Tesla's radiant energy system (for Peter Lindemann)
  • Tesla's radiant energy system (for Peter Lindemann)
    Hello to all! For a long period of time i was studying Tesla's patents, but there was a turning-point, induced me to start practics. That turning-point were your videos and books, Peter. So i want to talk about radiant energy.
    I've learned in depth the book "Secrets of cold electricity", also watched "Tesla's longitudinal electricity" video. So i and group of engineers decided to replicate Tesla's radiant energy system. There are three types of electricity by Tesla: DC, AC and radiant current. Radiant current is produced by tiny particles of aether.
    In his experiments Tesla used spark gaps with unidirectional impulses to release radiant energy. Classical physics tell us the spark gap is a universal resonance tuner for any circuit, cause plasma discharge generates several frequencies. But this is what classics tell us. We can assume that Tesla used spark gap, cause he haven't modern semiconductors. But also we can assume that spark gap have some unique characteristics, that can't be obtained with semiconductors.
    1. Is it possible to use mosfets instead of spark gaps?
    2. Why did Eric Dollard caught radiant flow only from the bulb, but not directly from the transmitter's secondary? In the book of Gerry Vassilatos Tesla said that radiant stream went from the secondary of his discharge system. "Furthermore, whenever a metal point was connected to the upper terminal of one of his Transformers, the stream became more directive. It behaved just like a stream of water in a pipe."
    3. What resonant frequency has been chosen in Eric's transmitter? Eric Dollard said that every oscillating system has two resonant frequencies: one for transversal waves and one for longitudinal waves. Doctor Meyl calculated that the speed of propagation of longitudinal wave is 1.5 times greater than the speed of light. So should we design secondary with the rule of 1/4 of longitudinal wave length, or electromagnetic wave?
    4. More resistance of secondary - more radiant energy from it, is it right? What material should we use to wind secondary coil with vaximum resistance?
    We designed PCBs with flat pancake coils and bifilar coils .
    We decided to buy CG39.0LTR spark gap Littelfuse - Part #CG39.0LTR
    High voltage TDK ceramic capasitor 15kV 7000pF.
    So we want at first release this schematic:
      Just too busy right now...
      Dear Ashanin,
      Thanks for your interest in Radiant Energy. You are asking good questions. Unfortunately, at this time I am just too busy to wade into all of your questions.
      When I was 25, nobody even knew what Radiant Energy was. Today, because of the work of Eric Dollard, Gerry Vassilatos, John Bedini and myself, Radiant energy is understood and being put to practical use.
      You are just going to have to learn the answers to your questions by doing your own experiments and thinking about it, like we did. Maybe Lighty, or others working with this technology can help you. Read the other threads in this Forum on Radiant Energy. A lot has been discussed already.
      Best wishes,
      Peter
      Peter Lindemann, D.Sc.
        easy way to start observing radiant and unbelievably easy to make
        http://www.angelfire.com/80s/sixmhz/trashy.html
        found this one when searching for spark gaps ,this guru built this one from scrap to show how easy it is to get into study of tesla
        “Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
        Nikola Tesla
        http://www.imhotepslab.com
          And where did you see radiant streams in ordinary tesla coil? Tesla designed his magnifying transfirmer as electrostatic and radiant energy device, but not as electromagnetic resonance circuit. Streamers from tesla coil are side effects of this device. The main Tesla's aim was transmitting radiant energy. Streamers cancels all radiant effects.
            chapter 1
            Hi Ashinin,
            If you read Secrets of Cold War Technology chapter 1 on Tesla...what is your analysis of it? Just curious and welcome to the forum.
            RPX & MWO http://vril.io
              What most people don't realize is the fact that the transfer of radiant energy occurs through the ground and not through the atmosphere or any other surrounding media. Tesla was very adamant about the fact that electric energy can be transfered through single wire (Strebkov, Zaev and Avramenko pretty much confirmed this in the most practical sense) with almost no loses using the resonant effect of what we would nowadays call transmission line. He was also very explicit in his claim that since the single wire tranfer is possible then Earth could be utilized as a single wire conductor.
              As for the streamers and any kind of EM radiation whatsoever emanating from his transmitter- he was also repeating over and over and over again that his system was designed in such a way to prevent any kind of EM transmission to the surrounding media other than Earth and that the energy transfer occurred exclusively through a ground conduction (or rather ground single wire system). That was also one of the reason he limited frequency output of the carrier to the absolute maximum of 200 kilocycles. Finally that's also the reason that when you see streamers of any sort being emanated from the secondary you can be pretty much sure that you've made a mistake Tesla warned about- you wasted energy in the form of Hertz waves to the surrounding media.
              http://www.nequaquamvacuum.com/en/en...n/alt-sci.html
              http://www.neqvac.com
                1. I think we should achieve the shortest pulse fronts. It is possible only with spark gaps, cause there are no powerful and fast switching semiconductors for high voltages. Only with such a voltage we can produce visible radiant effects.
                2. We should find optimal place of spark gap in primary chain to produce positive or negative radiant waves.
                3. We should find materials for secondary with huge resistance to prevent electrons from moving.
                4. It is necessary to check resonance frequencies for longitudinal waves and to design 1/4 wave resonator system.
                5. We can catch radiant flows with metal plates connected with capasitors.
                  Basically you don't need any special material for secondary. You just have to read what Tesla said about the way coils have to be constructed.
                    lighty, Tesla said the secondary should be 1/4 wave resonator. He also used conical coils in his transmitters. What coil do you mean?
                      Your gap will determine the frequency.
                        Chip Shorter, spark gap automatically tunes the circuit to it's resonanse frequency. It will not determine pulses frequency but capasitor.
                          Indeed but as his secondary had to be 1/4 lambda you really ought to look into the theory of Tesla coils (or what people call like that) and see what happens with voltage potential at 1/4 lambda as well what happens at the ground connection.
                          Also, if you want to use Tesla's system as he intended it you have to go to frequencies below 200kcycles- if you read that Tesla spoke about several miles of wire in his secondary (and he used 1/4 lambda winding) you can see that the frequencies he used had to be below 50kcycles (most probably between 10-30kcycles). The self-induction of the coil and the resistance of thin copper wire at that length should serve more than adequately to slow down electrons (if you go after that theory).
                          • #14
                            Eric Dollard produced radiant effects at 2.9Mhz for example
                            • #15
                              Yes he did, but he compromised (I suspect because of low budget) and wasn't striving for highly efficient energy transfer to distance. About that one you really ought to ask Peter.
