johnny-come-lately
Bodkins and ...... Everybody.
Call me johnny-come-lately ...
I sorta figured that one out also, Bodkins, but I came to a conclusion.
I'm looking at my version of the Lidmotor "Small Transistor CFL table candle"
circuit, well .. a sorta kinda like that.
I don't have a regulator and I'm using a 6 volt source.
At least for the Candle circuit, an earth ground has nothing to do
with making the bulb light brighter.
One side of the bulb is connected to HV.
1) it doesn't always "get going" without a push
2) it is like a candle
3) without something connected to the non-HV side,
the whole bulb isn't lit, lites less than a candle and generally will flicker.
4) allows for Yes,No evaluation of what does and doesn't effect brightness of bulb
5) A carrot works not as good as an orange and not
as good as a finger for bulb's Ground.
I wasn't touching the carrot when it was working, but I touched the orange.
6) foil works as good as wire and as good as earth ground.
I took my earth ground which is network wiring (8 wires) used 2 twisted
together for earth and 2 not attached to the earth rod.
and a piece of aluminum foil off a 2 lb peanut can.
The bulb is equally lit for all 3.
For this circuit it isn't earth that makes the bulb bright.
How the non-HV side of the bulb works, it might not be a Ground
and I don't think it's an ANTENNA. It's more like a valve.
Forgetting all the other effects, blue,purple sparks, etc
and looking only at the lighting the bulb.
Let us say the only thing making the bulb light is HV, just like
you see here., except one side of the bulb connect to HV.
Something under pressure just sits there doing nothing but being
pressurized, in this case by HV. It is just potential.
You guys are seeing a bright light because you are pushing so much
pressure, more pressure equals more volume through the same size
hole. We all have the same size hole if nothing is connected to the
non-HV side of the bulb. Less source volts, less light with the same
circuit.
An Orifice with pressure behind it can only allow so much to past
in any even time. If you make the Orifice larger so more can flow through
it. Th Orifice, in the lighting a bulb, isn't a hole, but is surface area.
The bulb gas is under pressure by HV but only so much pressure can get out.
The volume that gets out equals the brightness of the bulb.
If nothing is connected to the non-HV side, it takes more pressure to increase
the brightness.
If the Orifice is widen via a wire attached or a piece of aluminum foil,
a carrot, etc. the brightness increase due there is more surface area to
release the pinned up pressure, more flow, more movement, more light.
That sounds like it matches what I'm observing.
I have not a clue if this idea has anything to do with reality,
because I'm a victim of my own reality like everyone else is.
At this low voltage you can see the gas moving in the bulb, but it's
like the spokes on a wheel. You can not tell which way the wheel
it rotating due to the observed movement of the spokes.
I see the gas (pulses) moving forwards and then backwards in both directions.
I'm still only an observer.
Just
Randy
circuit.
the brightness.
Just
Randy
