I have been looking at various methods of tuning the SSG.
1. 1 ohm test ( from yahoo monopole groups )
2. Am radio ( listen to the pulses ) found on youtube, and older group.
3. Led test, tune for the number of pulses.
4. Voltage tune, tune by the "sweet spot" when seen on the amp meter ( the valleys )
5. One that I have found from a guy in India, simply put the voltage meter over the diode going to the charging battery and measure the voltage ( it will be higher than the charging batter normally ) and simply go for the highest voltage.
6. Amp tuning measure the amps going to the target charging battery and the amps from source and adjust based on this info.
Now things even get more interesting as you ad more coils. It is like directing and orchestra even one instrument out of tune can stop the music and just make noise.
I am thinking of putting on off switches on each of my transistors and then turning them on one by one. The question in my mind is, which of the above methods is best to tune a multi coil, or is there even another method?
Any other thoughts on this?
![Thinking Smiley](http://www.energeticforum.com/core/images/smilies/thinking.gif)
