Originally posted by Sephiroth
Originally posted by lost66 View Postthings r looking litbit better, the fan is turning. i have 2 short out the pot 2 get it 2 turn continuously. there is nothing coming from the neon though and it seams rather slow
one last update befor i go sleep. i have some luck nowthe fan is spinning up. it is running of a 12v battery and @ full speed, there was a volt drop (the battery was not fully charged and has a small charger on it) i then turned the pot a bit, the fan slowed down and the voltage started to go up from the charger. the voltage on the charge side from the fan also went up a bit (6volt battery) i dont want to tempt fate and try tune the pot a bit more (it got damaged when i disconnected the charging battery) dont know why? ...sleeeeep!!!!
Congrats.
Never run it without a load then :P
Adjusting the Pot all time is importend, as i did write you earlier too.
But you maybe need first a bit more feeling for it.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Light @ The End Of The Tunnel!
good morning all. i dont have a COP2 yet, but working on itlooks like i will b frying more "pots" than any thing else
(the pot that i am using now is even smaller, but almost transparent. even with load, i can c sparks in it when i try 2 adjust. and then it is buggered. will have 2 get a bigger 2k pot)
it seams such a wast 2 have a whole winding of that size, just 2 trigger (if i could tap off the extra power from it, it might b ok?)
i am thinking of joining the 2 windings on both sides and run them in parallel a1+b1 start and a2+b2 end?
or a1 start, join a2 & b1 and have b2 as the end (in series, around twice)?
or join both windings in series on each pole to make 1 winding per pole?
after i have done that then i must add a thinner trigger winding?
or glue a small pc fan on top and use that for triggering?
so many questions, hope i can get as many answers
Originally posted by lost66 View Postnother quick update. the fan is spinning up faster now but there is one thing that i c now. if i take the power off the charging battery, then it buggers up the pot. y would this b?
well done on getting it going
Originally posted by Bodkins View Postthink about where the energy is going if you take off the charging battery, into the pot and burning it out trying the neon bulb across E and The C should help.
i do have a neon on the transistor, but i dont c that it is helping 2 protect the pot? it is across the run/charge winding? and not on the trigger winding? i might b looking @ it wrong!
Originally posted by Joithi joit, i have some luck nowthe fan is spinning up now. it is running of a 12v battery and @ full speed, there was a volt drop (the battery was not fully charged and has a small charger on it) i then turned the pot a bit, the fan slowed down and the voltage started to go up from the charger. the voltage on the charge side also went up a bit (6volt battery) i dont want to tempt fate and try tune the pot a bit more (it got damaged when i disconnected the charging battery) dont know why? thanx for your help so far
When i make it smaller, with thin wires and lesser winding, it still gets enough current,
to trigger the Transistor, but it dont burn the Pot so easy.
There is a certain Point at the Pot, where it seems its a critical Point.
But i dont know exactly, if the Magnetfield, what is build at the Triggercoil interacts with the Rest or its just for triggering...
i have posted so many times after each other on this page, i hope i am not confusing the subject! Lol. all the questions still stand! (i have not realy made progress) :-( i have now run out of pots so i thought i will put in a 12v brake light bulb, and there is enough power where the pot is supposed to be, to light it up. but sadly there is no real power charging the battery (maybe i should have had the bulb in paralal with the pot or something. i might still have had a pot to play with) i still think i should winde another trigger and use this winding i some other configuratinon (what if, i double up on the circuit, usind 2 windings with 2 curcuits in paralal and 1 or 2 new trigger windings to drive it?
Brake bulb is overkill but small 12V 25 - 60mA grain of wheat bulb between the coil and pot (in series) will do. Cold filament of the bulb has very low resistance but when enough current will flow through and lit the bulb, resistance will increase, thus reduce the current going through the pot and into the base of 3055. You can also try to put relay coil (12V) in the same spot - in series with pot.
Vtech'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
General D.Eisenhower
http://www.nvtronics.org
Originally posted by blackchisel97 View PostBrake bulb is overkill but small 12V 25 - 60mA grain of wheat bulb between the coil and pot (in series) will do. Cold filament of the bulb has very low resistance but when enough current will flow through and lit the bulb, resistance will increase, thus reduce the current going through the pot and into the base of 3055. You can also try to put relay coil (12V) in the same spot - in series with pot.
Vtechwill i use it as is, or can i take out the coil (mmm maybe i can use the contacts to do something if and when they pull in?
wander what) should i use a bigger or smaller relay? (i dont care wt people say, size does count.
) or will the 'grain of wheat bulb' be better?
that said, i still wnt 2 explore using this winding 4 a better 'COP' have a look further up and let me know wt u think of the options or if u have better ones
thanx 4 the reply, i will do it in the meantime
Originally posted by lost66 View Postrelays, i have plentywill i use it as is, or can i take out the coil (mmm maybe i can use the contacts to do something if and when they pull in?
Just use the coil terminals, forget about the function of relay. All you need is an extra inductance in series with pot. Small bulb may work better since you'll see getting brighter or dimmer. At the same time you'll notice fan speed changing. Highest base current and brightest bulb doesn't mean better charging. It only means more current.
just want to highlight the last couple of points/questions
i still think i should wind another trigger and use this winding in some other configuration
-it seams such a wast 2 have a whole winding of that size, just 2 trigger (if i could tap off the extra power from it, it might b ok?)
-i am thinking of joining the 2 windings on both sides and run them in parallel a1+b1 start and a2+b2 end?
-or a1 start, join a2 & b1 and have b2 as the end (then it will be in series, and go around the rotor twice)?
-or join both windings in series on each pole to make 1 winding per pole (a bit more work, but can be done)?
-or double up on the circuit, using the 2 windings with 2 circuits in parallel?
after i have done one of the above, then i must add a thinner trigger winding?
