@lidmotor
-----------------bobbin motor --------------
Oh I am so glad i asked.
I missed a whole week of bobbin motors from you.
I love that motor.
AND... I have been wanting to make a charger without a transistor and I see you have done that too!
Well done
thank you.
@all,
-------------------- plant battery-----------------
I have had a hard time getting the voltage high enough today.
In a way, I am glad I did this the way I did.
Here is how I did this today:
I made up some new standardized planters and waited for the volts to get high enough and it was my plan to add the plants later.
I had to give up and just add the plants, because nothing was happening.
The first one which is similar to the 2 I made in the last 10 days, but in a much bigger container, took 3 hours just to get a spot of light and even after 5 more hours, I could still look right at the led. (I really don't like to do that)
This had only one leaf with a root which filled the tiny pot but in this planter the leaf was very alone in the middle, so I added some more plant. Very soon after, the light got brighter, and is continuing.
The next test is a mag block and copper pipe like lidmotor's.
It sat at 1.2 volts and 1.8mA for an hour.
I am starting to wonder if the block really is magnesium.
Anyway, I just gave up waiting and put the plant into the soil on this one.
The mA jumped up to 2.2mA.
But, when I move it even the slightest bit, the volts go down to 0.8v.
I will make a jtc for this tomorrow, and I will include a memory cap across the leads.
It really does the trick... but there is a minimum which seems to be 2.4mA at 1.4v
I was half kidding before, when I called it a plant battery, but maybe it really needs the plant to make it go.
And the other plans I have are to plant some seeds.
I wonder if I can get the jtc to turn on before the seeds sprout.
I thought I was testing the effects of the jtc on the plant.
It appears it might be the other way around.
It might be the effects of living plants on the jtc!
Either way
jeanna
I love that motor.
Well done
thank you.
@all,
Either way
jeanna
