Thank you. I look forward to seeing the work being done here.
Bill
Hi Bill
Now to work!!!
I have some land YouTube - Allotment
on this plot i what to get the tube running which will be proof to the people around me that free Energy is real and working, if I get to show this the fallout of this action will be Massive!!!!
I also looking at the freeman movement to help with the lawful/legal side of getting a really big piece of land and moving in lock,stock. I was born in this city and have a big group of people looking at me for the first steps to freedom from the state.
I can only do this will help from you Bill I need a drawing of the setup you have, with link too product to buy.
Ive done a lot of work on this and have a BIG stack of ideas on the backburner once I get this running
Also have been talking to ashtweth from Panacea Universitywe need
to get this in a doc for him to putup at panacea.
Once we get moving here Bill, things start happening very fast, we have a lot of systems that can work off this battery.
I have no drawing and I guess I could make one but it is just simply some rods stuck in the ground on the proper alignment as described. I make terrible drawings (see some of them at OU.com) but I can give it a go. Gadgetmall has a ready made earth battery kit on his website. If you look at any of his post at overunity, (like in the joule thief topic) you will see a link to his site at the bottom of his posts. I believe he is charging $55.00 plus shipping and it has both the carbon rod and magnesium rod. I would post it here but I don't know the rules about promoting stuff like this. I suggest anyone interested to ask him about it as I am not endorsing this one way or the other. It might be a good way to get the materials which can be hard to find in some/most areas.
I read this topic from the start and I wanted to point out that the part about the ground being wet is not what I have been seeing. When it rains and the ground is wet, my output drops a bit. When it is dry, totally dry with no rain for weeks, my output raises. Others in various parts of the world have reported to me the same thing. This is one of the things that makes this different from a water battery, or galvanic battery in my opinion. There are some other reasons as well which we can discuss later.
I will try to make a drawing. (Promise not to laugh)
Thanks for the welcome, I missed your post earlier.
@Uusedman:
On overunity.com the joule thief topic I started will tell you anything you want to know about them, and more. Since we have over 6,000 posts there, I started another topic which I locked, (joule thief diagrmas, etc) just for the diagrams and photos. There is a ref. to the page that the diagram came from on each post. I am well behind in keeping it caught up as I am only up to about 3,000 posts worth. But, it will show how to make the Fuji, how to modify it even more, how to make a standard JT, etc.
For a really most basic JT circuit, you can find that on instructables.com. (search for joule thief) Also, Bree Petis from Evil Mad Scientist Laboratories has a good instructional video on how to make one on Youtube.
The most common transistor we used is the 2n3904. You just need one, and a 1k resistor, and some 22 ga. wire and a ferrite toroid. Electronics goldmine has some good ones we have had great success with. They are 5 for $1.00. These are 1" OD x 1/2" ID. That is all you need to make one.
Then, once you get that working, go to overunity again and read the advanced stuff they are winding. As I said, I began that topic and a good many of the folks there are waaaaay ahead of me with their work. I think the record is now up to 1,350 volts from an old AA battery!!!! These are all hand wound and not the Fuji stuff. They have many different windings on a single toroid and also they are using pick-up coils on other toroids and appear to get no additional power drain when doing so. It is fascinating stuff over there. It is too big to read all of the posts but that is why I made the other topic too.
If I can help you with anything, just let me know and I will try. I am no electronics expert at all. Actually, I got into this stuff about 2 years ago and have learned so much with a lot of reading and a lot of help for many others. i have 2 working Bedini motors, (Including a replication of Jonnydavro's no bearing, one magnet Bedini) and a number of other projects as well. This is a lot of fun and you really can do useful things like make light.
Basically just 2 Coils across, where one trigger the other.
Slayer suggest a Toroid Ferritcore, but the Fujycoil seems works well too.
But i made them from all kind of Things, Transformators,
lately 2 Aircoils, what caused, to burn my Pot again with 9 V.
And when you wind one Coil opposite direction, eg clockwise-Counterclockwise you can use both Ends at one Side for Plus.
Otherwise mostly the opposite.
And when it dont works, just switch the Wires around.
cant help but wonder what would happen if a joule thief or two were burried in the ground.....
the really good thing about pirates EB is that it will work in the areas where they need it most, like africa.
its totally wet where i live most days, but i'm sure that could be an advantige somehow.
ok, still wrestling with my 3055 and computer monitor ferrite bead. when i suceed, i'll bury it/them. sounds weird i know....
For whatever it is worth, I'm posting this for reference.
I've had a galvanized sign (call it GS) used aside of the road advertisement in the ground for months,
wire is attached 1.5 feet above ground level.
It has two legs of less than 1/4" galvanized wire .. that's the south side.
Readings at 20 ft north of the GS:
Holding the probe in your fingers will read about 0.3+ volts (Don't touch the wires or rods you are metering !!!)
meter probe stuck into ground: 0.1 volt
meter probe stuck into wet ground: 0.5 volt
1/4" galvanized rod, rack/shelve rod used on peg-boards, dry ground: 0.3 volt
1" hole with 5" of charcoal and galvanized rod, wet: 0.5 volt
meter probe in hole with charcoal, wet: 0.75 volt
meter probe at top of hole, at ground level in charcoal, wet : 0.88 volt
Wet verses dry ground means I poured some water on the ground.
The charcoal is a power, it is home made which can be crushed easily with one's fingers into a fine power.
As you can see, the rod can reduce the voltage, if both north/south are then same (duh )
45 mins later the ground level reading on wet charcoal had dropped to
0.6 volt and the charcoal in the hole was up to 0.84 volt.
A single reading is not valid. You can read it 3 times in a row in 10 seconds
and get 3 different readings or about the same reading.
