inaccurate consideration of what actually happens during pulsing/frequency change. He is an X-engineer / Rocket Scientist for Lockheed Martin, and has about 30,000 into test equipment. He was pretty closely connected to Floyd Sweet's work.
All in all, it's substantially easier to get "fooled" by circuitry, than by mechanical COP gains. If you've ever questioned the gains possible by gravity, I invite you to do this:
In state fairs they have this ride, it's amazing, I forget the name, but.. basically a small motor (and yes it's pretty darn small, I was shocked!) winds up an enormous bungee to the top of two arms, stretching it by use of mechanical gear advantage. once stretched, the thing hurls a huge steel cage full of people in the air about 140'. Once they peak, of course, they then fall... but they do about 5 bounces back up... the first being almost as high as their initial height, maybe 100 ft.
If you stand by the thing and watch it all, you seen realize, when two systems are disconnected creating a cause and effect - gravity power is unbelievably high in COP.
