Very good points on the order and the priming.
Earth Battery SG
Originally posted by Iotayodi View PostVery good points on the order and the priming.
I think the switch can be done by a sg or a little fan in the wind sorting the coils,
I love it
setting up a condition in the aether that self sustains, producing the voltage potential with aetheric stress, without using chemicals, and deriving electron movement from there.
Have you done a clear drawing of how to build each unit? Might find a use for my back yard after all..
Love and lightAtoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
Originally posted by Inquorate View Postsetting up a condition in the aether that self sustains, producing the voltage potential with aetheric stress, without using chemicals, and deriving electron movement from there.
Love and light
build is easy zinc rod or zinc plated box with cotton to insulate the windings, put in a plastic drain pipe with a sealed base with holes to let the water out (like planting a energy flower)fill with earth water it and stick in the ground.
love and light 528
Originally posted by Bodkins View Postalso ben got infomation saying, that if you have voltage and a vac tub you can use the sunlight to supply the amps! more on this later,
love and light 528Atoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
YouTube - earth battery light bulb
I lot of hard work for a flash! but it will charge passive so what about pulsing?, Im trying to use the Sg fan to pump the energy around with a cap on the front end so i can spilt the earth battery across the cap and power battery.
what i have now is basic, not really got the volt up to a point i can dump into battery
any ideas?
Originally posted by shubhamformeFree File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu
need a simple,chea and effective osolar charger which can charge your car lead acid 8o amp battery with just 5 watts solar panel……then here it is….
this is one of the very best and simple yet very effective and cheap solid state self triggring radiant oscillator or charger...
please give me your feed feed back and views...
i had recently desulphated 3 of my 5 years old 12v 80amp lead acid car battery...now they hold a charger quite properly....
and i had simply use a 1amp 9v pus or power supply for input...
heres the link to circuit.....
download it and enjoy---
link--- Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu
thanks
shubh!!!!now stick up a picture with a big happy smile!
led solar panel earth battery
love and light x
Series Earth Battery
Hello Guys and Gals(Jeanna) . Just a quick note that Jim(electricme)has Successfully Series connected his earth battery's to produce more than 80 Volts dc at a considerable Amperage . I know it could be Done . I personally can get 15 milliamps off of My carbon and magnisium rods . I sell sets on My web Site (www,sunpowerwindpower.com) in case you don't have a supplier . Copper and zinc do not work well for me in My ground here in NC . I have been Lighting up Joule thiefs from day one manm many months ago producing whiye light continuiuus . I recently pulled one of the Mag rods and there is very little wear after almost 9 months .My jt produces any voltage i wish but i use one of them to keep a 650 farad 2.7 volt Ultra cap full for experiments .I am able to power radios and lights and small One Magnet Bedini Bearingless Rotor . With one volyt and 1 milliamp . Needles to say this one is a self runner with 5 extra coil gathering electricity from the spinner magnet and also produce light and charge up a few super caps to boot . motors with one earth battery directly with only a small 2000 MCD cap in parallel with them .
Ok good work . i would say more but i am on dial upand it takes way too long to chat these days now that i have no High Speed availible where i live .
Take care GodBless and Good Experimenting ..;
Fusionchip
AKA Gadgetmall @ ou.com
Spaceborne observations
Originally posted by jeanna View PostI am seeing up to 67mV pulses at a rate as fast as 5.5Mhz. They are quite sharp and they are on a carrier wave. I also see it in a 'fractals' light, because the waves repeat themselves at different resolutions.
jeanna
I would like to point you to this paper which might explain why 5.5Mhz:
1965IAUS...23..309H Page 309
See figure 3 on page 313.
Spaceborne observations of radio noise from space done
in the 60s show that most of it falls in the 1Mhz to 5Mhz
range.
fyi
HA
ET radio stations eh?
I think the most interesting part for me was that these frequencies were not the same every day. Most of the time they were 2.2Mhz to 2.4Mhz and some days 2.5Mhz.
I think there must be a lot of radio waves everywhere and I do not mean those from radio stations on earth. I am meaning that every light bulb or dishwasher etc gives off radiation light or heat etc. That radiates out and across. We twirl around etc.
I think some of it is us bumping into our own past radiations, and then of course all the stars and explosions in space keep going radiating outward. We must be bumping into them too.
I just didn't ever see anything higher than 91mV from my EB plus 2 stubblefield generators set-up.
I never did make those stubblefield generators big enough, I think. I will get back to making more.
thank you,
jeanna
Originally posted by Bodkins View PostYouTube - earth battery 7
still working
i cant get the scope down to the allotment no power sorry Bill
Bill
Originally posted by Pirate88179 View Postwhat I do is to wire my electrodes to a 50 ft extension cord, one on each prong, and then run that into my house and hook that up to the scope. Much easier than packing the scope outside. Electricme (Jim) told me of this little trick. It works just fine, unless of course, your electrodes are way out there somewhere.
Billsaving for a inverter
Richard
Earth battery booster?
might a salt water battery leverage/multiple energy extraction if paired up
with an earth battery?
Don't take these references "as-is" .. but how could they be reconfigured
or redesigned to be used with an earth battery?
Might a tube tightly packed with crushed activated carbon for the
anode and cathode with salt water
at one end of the tube and fresh water at the other end of the tube work without flushing / total
replacement of salt/fresh water?
They claim 1 Kw per liter of water is possible but have not obtained that yet.
References:
12V 40AMP HOUR salt water battery
Amazing 12V Saltwater Generator
Physics Buzz: Electricity From Salty Water
