Cell Design 101
  • Cell Design 101
    So got some pretty basic questions for a cell design. Now if I'm using a neutral plate design with lets say -NNNNN+ and so forth, do you think there would be more gas production with less groupings and bigger plates, or more groupings with smaller plates?
    That's almost an impossible question to answer, especially without more specifics. When experimenting it is always best to change one variable at a time. That's the best way to learn.
      "as there can be seen - there is not big difference in efficiency if using more plates and greater active surface (biger hho gen), or very small surface (test with 6cells x1section) efficiency are arond the same. so, i hope to get better results after correct conditoning process"
      never mind found the answer
