Peter,
I made some tests with the 555 timer pulsing the LED. The results are not too good. Here they are:
I used a 1 KOhms for the first resistor and 85K for the second one on the 555 circuit, the greated difference between these values, the closer we get to 50:50 ratio of ON and OFF time. I changed the frequency of the pulses by adding or removing some 1,5nF capacitors on that timer. The more capacitors in parallel, the longer the pulses. The resistor between the output of the 555 timer and the IR diode is 470 Ohms. The comutator wheel has four gaps, 25 degree of an arc each. In the chart you can see, that by reducing the pulse width, I get more spikes per 25 degree window and also getmore back on the output. But I can't get more than 24% back. Also the more spikes, the slower speed.
Here are some scope shots:
Notice how they get shorter in height when there are more spikes per 25 degree window. That means that I can get the pulses even shorter than the rise time, but nevertheless I can not get more than 24% back. Also the higher the frequency of the spikes, the higher pitch noise the motor gives out.
Any suggestions which way to dig next?
