Imhotep's Radiant Oscillator Video
  • well i am over the 1hr 48minutes and nothing notable to report....maybe it takes longer in a smaller system....i will run it for a bit longer....otherwise i will add in bodkins modfications....
    • Nat's Mystical System
      I do not think you have to worry too much - yet. There are two possible scenarios to keep in mind.
      A: The coil might not be exactly the same.
      B: The auto conditioning' effect of just about everything.
      On Sunday I tested ALL my previously dead transistors - except for one that really smoked; they were all back to normal - and in 'like new' - but keep in separate box!
      With my scope and toroid modified probe, I find after running for one hour, the ignition coils are still resonating as much as 12 minutes after power down. Further, in older used (in circuit) ignition coils I get ringing much easier and persistant than in brand new coils.
      • That's funny...
        • Welcome back!
          Imhotep~**
          I see you are logged in! !! Welcome back.
          Trying to catch up is a real mission, I have been there, now I do make sure to read everyday.
          This is guaranteed the best forum and this group is the best co-operating experimenters anywhere on the web.
          Hope to see your new postings soon
          • imhotep
            @ Aromaz, I was thinking of doing the same thing.
            @ hello imhotep. Will be great when you catch up... Hope you have enjoyed all the mysteries
            • Bill Beaty - Crackpot or .....?
              A while back when my brain was still unable to understand much of this, I found, read and printed this article. Now going through old notes to clear out; I read it again - and Bright Lights Sparking!
              Though it is a hypotehesis; this is possibly a very valuable presenetation.
              I think this Author Bill Beaty is catching a tiger! At least somewhere, though some of his stuff needs a serious addition of salt.
              Bill B's Crackpot Theory the Second
              • Sound Frequency Analysis
                Hello,
                i have not been able to repeat the last experiment unfortunately.
                I have then added a spark gap, which produces really weak sparks.
                Seems like i have to run the circuit with 24 Volts or even 50 Volts like some of you or is this not the determining sole factor?
                Also i have not been able to get a drawer knob that is 100 % brass, they are all surface-brassed. Maybe in an antique shop ?
                Made an analysis of the oscillation that is audible coming from the bulbs.
                With the background of being a professional audio engineer, i have
                extracted some valuable information from a spectal graphical analysis
                of the waveform that allows some conclusions about the nature of the
                oscillation in this circuit.
                YouTube - FrequencyChange
                1. What we perceive as a ringing tone is a complex spectrum of individual frequencies.
                2. The higher frequencies (and that is remarkable) have partially higher amplitudes than the base frequency.
                For harmonics can be said: "Harmonics are produced by a rapid and abrupt rise in current, either in the positive or negative direction. Square waves and pulse waves produce a rapid and abrupt rise in current. The more rapid and abrupt the current rises, the greater the quantity, amplitude, and frequency range of harmonics produced. The abruptness of current rise is measured in rise time. "
                I will try to find out if that is actually really harmonics or 6 harmonically independent oscillations. It is hard to make out if the sound is being produced by all the bulbs, i had 4 CFLs and a neon tube in the setup, so it could match the number of frequencies in the spectrum.
                However when i touch the once CFL, all others light up stronger too.
                3. Upon touching the bulb, the spectrum behaves strangely, the base frequency rises but the upper frequencies fall
                See here:
                This picture shows the waveform where you can see the modulation in the changing amplitude:
                Assuming that there is a correlation between brightness and audible frequency, that would not explain the spectrum of the "touched state", where
                only the base frequency rises, but the others fall.
                Guess i will have to make more experiments with varying CFL quantities.
                I remember that Bedini spoke about a cancellation of two oppositely phased
                sine waves in one of the "energy from the vaccum" videos and he said that the hidden information lies in the modulated frequencies !
                So is it beneficial to the strength of the BEMF to produce as many upper frequencies as possible? That would be the key then and explains why
                a higher signal frequency to pulse the ignition coil yields in more BEMF.
                High frequent sine waves would not do that.So let`s try Giga-Hz pulsing soon !
                "Pure sine waves are not capable of producing harmonics because of the smooth and gradual rise and fall of the current."
                It remains interesting what Nat and Bodkins will find out in their wave surf experiment.
                Hope anyone finds something useful in this
                • spark gap in my system started to work at 36 volts minimum
                  • the upper frequencies are achieved by using polished brass spark gaps apparently.....as brass vibrates longer
                    according to oliver lodge
                    • Thanks for the info, i will look for better brass gaps then and incrementally raise the system voltage.
                      • @ Xenomorph; I am certainly very happy to see you here - we can do with more insight to the scope waveform analysis!
                        Solid brass is good, howeverI lately changed to 304 stainless steel. Gives same spark value - but the added hardness does not pit to easy. I only used up to 24Vdc on this system until now.
                        Unfortunately I will be out of action for a few days - has to stay on bed with knee problem. Please don't go too fast!! I would hate to do catch up again.
                        • Xenomorph good job with analizing sound. Moray got his idea from the sound in the phone. So may be we are talking about frequency < 15kHz. And about harmonics check the file that I'm generated RapidShare: Easy Filehosting, but in that case LC should be tuned to specific frequency.
                          Mike
                          • I get this error trying to download the file:
                            <<This file is neither allocated to a Premium Account, or a Collector's Account, and can therefore only be downloaded 10 times.>>
                            Maybe upload it again?
                            • One Wire Transmission | video repost
                              Both of these are powered by an Imhotep Radiant Oscillator
                              You can read the video details for details - I posted these before Imhotep released his circuit so I didn't want anyone to know. I just replaced the CFL with a spark plug.
                              YouTube - Single Wire Capacitor Charge (from battery terminal)
                              YouTube - One Wire Tesla Transmission
                              RPX & MWO http://vril.io
                              • Fried my transistors. Poop. So much for a whole day of experiments.
