Earth Battery SG
  • #31
    Hey, two month ago, I was studying electricity from water, if you put copper rod and iron rod on destilated water, reads a little voltage, 0.6 volts aprox with my volt meter. I put many glass connected in series and turn on a led. By many days bright keep equal. Then I tried put a energy on the rods from a power source 12 volts. First electrolisys begin after with volt meter reads more voltage and get low but keep high.
    Anyone has tried this???? I was thinking to try charge a capacitor from this water battery.
    Steve Jobs. Apple CEO
    • #32
      video of my earth battery, easy free energy, you try
      Yea patmac, thats basicly the same thing i did with dirt. Hear is a video to show you what i did.
      YouTube - Earth Battery
      Thats just dirt in milk jugs hooked up in series. Put enough of them together and you could power your house. That would really take a lot of them though. I also think that this power will decrease after a while just like a lemon battery or any other battery for that matter, so before you go out and buy a truck load of nails you probally should test to see how long its good for. Aaron suggests that the power will get stronger after time, which would be cool, but i havent tested this yet to confirm it myself.
      • #33
        dirt batteries
        Hi Cody,
        Thanks for posting that vid. Yes, they have to be isolated or they short each other out. There are ways to create isolated batteries in the ground that don't do that. Check Bedini's Stubblefield pages on Earth Batteries.
        When in the ground, what grows is that they entrain the aetheric magnetic currents...not magnetic field, but magnetic currents. That is how it grows...it gets a memory effect.
        Try charging your batteries there with the radiant from an SG and see how high you can get the voltage and see if they last longer. Charge/discharge and see if you can condition them. That would be interesting to see results from that.
        RPX & MWO http://vril.io
        • #34
          Thanks Arron
          Will be testing this patent over the next week!
          YouTube - Bodkins 16 Stubblefield earth battery
          • #35
            Hi Carl
            PAT2PDF - Free PDF copies of patents: Download and print!
            patents number 600457
            Carl this is not a chemical battery you can insulate the copper and the iron/steel wire and it will work it runs on earth magnetic currect.
            Thank for the link but i dont think they are doing it in the right way, pulse the third coil this will push the earths magnetic field out. when the third coil wire colapences the earths magnetic field will take its place and give more energy than impulesd (I think)
            good luck
            B
            "Workers on the telegraph system noticed big discharge on the telegraph line"
            Think about is people Telegraphs are a series of pulses
            • #36
              Testing tomorrow
              • #37
                Originally posted by Bodkins View Post
                Hi Carl
                good luck
                B
                I think you might be right Bod.
                They have been at it for some time, but no cigar.
                Anyway, it is useful to see what ground they have covered, it all helps in the end. (no pun intended)
                NS may have starved to death, but he didn't freeze. He seemed to be making lots of power.
                Carl
                • #38
                  Testing tomorrow
                  Bod,
                  That looks like 6011 welding electrodes in your core.
                  Should give you deep penetration.
                  Carl
                  • #39
                    Applications?
                    Anyone have a practical application for this resource?
                    Love to hear it
                    Acts 1:8
                    • #40
                      Love to hear it
                      wait till i have it working !!!!!
                      Carl LOL
                      • #41
                        Re Use...
                        Love to hear it
                        In the book "Free Energy Generation" some suggestions are to hook up a solid state Bedini to this source of power to charge batteries.
                        I chuckled that the one guy lit a led in his bathroom, but you know that is light he does not have to pay for, so a step in the right direction.
                        I think this sure would beat solar, if harnessed correctly reading the notes on the Bedini site, it states he was able to light arc lights with this energy.
                        So the pattern I am seeing so far is 3 coils, one is pulsed, and the other two you draw the energy from. Reminds me from the scene in Dune where they ran "thumpers" to call the giant worms.
                        Another thought hit me today... The pattern of some of these batteries where sheets of metal, a sheet of copper, and a sheet of zinc.... I have tried metal rods, but has anyone here tried sheets of copper? Why not an antenna burried in the ground? It seems that tree roots also were used...
                        So many different things to try. I am scared to dig, too many power lines where I live.
                        See my experiments here...
                        • #42
                          First Test
                          YouTube - Bodkins 17 first test Stubblefield earth battery
                          This was to make sure i had diodes and coil config correct,Next is the pulser and a lot of potash. I have a wood burner just hope the plant like potash?
                          The worms are packing there bags,
                          Mart my local diy shop has some big copper sheets but i sticking to one thing at a time
                          • #43
                            YouTube - Bodkins 18 pulsing test Stubblefield earth battery
                            Not in the ground yet!!
                            • #44
                              Originally posted by hh1341 View Post
                              Bod,
                              Carl
                              ye welding rod its a old coil core recycled cant remenber the numbers sorry.
                              im not expecting great results garden to small and coil to small.
                              But it the only way to learn theres day is by trying
                              • #45
                                Its not that easy Got the number wrong!!!!
                                200mili amps not 20miliamps
                                well nevermind still working !!!!!!!!
