Biogas Making is Easy
  • Biogas Making is Easy
    In WW2 people in england use biogas. i tryed to make some and its very easy.
    first light a fire put a airtite cotainer with one hope at the top for the gas to exit the best way is to have a metal tube coming from the container. put wood (i used sawdust)in the container and pressure will buildup and start coming out of the hole.steam first then biogas.
    after all the gas has been projuiced let it cool down open the container then you have some charcoal for the next one.
    easy!Gas
    also you now have the begining of a charcoal filter for the co2 from the gas!
    maybe it will be better to name it as "wood - gas" because "bio - gas" is also gas made from compost and farm waste.
    the wood gas is known to be as a fuel to for cars internal combustion engines. also some friends there in Latvia are driving cars by wood-gas, but this is not easy, there are lot of job to make good filtering, also good firewood is not easy to find, engine power are much less than with gasoline, etc.
    stationary station of combined heat and power generation, are also a good idea, using wood-gas. this way can be heated several private houses, or lighted and heated some large greenhouse (conservatory to grow plants).
    old car engines are not expensive, all other things can be made by oneself. this is very efficient way to use any fuel, propane, methane, or wood gas is suitable.
      sorry you right wood gas
