Hi Uusedman,
When you say "collecting the back EMF" how are you doing the load part exactly? Are you just connecting a light bulb after the diode?
It has many advantages to collect that Back emf (fly back or inductive collapse really) into a low impedance source like a cap or battery and connect your load on that. Not straight to the back emf recovery diode. It tends to often be a too high resistance for the fast spike to dump into. And can cause because of that rpm drops. (And amp draw increases)
In my view one wants to collect that flyback as quick as possible, meaning it must be able to dissipate itself fast into a load/cap/battery. You want the core in each cycle to also have time to 'relax' and reset itself to a more neutral polarity condition before the next pulse happens. You want to do it all in one cycle: Pulse the core with for example 33%duty, then somehow collect all the flyback in 33% duty and in the final 33% duty time you want the core to do nothing and relax back to a zero magnetic state as much as possible. If the core is not relaxed/reseted and still has like a 75% remanent magnetic field from the last attraction cycle you will have very little real field change and because of that bad performance. So it is important that you dump the flyback in a low resistance load, so a cap would be best. Your bulb can be connected to the cap. Hell even better would be having a circuit that dumps the cap to the load in between each dc pulse.
Steven
Steven
