Earth Battery SG
  • Magnesium and Graphite
    Hi Joit, you are correct in getting results from these materials especially magnesium. There are companies out on the web that sell these materials for cathodic protection of buried pipe lines and tanks that produce in the neighborhood of 1.5 volts. This acts to protect those installations from deterioration while buried in the ground. They sell magnesium ingots with wires attached, that the wires are in turn welded to the device they are supposed to protect. It is a very clever use of these materials to develop voltage to protect what ever they are attached to via a copper wire.
    Kingman.
    • Magnesium Anode / Cathodic Protection
      All, here is a link to a company that sells the tools and anodes designed to produce a small voltage that I referred to in another post. My intent is to get one of these anodes to possibly use in conjunction with the Self - sustaining induction coil of Nathan's patent. It will take experimentation as to where to place the lead coming from the Magnesium anode. It may require adding an additional winding to the coil to accommodate the voltage input from this anode. Now this is all conjecture as to if it would work but through experimentation one could learn the best use of this device and how it could interact with the NS coil. I feel it could be a viable addition to NS design. I still think that Nathan daisy chained his coils together to improve the results. I also think that he was using the voltage developed in a bank of coils to feed into 1/2 of his heating device and using the voltage yet from another bank of earth coils tied to the second plate of his heating device that he used to heat his cabin. I included a link to a magnetic heating device that hold some promise but I think that Nathan's cabin heater was operating at a high voltage set to resonate at a specific frequency via aiming these devices at each other that in turned heated up to a high heat thus providing heat for his cabin gratis of Mother Nature and his ingenuity!
      Maybe Rickoff would have some ideas as to how this heating device might have worked. He understands a heck of a lot more about tuning frequencies then I do.
      Link to Anodes that are available for purchase;
      Home
      Link to magnetic heater;
      Magnetic heater apparatus and method - Google Patents
      Kingman
      • Link to magnetic heater;
        Kingman[/quote]
        Hi Kingman,
        Interesting to see a Troy Reed patent.
        -Gary
        • Hi,
          Gawd, i dont like these Patents there, they have such less Pictures on it .
          I prefer more some nice Pictures.
          Anyway, i still played further around with Caps with Water, added Salt and Vinegar into the Water, and then 1 Cell gave me from the Salt 1,4V 2 mA, before 200µA.
          At Amp reading, it did go down to 1mA.
          Vinegar, because Salt does make a Reaktion with Magnesium for a while, and makes a Coat over it, and Vinegar keeps it smooth.
          But 3 Caps with Pencil and pencilsharpender been enough, to let a Led shine.
          4 maybe get really Light.
          But i guess i go to build a small box, with few small Cells in, and then its a pretty good short-circuit-proof Battery.
          And bad, i am to far from these Comapnys, guess i will take what i can find around here
          • Magnetic heater patent
            Hi Gmeat, I found this patent intersting and it just might have some similarities to what NS might have been doing. We of course will never know for we have very little info about how Nathan had built his home heater other then what has been published.
            Kingman
            Do the thing and you will get the energy to do the thing.
            • magnetic monopole
              hello everyone. This guy in 1940's claimed to have found magnetic monopoles, and created electric currents with them. Perhaps this is what stubblefield also did somehow?
              http://www.rexresearch.com/ehrenhaf/ehrenhaf.htm
              • magnetic currents
                This is from Bedini's page:
                Stubblefield
                "Nathan Stubblefield used earth magnetic currents. this is not current as we know it. Electricity is a wasted product of this magnetic current."
                • Laser Tachometer Measurement of "M and B" Device
                  Hi All, I have a laser tachometer that I used to get an idea as to what the cycles are per second of the action of the make and break device I built. This is the disk design in one of my photos. Now aiming the Tach at the silver magnet center I'm reading in the neighborhood of 150 to 200 cycles and that varies because of my design. It is obvious that I have to smooth that out to a less varied c.p.s. I know that my current system is still a little rough and need to modify the design. In one of my other designs I feel that the CPS must have been much higher for I used a stethoscope to monitor the CPS because it was a rapid vibration that I wished I had put the tach on but didn't think to do it at the time. It was a high speed hum that just sounded awesome and you could see the tiny blue sparks taking place between the copper contact disk / washers. My gut tells me this was the optimum operation. I could only guess what the speed of that "Make and Break" was running at.
                  Kingman
                  Having to much fun making mini discoveries via experimentation!
                  • magnetic currents must be responsible! Amazing;
                    Hi Aaron and All, I just love the look of this design of earth currents you posted Aaron, I think John Bedini drew this but not sure and you can correct me if I'm wrong.
                    Stubblefield
                    (Aaron's Picture that did not transfer for me. See above of John's drawing)
                    this is really weird and astonishing. I have setup in my garage a test so to speak. I have an LED that has a 330 ohm resister in line with it attached to a 12 volt 35 watt battery. I hooked this up back around the first of October 2008 and started with a charged battery something like 12.55 volts when I started. I intended to sacrifice this battery just to see what would happen to it. So it has been running since then and of course it had finally run its course for the LED was so dim that for all intents and purposes the battery was totally dead and the LED was no longer emitting light.
                    Now there is something a little special about this setup in that it is hooked to an 8 foot copper cladded grounding rod buried in the ground horizontally in a north south setting and is about 6 inches under the ground. I have the wire coming from that and in with the wire I soldered a Diode so that the current can only travel one way and that is to the battery from the grounding rod. I have that hooked up to the + on the battery. So I think that covers the setup. Now I have not touched this setup and have done nothing more to it other than stated below.
                    To my surprise and amazement when I came out into the garage this morning to get the snow shovel I looked over at the LED attached to the battery and WOW it was almost at full brightness. I can not explain this. It is as if the battery had switch from providing the load (the LED) with power to become a pump and start sucking energy from the grounding rod. Now I also did something else about 3 weeks ago, I purchased some zinc galvanized iron spikes from Lowes both 12" and 10" spikes and I placed those in a line shoved into the ground above the 8' ground rod. I also made sure that one of the spikes was in contact with the grounding rod. There are about 6 to 8 of these spikes still in the ground for I pulled 1 10 inch and 1 12 inch spike out of the ground for other uses. Any ideas? Right now it is powering the load and must be charging itself to sustain the load. No clue! I have more information to come for I took some battery readings to better understand what is going on and will share those with all. I must admit I did not expect to see this happen. I expected the LED to discharge the battery to nothing and kill it. I took a reading when I seen the LED lighted back up and I'll share those in another post. Oh, and I just took another reading at least 9 hours later and you'll be surprised!
                    Kingman
                    • Earth's magnetic resonance frequencies and harmonics
                      Link to esoteric resonance website.... Earth magnetic frequency here quoted as lower than I'd thought. But then I'm in tesla mindset, want very high frequency of resonance in aether. I suspect earth magnetic resonance better for earth battery pulling magnetic dipole streams to generate electric current. ?
                      Anyhoo,
                      Applied Biophysics Aether Research Laboratory: 02.08
                      Felix Ehrenhaft: Magnetic Current --- 9 articles
                      • for those researching earth batteries
                        The "Earth Battery" is in use in the oil field today and has been for quite some time.
                        Try a google search for the following "Cathodic Protection" and "Cathodic Potential"
                        One thing ya'll should start banking on is this:
                        Methods and Apparatus based on Super efficient or OU physics always turn up first in weapons, oil production, or medical devices.
                        Peace
                        PJ
                        A Phenomenon is anything which can be apprehended by the senses.
                        • Hi Kingman you work is beatiful sir
                          one question the battery LED, was it a battery used in a bedini setup before?
                          • Battery & LED
                            Hi Bodkins, Wow, how did you know? The answere is Yes. This is a battery that has been used on one of my SSG's and has gone through many charge discharge cyles. What clued you in?
                            Kingman
                            • Cathodic Protection / 17 Lbs. Magnesium Anodes
                              Hi Sigzidfit, you are right about Military applications being first with this technology instead of lighting our lights and heating our homes.
                              Our government will use the technology before releasing it to the common citizen if ever. More likely never! I did however mention in Post 106 above what is currently available in the market place and the ability to purchase magnesium anodes that generate electricity when buried. Like I said in a previous post that there may be a way to use these anodes to apply power to the NS coil on posts 5 or 6 or maybe even post 10 of the NS patent. Only through experimentation will this come to light as to how to best use this technology coupled with a 100 year old patent of Nathan Stubblefield. I feel it can be done with some good old Yankee ingenuity.
                              Thanks Sigzidfit for offering us all some help in this endeavor, Do you have any other ideas that might help in getting NS patent working as Nathan did?
                              Kingman
                              • Hey Kingman,
                                Thanks for the positive response to my post. It's the first since I came here. Boo Hoo
                                The earth battery while intriguing isn't where my head has been. Actually I am a refugee escaped from an oil field services company that did regulatory compliance inspections on cathodic protection systems
                                As you may well already know all intelligence in such organizations is HIGHLY COMPARTMENTALIZED.
                                Just off the top of my head I'd say be sure there's plenty of moisture in the ground where the battery is buried. Maybe a little salty brine. Or urinate on it.
                                PEACE
                                PJ
                                Oh, I almost forgot, you can buy small anodes like the size of a pencil. They use them to calibrate the inspection equipment...ugg it's all coming back to me now. Rough up or scrape the surface of your anode to remove any corrosion and increase the surface area.
