Imhotep's Radiant Oscillator Video
  • byjoveoldchap:
    Thanks for this important information. I always admire your inputs in this forum.
    • Electric smog
      Originally posted by Hoppy View Post
      Great demo showing the electric smog we all live in! Just imagine if we could somehow collect all this stray radiated EMI and re-use the energy.
      If we were living in a world where the power grid was wireless, Tesla fashion, just imagine the opportunities for robbing the power companies by tapping free energy!
      Hoppy
      Hoppy, byjove, Nat, and Bodkins,
      Gotoluc sent me this video of a guy who is working on a similar project. Luc tells me that the guy will soon be posting results of a device to capture the energy coming off high power electric lines. Byjove-- my sailboat mast is about 40 ft. tall but aluminum and not a good choice for the Bedini experiment. Hoppy I am going to try to capture that 32 volts into a cap and maybe feed it back into my lunch box. A free lunch for the lunch box? I'm wondering if I can use Nat's and Bodkin's SCR idea somehow.
      Here is the video that gotluc sent me:
      YouTube - Free Energy " One of a Kind Device "
      Cheers,
      Lidmotor
      • byjoveoldchap
        @byjoveoldchap
        You made me a secret toilet checker!!!!!
        Great idea will get one and try it out.
        it should work with my setup
        SET OF 2 STAINLESS STEEL GARDEN SPHERES RRP £35.99 !! on eBay, also Water Features, Ponds Water Features, Garden Plants, Home Garden (end time 15-Nov-08 07:25:12 GMT)
        • Voltage next to power line..
          YouTube - Free energy test at home.
          Interesting what this guy is finding...
          See my experiments here...
          • Escaping Electricty --CAUGHT !!!
            I captured the energy coming off the top of my Lunch Box Lite today and put it in a cap. I used the Earth ground with the pie pan antenna sitting right on top of the box---and it worked---over 100 volts came out !!! Right through the plastic lid. I then took a neon bulb and used it as a pulser and that also worked. Now the question is how do I get the escaped juice back into the box where it came from.
            Any ideas?
            Here is the Vid:
            YouTube - Escaping Electricity -- CAUGHT !!!
            Cheers,
            Lidmotor
            • Hmm
              Any ideas?
              Here is the Vid:
              Cheers,
              Lidmotor
              Could you line the inside of the box with aluminium foil? then use a 3 prong plug to goto ground that way?
              Just a thought.
              • theremart:
                Thanks a lot for the link of the video. Very interesting indeed. I have this actually on my notes but I was thinking of using a kind of a yagi antenna which is far more expensive than what is on that video. I think this can even be tuned-up to maximum resonance depending on the material used in capturing the "leakage".
                Lidmotor:
                Thanks also for sharing all your findings.
                To all the Experimenters:
                Thank you all. I have found a paradise here. I see a very bright future for the next generation to come with the kind of people you are, sharing and inspiring others of what good we can do to this one common planet we all have. Thanks everyone and don't forget to sleep too
                • well done lidmotor!!!
                  • Cooooolllllll Lidmotor
                    All@ist great to be part of something bigger than the self!!!!
                    And i sleep like a bady now!
                    Quote
                    Any ideas?
                    Bridge Rec. to
                    + and - ignition coil?
                    + and - primary battery?
                    watch the video again the ampdraw hardly moves when you switch the light on!!!
                    Peter was Right!
                    • Hello all I am new to this and i will post pics and try a vid latter . Think i should start to tell u how i am set up. Bedini multi-coils . 3 transistors ..the transistors are wired for 4 but only useing 3 ..the 4th place is to try things . the Bedini coils are 2 bifilar coils .1 coil to the 1st transistors.2nd coil all power. to transistors 2 and 3.
                      The ignition coil is wired as followed in to the Bedini multi-coils set up... + goes to the collector on the 3rd transistor.. the - is going to the - of the charge battery. the power or middle of ignition coil going to the CFL the other wire from CFL to the negative to the emitter side of primary battery . 2nd CFL useing 1 wire ... from the first CFL power or middle of ignition coil .the other to stainless mixing bowls two of them two make a sphere .14 inch. I am allso seeing AC every were. u will find u can see it allso on your digital multimeter useing 1 prob . single wire transmission . seams what ever is connected in shows this . even the batterys . AC . try even a battery not in the cuircit from your stainless sphere one wire . will become part of it now .. looks like this will keep growing. if we knew more about this we could link all are setups together A big thx to all hope this helps out and sorry if i use worng terms for things
                      • Originally posted by carmine View Post
                        Hi carmine
                        Looks like your up to speed to me!
                        cant wait to see the pics and video dont forget a setup drawing
                        Aboard
                          Carmine, glad you came in to join us
                          "I say that if a TEN year old can do this and win, what the **** is wrong with the whole World?"
                          ~ John Bedini ~ 8 Mar 2000 - http://www.keelynet.com/bedmot/bedmot.htm
                          • Tesla's kiss
                            • "How I Packed A Free Lunch Into My Lunchbox" by 'Liddy the Wizard'
                              Lidmotor
                              Your amazing Lidmotor!
                              I hope you're keeping notes, because I can see a book coming out very soon
                              Well done!
                              • Thanks
                                [QUOTE=byjoveoldchap;31070]Your amazing Lidmotor!
                                Well done![/QUOTE
                                No book in sight but there is a can of worms that I am into. This radiant energy thing is wiggling around in my hands and I'm trying my best to understand it and get it on the hook. When that neon bulb lit up yesterday and started blinking that was the first time that I really saw it. Now that I have the worm in my hands the question is what to do with it. Peter--You probably understand all of this but to me it's like Christmas morning. New toy!!
                                Thank you to everyone here for the support and to everybody new and old --- KEEP WORKNG. I think that alot of people are watching us. Look at the thread views counter.
                                Lidmotor
