  • Trying Jolt's suggestion[thanks hope it works]
    Don Smith Free Energy - Video
    Nope Don't know why, but when I paste in the address this worthless link shows up
    see post 595 please
    Thanks Chet
    BE that change !!
    • Same consept as above
      Stephan
      Quote
      A new video by MrFreeEnergy claiming
      100 KWatts output running 2 big motors and a
      electric heater via big Tesla coils:
      YouTube - FREE ENERGY GENERATOR BY KAPANADZE 100 KW - PART -1
      Amazing !
      * Reply with quoteQuote
      Looks like input is 240 Volts x 2 amps per
      phase and output looks like 240 Volts x 10 amps per phase, 3 phases total.
      For each phase there is a Teslatranformer with a special Kapanadze transformer
      amplifying the power.
      BE that change !!
      • I was wondering, when you remove the printed circuit what about the commutator. How is the current reversed? Thanks Laurent
        • help
          I tried to use the bedini imhotep fan and it charges a 5 year old 12V 4AH battery and a 6V 4AH battery but they seems to charge up to 12.30+ volts and when i use it it dies very quickly
          My bedini is connected to a DC Voltage regulator 3A and 12Volts.
          I also tried to charge a 45Ah Car Battery and a 50Ah battery both of them are defective which i bought it at a Auto Supply Shop and tried to charge them for 2 days non stop but still does not charge well
          How do you know its fully charged? im using a voltmeter to check
          I tried to run the bedini fan at 24V but the 2N3055 gets very hot and after a while it does not work anymor, but when running it at 24V it charges very fast.
          Should i connect the 2n3055 transistor a heatsink and try to run it at 24 volts?
          Maybe i should buy the Radiant Charger instead?
          • rotor
            If I put in the power the rotor moves a bit and then you feel that the magnet hangs but does not do anithing what am I doing wrong can someone might help me thenkx
            • mindmaster switch the ends of one coil, then it should work. At Plus and Collector ie.
              For charging a 4 Amps battery you maybe wanna use thicker wires as #30
              • sorry im a bit of a noob what do you main with swith one end of the coil.
                thenkx
                • You have actually 2 Coils at your System, each Coil has a Start and a End wire.
                  One Coil is connected to the Collector of the Transistor and the Plus.
                  The second Coil is Connected to Minus and Emitter, with the other End from this 2nd Coil to the Potentiometer and the Base of the Transistor.
                  Swap the Wires from one of this both Coils. Its all described a bit earlier in this Thread too.
                  The Problem is, that one Coil dont get the Signal right.
                  The Transitor opens, when it dont repells the Rotor.
                  • Originally posted by Joit View Post
                    just change the Coils Oo i hade this Problems 3 Times and buy 3 New Motors xD okay i think i the next Holidays i try my best second Time to build "free Energy" ^^
                    • Well, i guess, its not 'Free Energie' right now,
                      and that is, what other say, that J.B did never claim it, that the SG(Schoolgirlmotor) is.
                      What i know, the Ratio should be 1:1,7 what you can charge, its not much, but i did not do a compare with 2 same Batteries, where i really can confirm it.
                      And other Thing, this small Fans dont have thick Wires inside,
                      dont assume, they spit much Power out, but they are nice, to make high Voltage.
                      There are plenty of Variations of it, and i prefer anyway more, to make my own Coils.
                      And this is good, for charging up any batteries, and get more Capacity in them, what much dont see.
                      Even that is a good Reason for need to have one.
                      • [IMG]My Computer\Nokia N97\Mass memory\Images\Camera\200910\200910A0[/IMG]
                        • man has tryed and failed, but never failed to try!
                          hi i found this 2 b very interesting, and have attempted 2 get it going. but with no luck. wt did i do wrong!?
                          • @Joit, If you think what is coming from your thin wires is power then you will never understand the concept. It is the rise and fall sharpness of the high voltage/low current that resonates your charging battery in the vacuum which makes it charge itself. The key to getting this stuff to work is understanding what is happening at a much lower lever in the system. I would recommend Bedini/Bearden's "Free Energy Generation" book, it explains it very well.
                            • Look at post 155
                              Originally posted by lost66 View Post
                              [ATTACH]3994[/ATTACH]
                              http://www.energeticforum.com/renewa...ust-see-6.html Post 155 If that is the circuit you're trying to build.
                              Vtech
                              General D.Eisenhower
                              http://www.nvtronics.org
                              • Originally posted by Zooty View Post
                                Lol Zooty, thanks for remind me on that.
                                But what i did wrote above is a practical Experience,
                                not a Story from a Book, or something, what i did dream about once.
                                Hows about, YOU show us, how you charge a 7,5Ah Batterie in 12 Hours
                                with a Fan from a computer, what has only #35 Wire inside.
                                And further, explain, what you do think, how it gets charged,
                                and please, without pointing at a Book, what you did read once.
                                And btw, your Answer is still not correct too, actually, Way beside the Track.
                                Sometimes, it sounds like, for some is the Word Energy from the Vacuum like a Drug,
                                that some allways need to use for all Explantations.
                                And well, you maybe wanna explain that too, what you do understand
                                at the Term Energy from the Vacuum.
                                -Edit-
                                And at last, explain me, where or why do you think, YOU know, what i think.
