Imhotep's Radiant Oscillator Video
  • Originally posted by nat1971a View Post
    i have already tried the AC fan....but hey i am a junior and dont know what i am doing.....so give it a go....
    yeah i got a shock from the plates yesterday....quite a strong one at that....really weird stuff....Tesla does mention the shocks...having to use 2 inches of insulation
    dont now what to make of the shocks your getting.
    how do your tune it. is it in the key of B.
    i think you need a amp draw meter for the low levels to do a lightup amp down test.
    also thinking of the imhotep fan over the caps. maybe what imhotep was doing with the box he buildt
    • Table Lamp & Fan
      I'm still working on the 555 version. I stuck a little fan on the box today ( not changed to Bedini circuit yet) and made a video of how I want the situation to end up. It is almost identical to the way Imhotep decided to arrange things. I will get back to the earth ground and multiple lights after I finish this up.
      YouTube - A Lamp and Fan ---Lidmotor Style
      Cheers,
      Lidmotor
      • Everyones doing such a great job. its hard to keep up with all the updates. Lidmotor has probably the smallest version I have seen yet. Ive been working with some magnetic projects involving the circuit (more free lunch) Will be post when I have it completed. Been sidetracked But Imhotep will return. Super work everyone
        “Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
        Nikola Tesla
        http://www.imhotepslab.com
        • Originally posted by **~Imhotep~** View Post
          Feel like the teacher been in to mark your work
          Imhotep
          http://www.youtube.com/watch?v=H0l8imThtvc
          • ok i tried the insulated plates in the middle of cfls and two lights went out and when i touched the pot it gave me a shock.....
            am now trying different capacitors instead...using my original config.
            • it best to stick to what you now works and go for there nat.
              im down with the flu so im offf for a bit
              • Safety measures
                Hi folks,
                Thought i should mention some safety measures with this system.
                1. dont touch the insulated plates while the system is running as you will most likely get a shock
                2. discharge the capacitors when you turn the system off. This makes the circuit safe to handle. Or to use non-polarised capacitors which disipates the energy the instant you turn it off. Thus making the system safe to handle also.
                if these measures are adhered to i haven't been getting any shocks. One can tune with the pot and rheostat
                cheers
                nat1971a
                • Hmmm
                  I have been driving 2 ign coils in series with the output from my Bidini fan energizer using 24 volts in oscillation.
                  I get the most light from 4 cfl's tuned to the lowest freq with the resistance turned down to zero.
                  They are the brightest yet.
                  Carl
                  • yep thats what i am doing.... resistance is zero...no tuning required so far...tuning it makes it worse from what i can see
                    • YouTube - BEDINI IMHOTEP BODKINS REPLICATION UPDATE6 RADIANT ENERGY TE
                      Tesla's radiant energy patent explained.
                      • Sherlock Holmes
                        Great research Nat
                        I feel like Waston watching Sherlock Holmes!!
                        • Hmmmmm
                          Nat, Bod,
                          As I turn my pot down to zero, the neon, lights, indicating excess unused energy.
                          Of course the frequency of oscillation goes down with the lowering resistance, all the while making more light.
                          I have long had the suspicion that lower frequency would make more light, as an ignition coil is running at 330 cps when the engine is turning at 5000 rpm (8 Cly). I'm getting up wards of 3000 cps in my Imhotep testing. Too fast for the poor coil.
                          Carl
                          • Spheres
                            Nat,
                            Do you think the spheres could be fabricated by tacking two cheap stainless mixing bowls back to back?
                            Carl
                            • Originally posted by hh1341 View Post
                              Nat,
                              Carl
                              Thats what im trying to make it out of, tesla only has half a sphere in the springs build,
                              Your right on the lower freq. better light and better collection in the cap nice one
                              Got another strange effect with the spiral bulb today, got it on camera will post video tonight!
                              • Parts
                                BTW......I'm getting good results with a 1 uf cap, out of a scrap microwave, placed across the +/- of 2 series connected ign coils.
                                Carl
