I will repeat the experiment (if the circuit will react in the same way again, you never know hehe)
and try doubling the salt like bodkins suggested.
Shortly before ending the experiment for today i have also put a water glass with sugar inside next to the coil and it seemed to have the same effect as the salt.
I also wanna see what happens if i use inanimate organic "material" instead of my hand to touch the bulb, for instance a piece of steak or so.
That would prove that the effect is dependent on a quality that only animate beings have/emit. (radiant energy field in humans).
I will ask my girlfriend when she will be around to touch the bulb too and see if there is differences between individuals.
The thing is that i have a 2nd degree in the radiance technique which is also called Reiki, so my hands automatically "create" radiant (healing) energy when i touch organic objects (according to the books) and this might influence the effect on the bulb somehow ,who knows? I want to investigate that possibility.
I remember luc pointing out in one of his videos that the injury that the radiant energy burned into his finger healed amazingly fast!
"Maybe the crystal became 'conditioned' like the transistors do"
Hmm, i am just pondering : "What if we become conditioned too?"
We will be quite "out of phase" for christmas ...
Or the aetheric field tuned itself to the crystal frequency and since these circuits swap frequencies periodically (like Aromaz pointed out) maybe the
frequency of the total field is a combination of all individual fields` frequencies that are involved in the experiment.
Anyone have a radiant fieldforce-meter?
...."Maybe the crystal became 'conditioned' like the transistors do" .....Hmm, i am just pondering : "What if we become conditioned too?" .....Or the aetheric field tuned itself to the crystal frequency and since these circuits swap frequencies periodically (like Aromaz pointed out) maybe the
@Xenomorph ; It will never seize to amaze me how everyone is thinking in different directions. More so is the fact that I am doing certain experiments - just to find one of you had the same thoughts.
Your experiment did make me think more of this than before. I did not realize that over a period of time the frequency will change to be 'not hand friendly' like yours! Will go set up for that imediately.
Earlier today; before reading here, I was typing a long reply to a message on one of my videos RE cosmic forces and effect of crystals on this energy experiments. Ohh. there is one part few of you could experiments with; and because I have two huge safes full of some 38,000 gemstones - I did and am doing; experiments in using some of these gemstones in a circuit. i.e. Tourmaline!
Now back to your experiment. Very well done! YES, any crystaline form will act on the circuit; any such as water and minerals in the water will change the resonance! Now try to what will hapen if you let the wire run through such substance either with or without spark gap.
It is not only the crystals - but also shape. Shape does have an effect. And before anyone start calling the shaman's - I am talking of real scientific effects are manifested in both material and shape. Keep that in mind!!!
Aromaz, talking about crystals reminded me of what I read about Tesla using all kind of jewelery including diamonds under his Aether "ray". Given the correct density of the Aether it just vaporized. Was in the cold war tech book btw.
I can afford to loose a few - of certain ones; but .....
Thanks for the warning, will have to be carefull with the 5 big ones!
Fortunatley I know already from crystalogy (and gemology) the most important crystals in electrical/electronic is standard quarts based i.e. Quarts, Amethyst, Citrine followed by Garnet and Tourmaline. Fortunately those are the cheaper stones!
And YES, Tesla..... Diamonds does have a tremendous high frequency - Normal white diamond oscillates around 120 GHz with Blue Diamond complete conducting and oscillates at higher than 600 Ghz (- because of Boron!). Ahh, but a good royal Blue diamond is only the second most expensive gemstone in existance today. Blood red diamond is the rarest of all and most expensive.
It all depends on the exact chemical impurities. Boron is also found in Tanzanite....which might be worth while to look into on later stage.
This I have only very few small pieces of!
A metalurgial thought and NOTE to myself: Should try mix Boron in with Ferrite and Carbon for coil core......
This crystal stuff takes me back to my youth, when I built my first crystal set with a coil, a crystal, and a cats whisker ( cats whisker......a fine wire you poked around on the crystal until you got a signal)
Batteries not included....weren't needed.....kind of a FE radio
I setup a spark gap with my sphere and the sparks got faster and faster i had to stop i got worryed.will video it when i can, i think it was the waves gentlemen. Surf Up
It's not pointless and you know it... Squiggly lines that don't change except for amplitude when the neon triggers the scr to discharge the cap, and periods where the neon lights for longer DOES look like periodic flowback into the system. Anyone who's ever sat on the beach and watched the waves on a rip come in and in and in then meet one going back out because of the rip would recognise that pattern.
Sorry to ask, know it's xmas and you've got kiddies, but when you're free and not so tired could you draw a complete schematic for all the voyeurs, I mean 'readers'?
remember my blog where I said if we time the intervals right we should be able to amplify the amplitude with the return of the impact wave? I think it's randomly happening in your setup.
Merry xmas to you and yours richard, and a great many thanks as always for sharing so much.
I've a friend in western australia who's very 'sensitive', and one in south sydney who's a clairvoyant. Both tell me to follow any urges I may start having to go north / inland (uphill) any time soon.
Could be sooner than we think before we start living in small villages. That's when this type of technology will be really very useful.
Carl
Ahh, now you gave your age away!
I did the same but gosh it was a good 40 years ago!
Can still remember the excitement when you tickle a sound from it;
and no battery. Late nights under the blanket so my father does
not hear me ...... Hey, can remember when I caught the Police band! THAT
was the best, all my friends always wanted to come listen to that.
YouTube - Bodkins47 waves back
carl 1200 volt 2mf she a big one
@Bodkins; NICE videos!
WHAT the heck are you doing to get that cycle of amplitude?
Stranger even is that it sems to bump all up at the same time Make your display time on scope longer to see if you have another running wave on the amp? i.o.w Get more cycles on screen. How long is that wave of increase/decrease amps?
This far I can not get the same. Your scope probably ignores the back EMF? So you only read the Amp and wave form that is on your normal generated frequency.
Now, I think what you have is that big one surfers are waiting for. I agree with Inquorate to look at the sea waves. I think you are catching a back EMF out of sequence. So what could be the beginning of a BIG one is if you can time a new pulse to hit exactly the same time that back rush comes - at its peak. Then you can start getting the playground swing effect and bounce the Amp higher with each hit.
It is also possible - and THIS would be my wet dream - that you somehow get an soliton running there. Soliton ignores all other waves! But then why does your scope not read it?
As you say: It's WEIRD - BUT it certainly is very interesting. That is why this tread is very far from over with. Than you all for the continues experiments, sharing and head scrubbing. One day we are going to put all these results together and we are going to see a very nice puzzle become a big picture.
Please Richard, see if you can post an diagram update for us? I am standing in the same que as Inquorate. Maybe I have a missed diagram or update from you. Iam now backtracking to see when my wheels turned away from your tracks!
