  • Now i am a bit confused about Trigger and Powercoil.
    I did usual name the one, what is at the base as the Trigger. Anyway.
    Black and Red is one Coil, and there dont go current through, when it dont runs.
    You need to measure between the Case from Transistor and your Minus from Batt.
    Thats Collector and Minus.
    There is current, at the moment, when the Transistor switch.
    If there is current without running, then its wrong connected.
    But, can you measure the Ohms from the Coils?
    And what Resistor & Pot do you use.
    I think, either your Resistor is to high, or your Ohms at the Bifilar is to low.
    Does the Coils swinging in a high frequency or low.
    The right Resistance at the Base do control the Strenght of the repell.
    And dont forget to put 5 Diodes in parallel for charge
    • Hi all,
      I'm using this fan quite successfully - HVACR > Fans > Axial Fans > Fan,Axial,107 CFM,12 V : Grainger Industrial Supply
      It is the best so far and it only has 2 coils which makes life easier. Tonight I've been playing with the setup and got something rather interesting. I've added a self-oscillating relay (Imhotep's idea) in line with the running battery. The bad thing is the fan cannot sustain rotation, i.e. dies in a few seconds tops. The puzzling outcome is that the neon bulb comes on VERY brightly even with the load attached! I don't have a scope right now to see what is actually happening but I've never seen neon coming on with the load...
      Thought it's worth sharing,
      ABC
      • No Oscilloscope
        The neon on the relay or the neon on the fan? I don't have an Oscilloscope either and it's like being blind eh. Sounds worthy of note though. I wonder what frequency the system is running at?
        • The neon that protects the transistor, between C and E. The relay is just in line with the running battery, self-oscillating. The system appears to be producing HUGE spikes and LOTS of them... Will try to check today.
          ABC
          • I'm not sure about a fan setup, but with a normal SG charger if the neons light up while the load is connected, it is usualy because the battery is damaged or heavily sulfated. However you have said that you are trying something different so it could be anything.
            (Not sure if I was much help. )
            Cheers,
            Steve
            You can view my vids here
            http://www.youtube.com/SJohnM81
            • 5Hz = hot, 2KHz = cold
              My recent observation on my circuit.
              After my transformer failed, I have problem of finding a coil that can be turned on for hours. Using car coil or self made coil will make the transistor very - very hot in a few minute. I already try lowering the duty cycle, but it still get hot.
              It turn out that the key is higher frequency and low duty cycle.
              See attachment.
              If VR set at 50K, the frequency is around 5Hz, the transistor will get hot in seconds.
              If VR set at 1K, the frequency is around 2000Hz, the transistor remain cool .
              The picture is my new transformer with 0.8 ohm resistance being switched. One wire neon bulb, top part slightly lighted up, is attached to 185 ohm part.
              Even when the power is strong enough to do one wire lighting, the transistor and transformer remain cool .
              • Hello,
                I have folowed the Imhotep videos since quite a long time.
                I come from France, but since I discovered your video Step by Step, I was like obssesed by the bedini circuit. I have distroyed a lot of fans (maybe 7) but researching more on the internet I finaly found the missing parts. ( translation for ecg125, neon bulb, and coil wrap,...) AND THE FAN RUNS!!
                But strangly I don't have the same results as you have!
                my Batterries d'oent load herself up?
                but why? I don't no everything is new so nothing is broken
                I realy don't know what to do please help me!!
                • hi jointbk
                  Imhotep not been around for some time, so I will try and help, can you get it to charge a little 9volt?
                  or put a cap on the backend and see if you get a charge, it may be the impedance, you are using big batterys.
                  Take Care
                  Bx
                  • :-) Thanks ?
                    All right so what can I do to make it work?
                    change the fan? change the batteries?
                    but imhotep used also a 12V 7Ah batterie.
                    my fan is a 12V 0,11A is it maybe not enough? Should I take a bigger one?
                    This makes me realy sad I thaught I had it, it was running but just like a normal fan. no overunity.
                    Well I will try it with a bigger fan and then I will see what will happen.
                    If you have any Idea what I could do just let me know
                    Thanks for your help and I hope Imhotep is all right?
                    • You have to remember that the device purposes is not for overunity. It is for charging battery. See if you have some voltage between the collector and source positive. Also, like you notice, if you have small current running, you will get small current for charging. To get real charging, you need decent current.
                      • [QUOTE=jointbk;50430]All right so what can I do to make it work?
                        I have been experimenting with the fan unit for some months now and I have found that they need to run much more slowly than regular Bedini machines. The fan units tend to start up quickly and overspeed which stops the high voltage output to charging battery completely. I have had to add another large upright blade to the fan to keep rotation speed down and current draw to about 60 ma. on the larger unit I am using to desulfate my tractor batteries. Best charging rate happens when fan is turning just above stall speed and you can actually hear the unit is almost in self osicillation. Under these conditions, the neon will flash brightly and distinctly and the voltage on the charge battery rises rapidly. Even a small amount faster rotation causes the neon to flash almost constantly and charge rate slows dramatically. Any faster rotation than that and the neon does not flash which indicates no high voltage spikes going to charge battery at all.
                        I have found that it is impossible to use a variable resistor to tune down the rotation speed of the large fans slow enough to get charging to work. You actually have to add a mechanical load in addition to fine tuning with the pot. I have also found that counter clockwise rotation makes my fan easier to control as it overspeeds much easier when running in a clockwise rotation.
                        Keep trying.
                        When you pick up a cat by the tail you learn things you cannot learn any other way...
                        • el-tigre
                          great advice the sweep spot is a bugger, I have a 24 volt fan funning on 12volts YouTube - Fan SG Bedini
                          this is a video i did from lidmotor but it may help jointbk
                          el-tigre where did you get the big fans from? and what do you use as the load?
                          and jointbk you need to condition the batterys with lots of charge discharge to get OU, when i say lots 20-30+. if el-tigre has a place to get the big fans we may do it together?
                          Take Care
                          Richard
                          http://www.energeticforum.com/renewa...attery-sg.html
                          also look at this thread it can open a hole new door of possiblitys.
                          • [QUOTE=Bodkins;50818] el-tigre where did you get the big fans from? and what do you use as the load?
                            I agree on the cycle rate numbers above. To desulfate my diesel tractor battery took 27, 12 hr charge/drain cycles. It holds a charge nicely now so the fan unit just saved me about $150 as I would have bought a new heavy duty battery. I am currently working on my commercial lawn mower battery now.
                            My fans are metal body, 145mm diameter 48v dc brushless 0.45amp NMB model 5920pl-07w-b40 made in USA by Minebea co. ltd. They weigh 735gms. Large enough to glue the electronics package to the housing for easy portable use.
                            I got them on an overstock sale. They are very robust with 4 large coils and excellent large ball bearings. The metal body makes it a little more difficult to modify them into Bedini rotors but can be done if you are handy with a dremel cutter or milling machine. These units run very cool and very reliably. The batteries I am charging/conditioning are standard automotive wet cell 12 volt 300-500CCA. The supply I use is a small wall transformer of 500ma @ 12 volts. They will run on 14v NiCd drill batteries or 12v lead acid with no trouble. These units run very reliably for weeks at a time only stopping to drain the charge battery.They start with a gentle fingertip push in either direction. They draw 50-80ma. while charging and can max out at 250ma if allowed to run ungoverned. They will turn reliably as low as 20ma. You do need extra resistance in the circuit to about 40,000 ohms. I use 2 pots in series one is 40k and one is 5k so I have a coarse and fine adjustment and this works well but you get much better speed control if you mount a physical load on the fan blade hub. In my case I used a stiff plastic sheet about 6" high, 1/16" thick and as wide as the blades which acts as a speed govenor, the faster the fan turns, the more air it has to push aside. Best charge rate happens at about 150rpm. They have enough torque, way more than a standard bedini rotor, that I am definately going to mount a small generator as a load instead of more fan blades on my next one. Are you motorheads salivating yet??
                            I have about half a dozen of these fans left, all are new, if anyone wants to buy one for $35 plus shipping. I will wire the coils up for you and test it for an extra $30 (you supply your own Bedini circuit). Just let me know. Digikey sells them in lots of 10 for $46 each plus shipping etc.
                            • Hi el-tigre
                              I would love to buy one but not at the moment.
                              Cash but please hold one or two for me give me a month I need to get a function genertor first and some other thing for a project im doing.
                              Man they do sound nice
                              I bet these a gail blowing in your house
                              Take Care
                              Talk to ya soon
                              Love and light
                              Richard
                              • Originally posted by jointbk View Post
                                YouTube - Bedini and Teal demonstration
                                check your fan connection i think its the wroung way around?
                                Imhotep it fine he has to work twice the hours for the same pay hes real busy dont worry
                                take care good luck
                                Richard
                                x
