Earth Battery SG
  • All such devices seem to use important factor: closed path for current and usage of inductors.
    Am I only one who see this ? Induced currents flow from Earth magnetic field into antenna , then in circle closed circuit accumulating. Output is secondary coil by induction or a second path at 90 degrees like in Sweet VTA or TPU or Roy Meyer absorber.What about Stubblefield device ?
    In Tesla devices closed path is OSCILLATOR, and output is got from secondary also.Hmm..is it a by accident that magnetic field is perpendicular to current flow ?
    FIRST RULE FOR FREE ENERGY DEVICES :
    ENERGY IS ACCUMULATED IN CLOSED PATH BY INDUCTORS.It is done by SHIFTING phase of induced currents and force them to flow together in CLOSED PATH.
    • RESONANCE !!!
      • Niceone boguslaw will study
        • I think the NS works because you have two coils in different stressfields.
          YouTube - Think out of the BOX Primary Phyics
          • RadioActive
            The buried coil was also buried with pitchblende..
            Those of you that want to bury a inductor and get induction
            please keep reading and studying. The work of Dr Paul Brown.
            Is an excellent starting point.
            Paul M. Brown: Resonant Nuclear Battery (Nucell) ~ Beta Voltaic Effect
            Any Conductor hit with a beta particle causes an avalanche of
            electrons within the conductor, IF there is any voltage the
            released electrons add to the current that's already flowing.
            Now you will see the suppressed info is Radio-Action.
            A ionic breeze electrostatic air cleaner will collect fuel
            from radon and its daughters. If your in a radon zone.
            Who can light a LED with dust from it? Like this?
            From
            THE STUBBLEFIELD PAPERS
            What are the Radon Daughters?
            • Ive been waiting for this day I new it would come,
              YouTube - 15 Watt Tube Powered by Earth Battery!!
              YouTube - Earth Battery Joule Thief Lights 7 LEDs
              YouTube - Earth Battery Lights 100 LEDs
              I so happy
              Im trying to get the setup daigram from him If anyone is on the ou forum too can you please try and get the diagram.
              BINGO!!!!!!
              come on LIDMOTOR!!!!
              • Bill @ Pirate Labs
                Hi Bodkins, I have been watching Bill's work for quite a while and it is very interesting in what he has accomplished.
                It proves that you can pull power from the good Earth. My Garage LED is still shining on. It has been maintaining a voltage in the battery of around 3 volts for the past two months and seems to be remaining consistent with the end of all of the freezing and thawing in the ground considering that I live in COLD country. I do get a daily bump up in voltage of about a 10th of a volt that starts in the morning and ends about 9 pm. It has been several weeks since we have had a wave or tide of voltage come through this area. It is over due.
                Kingman
                • haahhaaa the led still going great!!!
                  Im trying to get bill over here but he cant sigh up because no ones signing up his account so he cant post !!!
                  Take Care
                  Bx
                  • Earth Battery
                    Hello everyone! I see some great work is being done over here on the EB's.
                    Thank you Bodkins for inviting me over here and helping me get the sign-up issues resolved.
                    I was going to post some of my latest videos here but I see Bodkins has posted the links for me. Thank you. There will be more coming. I am awaiting a 650 F supercap. I want the 3,000f cap but that is about $130.00 so it will wait for a bit. Once I get the new cap, I will make more videos.
                    This appears to be a nice site and I have seen many references to it all over the place so, there must be a lot of stuff going on over here. I look forward to posting. Thank you.
                    Bill
                    • Welcome Pirate!!
                      your arrival has been much anticipated..
                      i'd love to know how your earth battery is set up!
                      you said in one of your videos that you were using two carbon rods??
                      welcome to the community!!
                      love and light
                      • Originally posted by Inquorate View Post
                        love and light
                        Thank you for the welcome!!
                        OK the set-up is pretty simple. I bought a 1"OD X 18" long carbon rod
                        around Nov. of 2007. The ground was hard and the first tests I did were with the carbon rod only about 6" into the ground. I was still able to light an led. (small red one) The south side (-) used a magnesium fire starter block and the carbon rod was on the north side. (+) Later, I dug up the carbon rod and cut it in half. In those tests the rods were buried almost completely (almost 9") and wired together about 4 feet apart. I was able to light 3 small leds like that. I was also using a small supercap (.47F 5.5 volt) at this time.
                        So, flash forward to a few weeks ago. I dug up the carbon rods and washed them off. (No damage to them whatsoever) and re-planted them further away. I replaced the small fire starter block with a 5 pound magnesium block. (This is the kind designed to stop corrosion of steel tanks placed in the ground. It comes in a canvas bag filled with potash or something like that) The specs say it will give a 1 amp difference on a steel tank for 6-10 years. Since I am not using it in that way, I don't think I need to worry about replacing it.
                        My electrodes are now about 12 feet apart set on the north/south meridian. (Not magnetic north and south....potential huge difference between the two depending upon where you are on the globe) I have not yet fined tuned the angle of the bottom of the electrodes to match the magnetic dip angle for my area (about 35 degrees) but when I do, the output should be better.
                        I have a site that tells you this information for your area if anyone wants me to post it, I will dig it out.
                        I think i have a few other earth battery vids which I can post links to as well but, this is pretty much the set-up as you see it in the latest videos. I am using a modified Fuji joule thief circuit on some of the vids linked above. I am also using 2 10F 2.7 volt supercaps in parallel with each other and tied in between the EB and the Fuji JT.
                        If anyone has any questions, just let me know and I will try to answer the ones I can.
                        Thank you again.
                        BIll
                        • Eath Battery Light 48" Tube
                          YouTube - Earth Battery-Joule Thief Runs 48 Inch Tube (40 watts)
                          If I did this right, there is a link above to my youtube video of the EB lighting a 48" tube.
                          Bill
                          • a few questions
                            @ pirate -
                            "I have a site that tells you this information for your area if anyone wants me to post it, I will dig it out."
                            sounds interesting
                            tnx for the info.
                            ps, did you simply wrap copper wire around the carbon rod?
                            "I replaced the small fire starter block with a 5 pound magnesium block."
                            i take it this is the negative? i'm unclear as to how you used the magnesium block / firestarter block, and also as to why?
                            love and light
                            • I used 22 ga. stranded wire and stripped enough off to wrap around the carbon rod OD. Then, I tinned it and added a connector on the end after the loop. It fits very snugly on the rods. Yes, the magnesium is on the south side. I wish I had more area to place the electrodes really far apart as they say that raises the output as well. Here is the link that shows the magnetic deviation and dip angle for your area. (I have not looked at it in a while, it may just cover the US) ***EDIT*** I just checked and it appears to cover the world.***EDIT***
                              NOAA's Geophysical Data Center - Geomagnetic Online Calculator
                              • Inquorate used up all the great smilies in his welcome ...
                                Welcome Bill
                                I've tried lots of home made battery configurations, shapes, metals as well as rods in the earth.
                                I never had any or tried any carbon. Watching your video got me thinking
                                .. I have carbon now, in the form of charcoal that I've been making with my woodgas stove.
                                Yep, that carbon is good stuff.
                                I tossed together a couple of (non-earth/ground) cells and the amps are
                                really good compared to other cells I've made. Next time I'll use something
                                other than a fork to crush up the charcoal.
                                I will be trying some charcoal out in earth here soon.
                                I'm just wondering how I'd go about doing that.
                                Maybe drive a pipe to dig the hole, pack full of charcoal and then
                                drive a rod or copper tubing into that.
                                It would be a make shift carbon rod everyone can do anywhere at almost
                                zero expense.
                                just
                                Randy
