Electric Motor Secrets
  • I Agree
    Originally posted by lighty View Post
    @Jetijs
    Is it possible for you to measure possible bending of shaft? It could be that your shaft is imperfect or that you assembled rotor (or stator for that matter) a bit "off" of certain points along the length of motor.
    How thick is your shaft and what material did you use? I doubt that your motor can produce so powerful magnetic pull to bend the shaft if you use any standard quality steel with appropriate shaft diameter.
    Also, are you sure that your bearing case don't introduce any lateral movement? Maybe the bearing casing is too lose or have too much tolerance?
    You really ought to check out everything before widening air gap because once you do it there is no going back.
    Jetijs,
    I totally agree with Lighty here. Take your time and check each gap from both ends. It may be that one bearing holder is slightly better aligned than the other. You are at the point where engineering and "massage" overlap! Lighty is right. Only take non-reversible actions as a last resort.
    Peter
    Peter Lindemann, D.Sc.
    • just another theory
      Jetijs,
      I know this looks like it could never happen, but have you considered this?
      the magnet force is in my opinion unlikely to offset the rotor itself, because it pulls in both directions. But the force of the magnet might be bending the armature ever so slightly. Steel is very flexible, and due to the tolerances worked with this could be the cause.
      I'm no expert but just another idea i'd like to toss in. We all want you to succeed
      • Steel cannot be compressed in the way you suggest without serious bending of material. And I suspect that if Jetijs glued plates together and bolted them properly the stator can't be bent the way you suggest.
        http://www.nequaquamvacuum.com/en/en...n/alt-sci.html
        http://www.neqvac.com
        • Peter, lighty,
          of course I tested the bearing holders before I increased the air gap. I could not feel any movement in them, the they are holding the bearing rock solid. Also I am now convinced that the shaft is not bending. The shaft is made of non magnetic stainless steel and is 10mm in diameter in the thinnest point (the shaft ends are thinner, but that does not affect anything). So I gave the rotor to engineers to increase the airgap. They took off a whole of 0.1mm form the diameter. That is 0.05mm on each side. This gives an air gap of 0.13mm on each side. But now I don't have any surface touching problems anymore. Unfortunately something in my transistor board has fried, today I tried to run the motor but nothing happens. I checked the optoswitches - they are ok, something else is wrong. The motor gives no sign of life. I can increase the input voltage up to the max, but there are no amps flowing. I double checked everything, but found nothing. I will have to make a new circuit board just like before with my first motor But I made a test without commutation and it seems pretty nice. Here is a small video:
          YouTube - Lindemann attraction motor V2.0
          You can see that the motor has a great potential and with a mechanical commutation the motor would just fly away. That bump sound on the beginning of each impulse is because I can not make the power pulse short enough, so that the rotor can not get past the fire zone and is pulled back. Only once in the video you can see a pulse without that bump. I also thought about the transistors. In order to get the max performance, I need them to open fully, because when they are not fully opened, there is a big voltage drop across them and much energy is wasted into heat. If the transistors would open fully, there would be much less heat. I will take this into account when soldering my new circuit board.
          Happy easter BTW
          Thank you,
          Jetijs
            Peter, lighty,
            Of course they're holding bearings rock solid but maybe they're slightly misaligned? Ah well, you already increased airgap so what's done is done. BTW- have a little patience those parts I've sent you entered Latvia on 18.03. so you should get them any day now- then you can use updated electronics as well.
            • Hi all,
              I as you know, my transistor circuit fried, so I decided to give the MOSFETs a try since I already received all the parts needed from lighty
              Lighty was so kind and guided me through the MOSFET circuit basics. So far I only tried this circuit on one phase and it works really well, the MOSFET does not heat as much as transistors did and the motor runs much faster at one phase than it did with the transistor circuit using two phases. The torque is very great, at least in the firing position, you can not hold the shaft with your hands in the fire position. I will get some soldering plates and solder all this together and then I will post my results. Here is the circuit I will be using:
              I would like to thank lighty for his help and patience with me
              Jetijs
              • Ok, after hours of soldering I finally finished my MOSFET circuit. After this I don't want to see the soldering iron again for a long time
                Everything works beautifully, the amp draw is about 1.6A at 12V. The RPM's are about 1800. The motor vibrates alot so I will have to balance the rotor. The commutator wheel in these first tests has the same 40 degree gap on each side. Here is a video:
                YouTube - Lindemann attraction motor V2.0 video 4
                I will make more tests and measurements tomorrow.
                Thank you,
                Jetijs
                • Ed Leedskalnin & Magnitricity
                  If you have never heard of Ed you should check him out. He apparently figured out anti-gravity and the universal way electricity works. I saw a PBS documentary on him several years ago. HE BUILT A CASTLE COMPLEX NEAR Miami,Fl. by himself using anti-grav. to move huge blocks of coral (up to 30 tons!) by himself. He also moved it one time and loaded these huge stones on a flat-bed semi truck by himself using only one hour per load. His theory is fascinating & sems to work. Might help solve everyone's problems with electric current. You can check him out at Mystic Places.com for a start. By the way he was from Latvia.
                  Antiquer
                  • There is already a thread about that in this forum:
                    http://www.energeticforum.com/renewa...ht=leedskalnin
                    This thread is only for discussions about Peters attraction motors.
                    Thank you for understanding,
                    Jetijs.
                    • Comments
                      Hi Jetijs,
                      Looking good! So any idea yet what the real problem was? The switching or a rotor lockup? T
                      his is no criticism, but you sure that is 1800? Does not really 'sound' like it. How do you measure rpm?
                      Keep us updated!
                      Great work.
                      Steven
                      • Hi Steven,
                        I am sure that the problem was the lockup. After increased air gap I never had a problem like this again As for the RPM's, I also think, that the motor sounds slower, because with my previous design I got 2600 RPMs at best and it sounded WAY faster. I put a black tape on the shaft so that it covers half of the shaft diameter, and then I just pointed the laser tachometer on that spot, it showed about 1800. I will try to verify this with a scope.
                        Jetijs
                        • Good work Jetijs.
                          • I Concur
                            Good work Jetijs.
                            Jetijs,
                            Great work. Seems like the motor can really hum along. As for your back side batteries, they seem pretty dead. You may want to get a battery to charge that is equal to the run battery, or move to the "recycle to the front" circuit and see how much the current drops.
                            What I do is set up the front end with the capacitor and the blocking diode, and then connect some wires with alligator clips to the output. That way I can quickly connect the output to a light bulb, a second battery, or back to the capacitor on the front, and study the behavior of the motor in each case.
                            Lighty,
                            Thanks for helping Jetijs with the MOSFET drive circuit. I really appreciate your expertise and willingness to help.
                            Peter
                            • Great work!
                              Jetijs,
                              I have been following your progress, and I am hoping very much for you to achieve great results out of this. Eager to hear about your amount of recovery and other experiments!
                              Thanks for sharing your progress.
                              Elias
                              http://blog.hexaheart.org
                              • @Peter
                                It is my pleasure to help. I don't have any spare time to make one motor myself but it's interesting to help and see where it goes. Thank you for publishing this design.
                                @Jetijs
                                When you're finished dealing with mechanics could you please connect ground of your two oscilloscope probes together (so you don't use that common ground but rather two "live" inputs), set A-B (A minus B) channel mathematics in your software and possibly use ungrounded laptop instead of desktop PC (run it on battery without power cord). Also, don't forget to set sampling rate as high as possible and bandwidth also to max (turn off any filtering if you have it). Differential probe should really give you some advantage when measuring inductive collapse event for numerous reasons I won't go into for the lack of time and ungrounded laptop should greatly reduce effects of grounding when measuring these extremes. So, use two recovery diodes I've sent you (connected in series just to be on the safe side before we know what's the value of voltage peak) to "rectify" and measure the voltage spikes maximum value as well as RMS value. It would be beneficial to know these values in order to possibly calculate optimum value of the recovery capacitor. Also, it's good to know what you're dealing with before you possibly use lower rating parts and burn them. The voltage won't go over 500V on the power side because of the protection diodes you used but in future if the voltage is possibly too low one can use higher number of turns on the recovery coil (with appropriate corrections of wire gauge and other parameters of course).
