Not Sure about this method
Jetijs,
Your description of how the scales are used is confusing. It does not sound right, though. Hanging the scales on the motor shaft just weighs the scales. This is not what you want. Also, I don't think your digital scales are the right kind for this measurement. They seem built to weigh objects by having them placed ON the scale. Also, your cloth sheet does not seem to be able to produce the appropriate amount of friction to load the shaft.
The input voltage, input current, scale deflections AND the RPM (under load) all must be registered simultaneously to do the calculations. This produces a POWER reading. To actually calculate WORK, the readings must be maintained for a TIMED RUN.
Doing the Dynamometer test is a bit tricky. It is very difficult to do just using a small shaft as the "wheel of known circumference".
You are going to have to think this through, and maybe get some different scales.
Peter
Peter
