Ok, I have been busy today and the motor is finally finished
here's the startor ready for coil winding:
The coil winding process was the hardest part, because I did this with hands. The startor is heavy and with each turn of wire it became even heavier. I wound three strands of gauge 21 wire. There are about 250 turns ( I lost the count in the winding process which took me about 2 hours). Each strand has a resistance of 1.7 Ohms.
Now as for the reedswich. At first I tried to mount the reedswitch to the plexiglass holder horizontally, but that did not work well, the duty cycle was bad, about 70% on time and 30% off time at best.
Then I mounted the reedswitch to the holder vertically. This was a lot better, now I could easily adjust the timing as needed.
I had to make a second plywood base plate so I have a place to mount the reedswitch. Heres how it looks like:
And now pictures of the whole thing:
I have not adjusted the timings now, I just tested if the adjustment works. Now I need to solder the circuit. Peter I think you missed my previous question:
Jetijs
In the mean time can you answer a question? So If I wind my startor coil from several parallel strands of wire, what is the difference between pulsing each of the strand with its own transistor and pulsing them all together with only one transistor, provided that the transistor can handle enough current? When I experimented with SSG circuits, I noticed, that I can get more RPM with two power coils if I pulse them with two transistors, each transistor for each coil. But when I used only one transistor and pulsed the both coils in parallel, I got only a little increase of RPM. Why is this so?
Jetijs
