Dear Aromaz,
......Please take care with your EYES!!!
......Your video 21 and 22 clearly indicates that you have run CFL
and long flourescent with 0.02 A. Is that correct?
Can you comment on Video 22? Will you continue with that route?
Nuri Temurlenk,
Istanbul Turkey
@Nuri, the rays are actually HV and radiant energy. In my last video #026 you will see much more about them.
If you mean low energy for lights - YES! That is my ultimate purpose for these experiments - and that of this specific forum thread.
BUT, I am still trying to figure out exactly how this whole thing operates and what are the forces behind it. Only when I got that covered, will I be able to make the light system near-perfect.
All observable effects are important without a detector available.
Oh Bodkins 41.AVI reveals sound has gone away when a cap is collecting?
Does this mean the sound is due to pressure or something like that ..
if given a place to hide out it stops making sound?
Was it just a fluke or does disconnecting the cap make the sound return?
Or does connecting a cap change the sound or does NOT change the sound
Both are another puzzle piece / clue and both could occur.
In Bodkins 42.AVI you Tuned it but the sound came back?
Does the whine sound indicate unused / untapped energy?
In Bodkins 43.AVI you say "I took the meter off .. proper bang!"
Yes, I saw a video, don't remember which one and I don't think it was on
this thread, showing that the volt meter WILL drain the cap, a LOT,
down to a level but not down to zero... it levels out.
At least that is what the video showed.
A couple recent published articles by the same author, one is very technical. The other not as much. These may have some interest to some among you.
Id like also like too thank all here for making this thread what it is. The dedication and comrade re is very lifting when so many other site are so full of flaming and disorganization. You should all pat yourselves on the back.
On another note has anyone tried to replace the copper stuff with carbon? Carbon plates are easier to get but polished carbon (graphite) sphere's are not that easy to find. From what I read of Tesla he found that carbon would eliminate sparking more efficiently and thus boost the radiant energy.
Will do burnt match and wood experiments tonight. The missus has been throwing up every night for the past 4 nights, nausea etc but feels perfectly ok every morning.. Um.
Yes well displayed. I had those same questions about the different
wires (?sources? no?) spark/color/sound you showed in the video.
That covered another area that required inspection.
Yes Yeppers , that snap-shot image was fantastic !! Pretty blue
Spark colors: white, very white, red (salt H20), blue, and purple
(and don't forget the sounds that go with each one and the source)
What's the part number of the scr you're going to use in this cap dump circuit? I think I'll have to find some online..
Ta.
@all - I said I'd draw up a data sheet/form for frequency measurement of these systems etc......
not gonna, computer died. column headings:
Date (GMT) / time (GMT) / time local / voltage (source) / amp draw (source) / frequency at hv ground / frequency of base of master transistor ground (if different ground rod) / frequency of multimeter or scope 1 meter from coil / cap dump rate from voltage divider /
Ps anyone know a good source of carbon? Ie for spark gap. I might pull apart a potentiometer... ??
