  • Originally posted by CitizenDC View Post
    Hello again,
    Update:
    I've discovered a simple method to make the Imhotep-Bedini fan self-oscillate.
    By self oscillating, the fan output power is many times higher than before and far bigger spikes are shown via the Neon. The fan doesnt turn but instead makes a high pitch sound. Actually after coils start oscillating you can take the rotor off and it will continue working!
    How to:
    Firstly, grab a standard stock fan you've converted via Imhotep's design.
    The coil-to-coil resistance should be around 40 or 60ohm.
    Next you will need a 10k-15K resistor and one 1N419 diode (signal diode).
    Replace the components as described here.
    Once you have swapped out the components, start with a resistance of 10k omh.
    Next, disconnect your output so that the Neon light takes the output strain.
    Method 1:
    Swing your fan up, it will spin and make a high pitch noise then begin to slow down and bounce back and forth all the time until it comes to a stand still and still making a high pitch sound.
    Notice the glow on your Neon. Play with your resistance, increase it to find the resonating sweet spot.
    Method 2:
    Instead of swinging the fan, there is another method to get this to start which is best done once you have completed method 1 and fine tuned your circuit.
    In short, grab the negative (-) output lead of your circuit and and give it a a light wack with another metal object. I have crock clips on my ssg outputs so that I can make better impact contact.
    You will also notice just by touching certain parts of the circuit will also get it going into self resonance.
    Connecting the output:
    Once your coils are resonating and the Neon is brightly lit, the next step is to apply a load. What you will notice is that sometimes the coils will stop resonating when you touch both output leads onto a battery or multimeter.
    To get around this you can connect the positive output to a probe or bat terminal then strike the negative to get the circuit resonating again, then make a firm contact in one movement onto the other probe or terminal.
    kinda funny, but this is what works for me.
    Performance:
    You can increase the performance or resonance by adjusting the rotor/fan blades about 90 degrees from its resonating point by taping it down onto the fan case. This creates a 5-10% increase in voltage output.
    You will notice the blades will resist you moving them and the coils will make a more noise.
    Troubleshooting and Safety:
    The resonance or oscillation relies mostly on the resistance. If your is not working, adjust your resistance higher so that when you spin your fan that it doesnt have enough power to keep going, then it will slowly begin to settle and start humming at a high pitch.
    If found that the signal diode 1N914 to make this all work.
    Also, I dont get resonance when I have a load attached to the fan and I try start it. So always disconnect a load before to get this to work.
    Finally, take special care to monitor the coils temperature while you let it resonate, with the smaller stock 80mm fans I've run for about 24 hours now and the heat is no problem but I've not tested all fans.
    Once you've done this mod, you can use it as a driver to Imhotep's Radiant Oscillator instead of the auto-relay.
    cheers!
    Hi CitizenDC,
    You have discovered the self oscillating effect that can happen if the resistance is too high on the base. You should be able to trigger it simply by hooking it up and switching it on. I have a self oscillating trifilar with a full cap pulser on the back end that works really well. There is actually a better way to configure this, just using resistance, no diode needed (except for output). Check the radiant oscillator thread for Jets post. And you dont have to have a specific resistance on your coils for it to work, usually anything with over 300 turns you can get to do this.
    Have fun, if you want to build this thing from scratch then just wind a bifilar coil 450 turns and wire it up exactly as you have for the fan. Use an air core (i.e NO core) and your frequency will be alot faster.
    • Originally posted by ren View Post
      Hi CitizenDC,
      Hi Ren,
      Super. Thanks for the info and advice. I'll will give the no-diode approach a good test tonight.
      Also I have some 22" and 24" wire ready for wrapping a bifilar coil. All I need now is a spindle of the appropriate size to hold 450 turns.
      “If Edison had a needle to find in a haystack, he would proceed at once with the diligence of the bee to examine straw after straw until he found the object of his search.
      I was a sorry witness of such doings, knowing that a little theory and calculation would have saved him ninety per cent of his labor.” ~ Nicola Tesla
      • remember if you use the fan to drive the oscillator ,monitor the fan coils for heat buildup
        “Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
        Nikola Tesla
        http://www.imhotepslab.com
        • Conditioned Battery
          Ok. I testing with a new battery 12 Volts 4 ampH brand new. Reads 12.52 volts then I connected my Bedini SG, and discharged to 10.54 volts, all in 40 hours. is charging in this moment. must be charged in 40 hours?
          Battery condiotioned is fast charge?
          Steve Jobs. Apple CEO
          • Thanks for the link framednlv, I will give that a read.
            Imhotep, I wait impatiently for any information that you provide. The 3-phase scooter motors is actually one of the ones that I was looking at, however I am currently working on a smaller one right now. Roughly the size of the Reel-to-Reel motor that Aaron setup, except mine is 3-phase instead with 27 poles, 9 per phase. I will keep looking and trying and if I find anything, I will post it to share.
            • Originally posted by kniteowl View Post
              thank you for your data and input, all help is appreciated i will be tearing into the controller on the voy scooter soon! and redesigning.
              Nikola Tesla
              • Transistor test...
                Today I gathered some of my transistors to see how they faired in the same ssg circuit at the same voltage.
                D44VH10G 5300 -> 5400 RPM
                NTE 2338 6300 RPM
                MJL4281A 5900 RPM
                2n3055 6100 RPM
                This was an eye opener for me. the NTE2338 showed much more performance than my D44Vh10G ( the one I have several of ) and the 2n3055 was not too shabby either for as cheap as it is. I used my a battery as supply and my night light with a cap. The higher the RPM the brighter the night light glowed.
                FYI.
                See my experiments here...
                • Bedini FAN PNP transistor TIP32C
                  I had no NPN tranistor, so I tried with this setup with PNP....
                  Run but in videos like yours, seems like if my FAN with PNP is low speed.
                  Run minimun on 12 volts low speed ( neon no light, is this normal ?), on 24 better but make wind is poor.
                  does need this fans 36 volts? Or only works with NPN 2n3055?
                  • Testing transistors..
                    Sorry Patmac,
                    I am VERY VERY poor at building circuits, I can only work with what I have seen built, and I have no idea about the PNP verses the NPN transistors.
                    When I did my tests I ran at 12V. I found my larger fan not the cpu fan but the power suply fan would barely turn at 12V. I did my testing with a CPU fan.
                    • don't worry theremart....
                      This circuit is correctly electronically speaking, because my fan run, on 24 volts neon light, and I can hear the typical sound of Back EMF when charger batt is no present. But my problem is my first fan and I don't know what is his normal operation. How many power volts supply, draw curent and how speed can get.
                      If my Fan is good that means that need a 36 volts power supply to make it work efficientelly. By another hand, here left to everyone a little contribution to make a Fan with PNP transistor, because many people loose all theirs NPN .
                      I've other idea in my mind for these fans. I'll design the sch tonight
                      • My purpose Bedini Dual
                        theremart
                        The only difference between NPN and PNP is like the current flow, in NPN you need a potential Negative in Emiter in comparisson to Base and a potential negative in comparisson to collector, so potential is E < B < C. so IC=IE-IB.
                        In PNP you need a potential in Emiter positive in comparisson to Base and potential postive in comparisson to Collector so potential in PNP is E>B>C, in the same way IC=IE-IB.
                        Everyone
                        Using two Bedini circuits one with NPN and another with PNP, or well one Bedini with two Bifilar coils, we can make a potential 2X with this setup.
                        I'm hearing comments.
                        • Hi Patmac,
                          You may be interested in studying the half and full bipolar Bedini/Cole circuit. It uses a darlington configuration (NPNs) triggered by various means with a PNP to isolate the whole lot from the source. It is a very funky little circuit, even in its half form and can be used to drive the monopole too.
                          Mart notice the little arrows on the emitter of the PNP vs the NPN (on a circuit diagram that is ). This will give you a little more insight into its operation.
                          Simple page here Lecture three - NPN vs PNP
                          more here
                          Transistor Circuits
                          • I just can't seem to get mine working. I kept breaking the wires, so I decided to make a stator out of wire from one fan and the base of another. I think I wound it wrong. I think it's got continuity, but when I hand-spin the fan I don't get even the tiniest output. I sort of broke the posts, so I made a cardboard "H" to rest the wires on because the coil wires ended up a little too short for me to feel comfortable just letting them hang.
                            I'm a bad photographer. And the time always resets back to 2004.
                            http://img356.imageshack.us/img356/3918/1000701is2.jpg
                            Red is Red, Green is Yellow.
                            http://img253.imageshack.us/img253/1268/1000703rg6.jpg
                            http://img296.imageshack.us/img296/4291/1000704fj7.jpg
                            More bad photography, now of my neon bulb. Thing never seemed to light.
                            http://img296.imageshack.us/img296/2623/1000706da5.jpg
                            I think my potentiometer is too big. Not just physically. I Think it's 1 Megohm.
                            http://img253.imageshack.us/img253/1882/1000707oe5.jpg
                            I'm getting sick of breaking fans. I only have one more left I'm willing to work with. If I can't get the unmodified version working, I'm going to give up and move on. Preferably to something solid state. I hate moving parts.
                            • Originally posted by Dingus View Post
                              i understand your frustration with the tiny wires and assembly .try the last one and get hemostats and a magnifier and take your time any potentiometer will work but the the 2k pots work the best for most situations. to try the unmodified version, if you can get the rotor off you just take a scope and look for the spikes (pulses) off the circuit board posts where the wires go to, off the stator usually they are on the posts with one wire not the common one that has two wires. On the post with one wire, either one run a wire out and put a diode(1n4007) on it. Anode goes to the wire you ran out cathode goes to the charge battery positive and take the charge battery negative and run it to the positive of the source running the fan. It should self start on its own and you should get some charging ability off it. good luck.
                              if all else fails i have a super simple radiant oscillator i will be releasing in a couple of days watch for it on this thread and my website. Imhotep's Laboratory | Renewable Energy
                              Nikola Tesla
                              • ren
                                I'm good for darlingtons setups too, here in my country, find newest MOSFETS is some new, in past years ago my only way ever was H bridges with darlingtons to DC control motors.
                                And yes, this circuits is practically equivalent to Bedini/Cole patent. And it is near to be a h-bridge. I'm going to take a look circuit Bedini Cole.
