Imhotep's Radiant Oscillator Video
  • another thought is the importance of battery and cfl also are negative resistor
    in my test it run better with battery fully charge respect a a 12v 1,5 amp dc power pack
    • Originally posted by Aromaz View Post
      Thank you for that small piece of info. I have seen some writings about Viktor - The crazy scientist that made things fly. There is a rumor that he actually used a podium to fly? Though I could not (yet?) find any writings of people that witnessed his flights. Recently there was an TV article about him and how he started all after a honey bee encounter on mountain cliff..
      heres a fab page about viktor >>>THE NATURAL PHENOMENA OF ANTIGRAVITATION AND INVISIBILITY IN INSECTS AND THE GREBENNIKOV CAVERNOUS STRUCTURES EFFECT
      • Same one
        Thanks stringguy - yes that is the same I saw short while ago on TV documentary. Interesting.
        • Bodkins - Big sparks
          Bodkins, A bit late, I just looked at your video "Big Sparks"
          check your coil - the insulation 'bakelite' - it is possible (likely) that the insulation around the HV terminal is cracked. That is usually where you had problems in the old days - car engine not starting.
          • Dual system video on line
            Just uploaded new video - Original circuit BUT all new parts.
            Running in this video is dual set from one battery Now have 1x2222A, 1x3055 master and 4x3055 slaves.
            Meter tested and verified with Fluke at same readings. I only have two digital meters that can read this low. Multimeter on singe supply line from Battery positive through meter to transistor array.
            10 Mili Amp analog barely moved indicator.
            1 Micro Amp = 0.000001 Amp
            Run cool – on 12 MICRO Amp
            All together 5x 18W CFL, 1x18W Fuorecent tube
            Then second half I added battery in series pushing 24 Vdc
            Extreme bright lights and drawing 60 Micro Amp Same load
            Aromaz 017 – Dual DRE test run on 24Vdc
            YouTube - Aromaz 017 – Dual DRE test run on 24Vdc
            BUT BE AWARE: I am running on 24Vdc only for short period. 19.4 Vdc get to coil terminals - the coil is in effect OVERLOADING. After some 20 to 25 minuts the coil is hot and I can hear sparks flying inside - also lights get some real strong spikes. After about 30 minutes, frequency drops to under 30 hz and lights are flashing like disco.
              Magnificent – Absolutely fantastic.
              Very well done, clear and easy.
              You are a real gem.
              That was a lot of hours working there!
              Thanks for that compilation.
              All nice set in one single document from top to bottom.
              Thank you!
              Hi, Corrie
              Thanks for all your hard work, its now included along with Bodkins and lid's new stuff in there..Ren is next after we sort some bugs
              http://www.panaceauniversity.org/Tes...Oscillator.pdf
              Ash
              • YouTube - Bodkins 35 diode ground.AVI
                WHAT MORE CAN I SAY.
                Aromaz Looks Like you ARE resonance with the planet
                • Here is link I found that does look interesting Thomas Henry Moray: Speech at Valley State College, Northridge CA.
                  Especialy I was interested in this part:
                  "Oscillations by synchronization are started in the first stage of the circuit of the device by exciting it with an external power source such as the difference of potential between two points. The circuit is then balanced through synchronization until the oscillations are sustained by harmonic coupling with the energies of the Universe. The reinforcing action of the harmonic coupling increases the amplitude of the oscillations until the peak pulses "spill" over into the next stage through special detectors or valves which then prevent the return or feedback of the energy from the preceeding stages. These oscillating pulsations drive each succeeding stage which oscillate at a controlled frequency and which are again reinforced by harmonic coupling with the ever present energies of the Cosmos. That is, the first stage drives a second stage, the second stage driver a third and so on. Additional stages are coupled or until a suitable power level at a usable frequence voltage and amperage is obtained by means of special resonant oscillators."
                  Mike
                    Excellent work Aromaz ... just microamps for all those bulbs
                    I saw your video and did not realize you were a member here. I sent you a message through youtube requesting a circuit diagram to which you can ignore as you maybe posting it here.
                    I would like to replicate your setup and wanted to know if the transistors are just all hooked up in parallel?
                    Thanks for sharing
                    Luc
                      @mlurye
                      Thats brillant,
                      @Aromaz I also have diso lights with my setup looks like its feedback of the energy.
                      Yes it is the insulation is crap but its the back radiant energy because of the potential in the coil with the inverted setup it gos to the postive of the battery (make and break) its the biggest spark I get.
                      Im Working on new way of pumping stuff around,
                      Will rep your stuff and post soon too I need shades by the looks of it!
                      For tomorrow
                      • Aromaz, this is SOO amazing
                        So much light on this much energy input. Even if the system consumed miliamps instead of microapms, it would still be SO amazing. That means that you are lighting up to 100w worth of light using virtually no power at all. You could light this up from some AAA batteries Interesting that on 24V you get the coil to heat up, that is also a form of energy you know And I doubt that you could do this with microamps in conventional way.
                        Thank you for sharing.
                        Can somebody please send me a circuit for this or point me to the exact forum page where it is already posted? Thank you.
                        You guys have done an excellent job!
                        • [QUOTE=Bodkins;36932]@mlurye
                          Thats brillant,
                          Yes it does sound brilliant Sounds like Moray invented radio that is able to produce kilo watts of energy
                          Mike
                            There's a circuit back on page 43.
                            • Thank you slayer007
                              • Hi all
                                I tried Aromaz single coil setup with two CFL lamps, 4 transistors plus 2N2222 tonight and it fires up every time and I can smell the ozone and can draw long plasma like arcs. However my current as measured on my AVO8 analogue meter is around 150mA @ 24v = 3.6W. This current looks to be about what I would expect for the level of brightness I can get from the two lamps. I've tried reducing this with an adjustable spark gap but cannot get it lower without a corresponding reduction in brightness. Is anyone else having this problem? My earth only slightly increases brightness, so I'm wondering if the type of earth is very important in order to run the lamps like Aromaz at just a few microamps.
                                Hoppy
