Imhotep's Radiant Oscillator Video
Parts values on 555 circuit
Originally posted by Philosopher View PostSome questions: What is the values of the capacitor you put between the two diodes to protect the transistor?
What is the resistance values of the induction coil?
What is the actual consumption of the circuit?
Thank you!
This circuit current draw is about what Bodkins Bedini Fan circuit is---About 100 to 150 milliamps at 12 volts. That is what I really like about it. The light intensity is not very good but with multiple bulbs we might be able to get around that. I added a second 2N3055 to the circuit to handle the current/heat situation and also added a heat sink. Trying to fit it all in a small box now.
Cheers,
Lidmotor
555 timer CFL light ---"Mini Boxed"
I put the 555 timer CFL in a little box and set it up like Imhotep did with the light mounted right on top of the box. I changed the circuit from my last posted video. For this application I eliminated the earth ground and the large energy recovery cap and just went back to a charging battery setup. Its a cute little thing. Gets hot if you run it on high brightness too long but on normal dim light it just cruises along. I did not mention it in the video but I also added a second transistor to help things out.
YouTube - Mini Box CFL Light
Cheers,
Lidmotor
Bodkins,
YouTube - Bodkins 4 lamp trick!
This one is awesome! Lets me think of a children's show in one moonless night far from the city's "light pollution". Very entertaining. And you eliminated the mechanical switching just by touching bulbs. Continue brother, the whole planet is watching.
YouTube - BEDINI IMHOTEP BODKINS REPLICATION UPDATE5 RADIANT ENERGY TE
still getting shocks through the insulation every now and then....quite strange
Time is on our side
I can get the effect without the scope connected to the setup. Natwas right the negative/earth can be a battery,we have it in the setup already
Lidmotor@change your ground to a insulted Metal!
Thanks everyonefor helping Philosopher.
keep it up!!!!!!
if i can help i will
i'm not sure what to make of these insulated plates...the other day i mentioned they sort of make a resonating sound when i touched them....but i guess it sort of sounds like a low level hissing sound......tesla's etheric gas maybe
i will see if i can capture it on video but it is pretty low levelLast edited by nat1971a; 09-28-2008, 09:58 AM.
Originally posted by nat1971a View Posti'm not sure what to make of these insulated plates...the other day i mentioned they sort of make a resonating sound when i touched them....but i guess it sort of sounds like a low level hissing sound......tesla's etheric gas maybe
One thing i think we need to checkout is putting a motor across the sink cap/battery!
i have already tried the AC fan....but hey i am a junior and dont know what i am doing.....so give it a go....
yeah i got a shock from the plates yesterday....quite a strong one at that....really weird stuff....Tesla does mention the shocks...having to use 2 inches of insulation
Originally posted by nat1971a View Postyou should insulate those rods of yours and connect them to the negative of your ignition coil and connect to a different ground
will be moving my pump to a new location with no national grid input or grid near by.hope to light the night sky from a 9volt battery!!!!!
your right the energy i get is weak for the rod because they are only insulated from the earth on one side.
If boxa gets on the job i think he will replicate everything in no time and move us forward in the understanding of the collection.
playing again cant help it!!!!!
