Lighty, do you mean that I should connect both scope probes across the output battery terminals? If so, then would I even see any spikes? Because when I put the scope across the charging battery on a Bedini SSG, I could see only a more or less straight line of 12 or so volts and very small peaks (in milivolt range) at the SSG produced frequency. I mean, the battery absorbs all the spikes and I only can see the full spike voltage if the charging battery is removed, but as we know, that can damage the transistors or in this case the MOSFETs.
So, I set my scope software to a demo mode with simulated sinewave at 2kHz on both probes. Now I set the math to A-B (I think) and a third waveform appeared in red (see the picture) it is almost flat. Is this the right way?
http://www.emuprim.lv/bildez/images/...nti_1/math.jpg
Also, I went through the help file of the software and the word RMS was mentioned only in one part. If I go to the FFT menu, I have this window:
http://www.emuprim.lv/bildez/images/...unti_1/rms.jpg
And the "help" explains what the different measurements mean:
-SNR (Signal to Noise Ratio): The ratio of the amplitude of the fundamental frequency to the Noise.
-ENOB (Effective Number of Bits) : The number of bits in an ideal converter that would be required to give the same SNR performance.
-SINAD (Signal to Noise and Distortion):The ratio of the amplitude of fundamental frequency to the Noise, but Noise include Harmonics.
- THD (Total Harmonic Distortion): The ratio of the RMS sum of the harmonics to
the RMS value of the fundamental.
-SFDR (Spurious Free Dynamic Range): The ratio of the RMS signal amplitude to the RMS value of the peak spurious spectral component. The peak spurious component may or may not be a harmonic.
: The RMS value of the peak spurious spectral component.
-Total Power: The RMS value of the sum of all spectral components.
: Sum of Noise excluding DC and Nyquist.
Which one do I need to look at to get the RMS value?
I haven't dealed with these kinds of measurements before
Thanks.
Thanks.
