@dmonarch, Can you post a close up look of your relay? how many leg it has?
Imhotep's Radiant Oscillator Video
5 Pin
Hi xenomorph
What a bugger i just payed 13 dollars on a relay i cant use. I might see if they will take it back and let me get a replacement and get the one you mentioned. I hope it is not too dare. Though i think it will be worth it as this little unit will satisfy most of my requirements for further experimenation.
With the 5 pin unit you mentioned how do you wire it up for the radiant oscillator.
Hi Sucahyo
I wish i could post a picture however i dont have a camera, I really should get one. It has 4 legs however the insider of the unit is very different from the imhotep video showing the modification.
Damian
Hi Damian, if you can not swop, I can try to help you.
The relay you got - is it 12Vdc Automotive as used for main lights?
This one will have the same pin layout as photo above, never mind brand name.
There is also another 12Vdc relay wich I used in my video #002. Thatone had four small pins on one side, typical for soldering and two clip-in type of blade pins on the other side.
Else try to describe if for me in as much detail as you can - if you can not swop it out for a Bosch.Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
@dmonarch, inside the relay there is two leg that will make the relay turned on if it's powered. Then there are a pair of leg that will only connect when the relay is turned on. The fifth leg that you want to know is not one of them. It is a metal where the moving metal rest, if it isn't available, make one.
Moving leg rest
Yeah I think that this is the problem Sucahyo, my relay does have the rest that i saw in the video.
Originally posted by sucahyo View Post@dmonarch, inside the relay there is two leg that will make the relay turned on if it's powered. Then there are a pair of leg that will only connect when the relay is turned on. The fifth leg that you want to know is not one of them. It is a metal where the moving metal rest, if it isn't available, make one.
@Aromaz
The Tesla pancake flat coil is of no unique value when using in electrical applications. The pure and only advantage - I have seen this far - is in increased magnetic field i.e. electro magnet.
I think the biggest value of BEMF will only be obtained from a single long wire placed in such a way that the EM flux from one part does not have effect on the other part. In other words, wound it around your room and keep the windings far enough so their EM flux does not overlap. A coil will reduce BEMF.
In regards to Nicola Tesla's pancake coil and the following statement, "The Tesla pancake flat coil is of no unique value when using in electrical applications"------ In truth Tesla's unique coil when operated correctly has no conventional magnetic field as you know it, How can a single turn copper strap utilized as a primary produce a magnetic field of any significance? The magnetic field produced is a function of amp/turns so why use a single turn primary?.Yet Tesla's short primary could produce inductive effects of large magnitude in all open and shorted conductors in the vicinity. If you want to understand Tesla's world seperate the actions---- one induces and the other is induced and these forces need not necessarily be magnetic in nature. Understand what electricity and magnetism are in reality, If I want to know the extent of knowledge a person has aquired I need only ask one simple question---"what is electricity and magnetism"?. If one understands what these forces are fundamentally then they can harness these forces to produce any magnitude of power they may require. Another question we should ask is how can we understand complex electrical machines without first understanding the fundamental forces which drive them?
Keep up the good work guys
ACLast edited by Allcanadian; 01-22-2009, 05:28 PM.
Originally posted by Allcanadian View Post@Aromaz .........
I found often when using the correct scientific terminology confuse simple minds like mine.
So when I do get to understand something, I am trying to convey that understanfing in
a set of words that could make sense to the person it is aimed for, using
his words.
This is probably enhanced by the fact I have been in non English Asia for past 9 years and communicating (lowered quality words) here is more based
on ‘concept’ and reading body language rather than actual words;
Using that persons ‘concept understanding’ to explain for him.
I failed by using ‘magnetic’ rather than ‘motive’.
In true definition: Back-EMF is a voltage that occurs in electric motors where
there is relative motion between the armature of the motor and the external
magnetic field.
What we are in true referring to in this case is Counter-EM(motive)F;
you are 100% correct.
In fundamental forces Electricity and Magnetism is a single force only;
Electromagnetism where the other three are weak, strong and gravitation.
I do think the true effects of that pancake coil will only come in with extreme
force, like the disruptive force used to propel / shoot subjects with HV pulse.
It is also possible that that enhanced effect will be with emisions of electrons.
Tesla’s primary: Yes, magnetic is weak but free electrons are high.
Still in much of these, Tesla had a better understanding than us 120 years later.Last edited by Aromaz; 01-23-2009, 01:03 AM.Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
? about solid state driving.
I have setup my lite with a BR on the low voltage side of the cfl. i have noticed that the when i switched from a relay driver to a bifilar coil and transistor self oscillator that my ign. coil reasonates and my charging shot up a bunch while maintaining a similar light brightness.
I also noticed that when i tuned my circuit to max charging rate that my amperage draw went down.
Has anyone else seen similar results? when using the "soldi-state bedini" as a driver?
BTW: i am using an air core coil the plastic spool is a 1lb solder spoon with a 3/4" bore.
Matt
Originally posted by Allcanadian View PostFirst we must use the correct terminology, an applied voltage is "EMF"(electromotive force), when the applied voltage is removed from a coil an inductive discharge will be produced. This is not Bemf, Bemf (back electromotive force or counter electromotive force), is an opposition to the applied emf which occurs "before" the current has been disrupted, the inductive discharge is produced after the current has been disrupted.
positive BEMF = BEMF, negative BEMF = inductive charge? or the other way around?
Can anyone having scope replicate this?
YouTube - How BEMF happen #1
Originally posted by redeagle View PostI also noticed that when i tuned my circuit to max charging rate that my amperage draw went down.
How do you measure max charging rate? If you make it faster, I also experience reduced amperage draw, but charging amp also reduced too.
Higher frequency = reduce amperage draw = reduce charging amp, most of the time. Reducing frequency bellow optimum will result in INCREASED amperage draw BUT REDUCED charge amp.Last edited by sucahyo; 01-23-2009, 07:48 AM.
@Bodkins, what this video about?
@All, about bifilar coil:
Originally posted by http://jnaudin.free.fr/html/scalwfaq.htm> Can you clarify, in terms of "superposition", what the difference is between
> the above and a bifiliar coil, or a magnetic or electrostatic bucking field
> achieved with paired coils and capacitors respectively?
This difference was the subject of a fairly long running discussion here
some months back. The thread was somthing like "differences in the
field(s)...".
Basically, if we take two conventional coils, and connect them in
series, but orient them such that the poles of the two coils are in
opposition, what is often called 'bucking fields', we will find that the
total inductance is greater than that of a single coil. The total
energy stored in the fields of the two coils is not significantly
effected by their orientation, and the system is highly inductive.
All we have done is to distort the flux, we have not canceled ANY flux
at all.
On the other hand, if we were to construct a bifilar coil with exactly
the same ammount of wire, we would find that the coil had nearly no
inductance at all, and stores no significant energy in the form of a
magnetic field.
Some have argued that the field is still present, even though the
current through such a coil reaches E/R in a time limited by stray
inductance alone.
but when we interrupt the circuit, such a coil return NO energy from
this supposed field.
In this case, it appears that we have actually canceled flux, that is
the flux from adjecent bifilar windings has undergone true
superposition, or added algebraically to essentially zero magnetic flux.
Note that when we deal with whole poles of permanent magnets, or
conventional coils, this NEVER happens.
This apparent difference in magnetic field behavior is not a matter of
physical scale as some had suggested, as the bifilar coil simply does
not store, nor return any energy as an inductive coil does.
Kick Back
Cheers for that Bodkins. I am as confused as ever now . I will hopefully get my unit going tommorow. I obviously need some hands on experience. You are a wiz at this stuff. Cheers
Originally posted by Bodkins View Post
