Earth Battery SG
  • #16
    in the ground together in water or apart in two contaners.
    • #17
      RE: water
      In a cup...
      I saw this on a video on youtube and ... it interested me more about earth batteries.
      See my experiments here...
      • #18
        Thank you theremart
        one 25ml water tube puts out o.85v the thing is i put a battery (9v reading 8.66) in series now i get 9.50 volt.Hows this work?
        • #19
          oscillator schematic
          Hi Bodkins, there are schematics in the Bedini Oscillator thread.
          RPX & MWO http://vril.io
          • #20
            RE: battery...
            Thank you theremart
            It works good
            Now put a little baking soda in the mix, should give you another tenth of a volt.
            You have two different metals, the exact mechanics of it I don't know, but I noticed in reading about the old earth batteries, they would drip water on them to keep them moist. I figured ehh why not just put them in jugs of water with electrolyte... sorta create your own battery.
            These are some cool videos...
            YouTube - Water Battery - Quest For Free Electricity Part 2
            • #21
              I was thinking on it while looking bendini schematics
              From the beginning, John has shown that you can ground the sg to the earth. Look carefully at:
              http://www.esmhome.org/library/john-...-bedini-sg.jpg
              http://www.esmhome.org/library/john-...bedini-sg2.jpg
              Below pic is what I'm pointing out:
              Unfortunately, most people haven't paid much attention to these details.
              In my diagram:
              I show something else.
              The zinc rod from the SG's ground is going to earth. That is a real GROUND. The Earth may or may not be used as an electron source. You can get a POSITIVE radiant potential (voltage potential) from the Earth and this has nothing to do with electrons.
              My diagram shows Bedini's ground as she has shown in front of everyone for years but hardly anyone noticed but a few. The other copper rod is what Kevin had on his setup in addition to the goofy magnet setup when getting way over 1.0 COP. Thing is, Kevin didn't even have the regular ground rod from the neg on the system...just the rod with diode to the + on the charge battery to absorb radiant potential from the earth.
              This diagram is putting BOTH of them together. It will be obvious to anyone that has experimented with Earth Battery setups that looking at my diagram, both rods together obviously form a basic earth battery or a real potential difference at both rods...about 2-4 volts can be easily expected almost anywhere at minimum. You have to poke around a bit to get above 2 volts but you can find it.
              The battery, better if large plates or of other construction like Bedini shows on his site, intercepts and soaks up earth currents and entrains the earth currents there.
              What can be expected out of doing this? Everyone has to do their own experiments but what Kevin and I have found is that the charging effect in the output battery increases.
              You can see where the diode leaves the copper rod and goes to the + on the charging batt...there are other places you can put it but you have to explore that on your own.
              Just see the SG for what it is...it is a gas valve and all concepts of gas pressures apply. What do coils do and how are they pumping this gas and how do you get low and high pressures and putting that together with what is sitting on that diode on the copper rod, well some things should reveal themselves.
              Hey AAron I was studying that schematics, i did a question about that in http://www.energeticforum.com/renewa...html#post22552
              i would like that John Bedini explain us that about ground on his circuit. I did a test in last week with Ignition Coil and 555 timer switching Ignition Coil with sparkplug. When you put sparkplug near to ground (floor) sparks to ground, then is possible ground could be negative and sparplug positive. That can be relation with Tesla's ionospheric energy.
              Steve Jobs. Apple CEO
              • #22
                earth ground
                There are both positive and negatives on the Earth.
                • #23
                  I did my theory about that...
                  Then if earth can have both positive and negative, then we need a way to pump electrons from the earth to create negative pole, negative pole give us electrons, electrons create electricity, when goes to positive....
                  Using a little of electricity with my Ignition Coil is possible pump much more electrons from the earth....
                  I believe that my circuit can be based on last circuit of Imhotep that he go to publish 1st August.
                  My circuit is the next:
                  555 osc timer to 20 khz aprox. excites a MOSFET high amp like IRFP450. MOSFET feed (+) ignition coil, coil's output is connected with normal wire spark plug to avoid currents losses, spark plug generates sparks, this sparks is atracted to whatever mass with low potencial (-), thus connecting HV Diode is possible separate (+) part, controlling electrons flow and storing electrons on flash capacitor, flash capacitor can be power a load.
                  • #24
                    earth battery charging cap video
                    Cap is charging by pulling the negative and not pushing into the positive.
                    YouTube - Earth Battery | Bedini SG | Radiant Energy
                    Works better the deeper you go with the metals. Works better with more mass. It is easy to get about 2v if you look around. I've gotten up to 4v with 2 rods but seems hard to find that.
                    • #25
                      Aaron, this is where the SG should of stared, harnessing power as an open system
                      Thanks allot for doing this
                      Ash
                      • #26
                        Let me get this right !!!!
                        What your saying is you can pull a charge off both postive(Kevin) and negative(your cap). Yes?
                        If thats the case would it work with the postive the the primary battery and the negative on the cap
                        • #27
                          Earth potentials
                          The main purpose for that video is just to show that there can be real practical effects to be had from an Earth rod. I just hope others use their own creativity and innovation to see what they come up with.
                          There are different ways to utilize the pos potential rod and neg potential rod.
                          If a neg rod is connected to a capacitor's negative for example..even with one wire...if the "Earth battery" has a potential difference at its terminals great than the capacitor's terminals, the negative line will form a suction on the negative terminal on the cap and will create a bigger net positive pressure in the cap.
                          You are forcing the negative on the cap to become a lower negative (by suction of the lower negative potential) than it was before and that creates a larger potential difference between the negative and positive terminals.
                          You did that not by even doing anything with the positive but only by manipulating the negative or lower potential side of the system.
                          • #28
                            other situation
                            p.s. If the earth neg is a lower potential than the neg it is connected to on the circuit, it will then act as a sink to give a more "conductive" path for gravity to channel more potential through the system.
                            • #29
                              I guess you got my message on you tube
                              I came across this same earth battery effect a while ago. I determined it was acting like a lemon battery, which gets best results between copper and zinc. You can put dirt into buckets or plastic containers and make individual batteries, all about the same potential, you may need to water it down to get a good connection to the dirt. Then you can connect them in series or parallel to get your desired output power. I lit up a LED and stopped there. Im not sure that you would want to seperate the dirt from the ground in this case, however i found you will get a higher amount of power with many cells than just one in the ground. I figured that it was because we have acidic soil (lemon battery effect) but maybe something else can come of this, like Stubblefields earth battery. He did basicly the same thing your trying to do, pulse it out of the ground. From my research on that system, your power will eventually deminish coming out of the ground unless you can pulse it out at a fast rate, just like a lemon battery will eventually lose its power. Maybe im wrong but thats what i concluded from playing in the dirt
                              • #30
                                Earth Battery
                                Hi Cody,
                                Depending on how it is done, the Earth Battery will actually grow stronger and stronger over time. The rods I show is not really an Earth Battery but does demo the potentials are there.
                                One of the tricks on a Earth Battery is to keep all the terminals from shorting each other out.
