  • Originally posted by hatman View Post
    Hi,
    I am new to this and just trying to understand and learn as possible so I apologize if my question seems silly. After reading a whole lot on this and watching the suggested videos it remains a mystery to me on how exactly is this free energy. It appears that you need a power supply to run the fan, which then charges the dead battery. Is this an over-unity device? If I need a battery to charge another battery - why would I do that? How many batteries can I charge with one battery?
    If anyone can explain or give examples of the input and output voltage, polarity, wattage, etc. that would be great.
    Thanks!
    From conventional perspective charging efficiency is 3%, with bonus of running a fan althought slower than usual.
    For "free enery at last" explanation, I leave it to other to explain...
    • free energy at last, my a%5e!
      I have read most of this thread, watched the video's AND built the bloody thing.
      Waste of time it is.
      Anyone who wants to SHOW ME the free energy, is welcome to.
      If you convince me then I'll write a retraction.
      Until then, I'd have to recomend that the seeker after truth move on, there's nothing to see here.
      I'd love to be able to apologise for this posting, but for now, it's the truth as told by someone who has spent time and a little money looking ito it.
      I will not be back, (don't want to waste any more time on this) but you can mail me at my username dot hotmail.
      Cheers, Steve C.
      Last edited by swallabat; 07-02-2010, 10:03 AM. Reason: Untidy posting, should have previewed it. Wasn't to my usual standard.
      • One typical mistake a noob does ( i have been also!) in sites like this is that he is biased by his want-to-believe, belief and reads all free-energy related posts and considers it has been done repeatedly by senior members etc, while treats all opposing posts as "Nay-sayers", negative aura people, MIB, etc
        I have said it before, i will say it again and i will say it in every occassion. Free energy beyond doubt has never been produced.
        From the moment that will be produced and a third trustworthy party replication occurs with full specs (results posted on the internet) will be made, this technology will spread like wildfire by Internet power.
        Unfortunetely this is not the case in any way. You have been led here because you do not believe current official physics dogma.
        Do not allow then, to believe anyone who formualtes theories and spell out words without tangible proof.
        • Not important: Can someone put beter, cleaner scheme, than show in step by step video, part 2?
          My motor fan have tree pin.
          1 pin is start, 2 pin end, 3 pin start and end. For 4 pin need end or start?
          Imortant very quastion: Need remove the sheme (plate green with transistors diodes, rezistors), not use it, after making 4 pin and put back stator and rotor to fan?
          • I make it. I not try chare, but from 6 V transformer working. Diodes I use other. Plate not need. Now it sensorlees motor.
            Peace and love!
            Maybe can say or put scheme, how make, that he run itself, without battery, with capacitor?
            • Originally posted by SunofFather View Post
              Peace and love!
              Not possible yet.
              • I not use neon, did I make big mistake and that use other diodes?
                • For the diodes it is only importend to got them in range ie 100v
                  and you may pick faster Diodes that they cut off faster.
                  But i dont have prefered one, i got a bunch of By255,
                  which are some bigger and fast one.
                  • Originally posted by Joit View Post
                    How I can known: my diodes fast or no?
                    • Datasheet catalog for integrated circuits, diodes, triacs, and other semiconductors, view
                      • I draw scheme for self runing fan. I do not known how need wind coils, dont known how much windings need on each coil and not garanty that it work.
                        • I use in other motor big diameter wire and ohm is about 0,3 not 30-60 like in not rewinded fan, with 2N 3055 tranzistor not work, what when need use tranzistor?
                          • The Problem with to low Resistance at the Trigger Coil (right Side from your Picture) is,
                            most Potentiometer dont goes down to zero.
                            Then you have to a bit Resistance at your Trigger Coil, and you get no current at the Base, to trigger the Transistor.
                            The 3055 usual should work, it can handle 7A at the Base and about 20A to switch.
                            What you can try is, to wind the Trigger coil with thin wires, and leave the thick Pair at the other Side,
                            that you get more Resistance at the Base Side.
                            As much Resistance at the Coil, as much you can adjust at the Pot.
                            Like the Coil is 10Ohm, the Potentiometer can be set to ~20-60 Ohm.
                            Some do suggest to put a 10Ohm Resistor fix between Base and Potentiometer,
                            in case you turn the Pot to Zero, that the Base from the Transistor is still protected.
                            Furthermore, i would first connect a Powersource like a Batterie to your cap, to charge it,
                            and see if your Fan turns.
                            When it does, adjust it to highest Rpm and low Amp draw, when you can measure that.
                            Then you can diconnnect the Source, and see, if it still runs,
                            after your Schematics what you do try there.
                            You can turn the Pot some lower, because lower Volt input need readjustment from the Pot.
                            But i doubt, that i will works this way, as you try it,
                            because the generated Current at the Coils will be to less, to keep the Rotor at turning.
                            Even because poled Caps do make a short between + and - when they are uncharged,
                            and you will have the first losses there.
                            • That parameter of diode in datasheet (or maybe in diode) show how much fast is diode?
                              • It does usual show at the Features at the left Side.
                                There is a list.
                                http://www.datasheetcatalog.org/data...50/50075_1.pdf (scroll down)
                                and you can see it here
                                http://www.datasheetcatalog.org/data...mcc/1N4947.pdf.
                                I did do a search for schootky and fast switching Diodes.
                                Schottky Diodes are usual all fast switching.
