Imhotep's Radiant Oscillator Video
  • Originally posted by nat1971a View Post
    YouTube - BEDINI IMHOTEP BODKINS UPDATE9 RADIANT ENERGY - WIRELESS RAD
    mini update wireless transmission without charging battery
    is the receiver oscillating too Nat, in resonance to the first spherical electrode. identical frequency and opposite phase.
    and you say some bulbs not connected to anything! would be interesting if you give them a ground to flow too!
    • Hi!
      Great job Nat and everybody else here! I think with the right theory behind the results will come 10 times faster.
      I just wanted to touch base and could tell you that Meyl made an experiment with microwave frequencies and capacitors. As we are talking about dielectric discharges from the capacitor(s) try to sheet it with some silver or other good conducting metal. I think he got about 5 times better Q value with a good silver sheeting to stop the potential vortices(dielectric current) from leaking away.
      Remember, everything is inverse. For hot current we insulate with dielectrics to stop leakage of Eddy currents, for dielectric currents we should invert this. So use a conducting sheet for better results, good luck!
      Maybe it will not work but logically it should.
      Another thing to check is the 1-wire system and the dielectric wires with nodes for perfect transfer. Meyk believes the MT will be dangerous for ecology and photosynthesis longterm. And after reading his book you will not microwave anything that you eat - ever again....
      • @ALL
        RE: TESLA's TRANSMISSION OF WIRELESS RADIANT ENERGY
        ok i will try and put my own theory to this based on what Tesla has left behind....but you have to keep in mind that i dont have a background in electrical anything or electronics. So here goes
        An extreme high frequency positive potential is rapidily repeatly created and then stopped in the transmitter circuit which then creates a pump via the insulated high polish stainless steel sphere (the theory that i have read so far suggests that it (the sphere) is creating a vortex that is resonating with either the ether or with light or both)...which then pumps in more energy from the environment.......via resonance (of the ignition coil) this positive potential is transferred to the reciever ignition coil...(as i dont have a ground connected to the transmitter)......once this positive potential is in the receiver ignition coil this then sucks negative energy from the ground via my aluminum ground connection.....is stepped down...(i assume this steps down the frequency)...this energy is then available to run lights & motors....which is my primary goal......
        The higher the voltage input the more energy you will extract from the enviroment as the pump will be working harder (more efficiently)...
        Tesla wanted free energy for everyone.....well here it is folks.....it has taken me 3-4 years to understand it all....having no clues about electricity or electronics or what Tesla was saying...Just had a burning desire to stop paying electricity bills....The world can not continue the way it is going. Huge change is required and this will make it happen.
        Please replicate as fast as possible!!!!
        P.S This is basically how Tesla was powering his boat and probably his car (refer Tesla patent 613 809). Notice the transmitter in figure 9. Not sure what the batteries on the boat are for but they are not for running the motor that is for sure
        • @bodkins / ALL
          RE: TESLA'S WIRELESS TRANSMISSION of RADIANT ENERGY
          The receiver circuit is basically as shown in the patent. An insulated sphere connected to an identical ignition coil with the negative connected to ground. The positive and negative terminals are connected to the light.
          The transmiter circuit is basically as shown in the patent. Using the same circuit we have been working on but with no ground and no charging battery...and a insulated sphere. And no CFL's connected.
          The insulation on the sphere is the key to it all.
          So the parts you will require are:
          2 x identical hollow high polish metal spheres insulated with clear arcylic paint - 3 coats. Mine are 8"
          2 x ignition coils the same model...any model
          1 ground connection. (maybe 2 if you build your own coils or want to experiment further)
          The theory that i have read advises that the shape of the sphere is important. The stainless steel ones are the cheapest. I recommend you purchase them rather than trying to put some thing together. The sphere is found everywhere in nature.
          • Many THANKS to everyone here...the future is suddenly looking much brighter again.!!!
            See the EXCITEMENT COMING!
            • @gauss
              i am not sure what you mean by "sheet it"
                Nat read your messages
                the future is teslas so smile all the time
                everything is going to be fine
                we are working to a goal and that goal is freedom for all
                Thank for all the work you are doing if you where not here i dont now what i would do you a very important person to me
                by the way i was born in 1971 too
                37 is a good number dont you think
                @ALL can someone tell me what a eddy current is?
                fly like my bulbs too.
                • Thanks Bodkins,
                  Just got to fix my circuit now. Not sure whats wrong with it. I swapped out the transistor. No difference. Starting to look like the fan is busted.
                  Interestingly there are a few dead flys on the spheres...Tesla mentions this in the colorado notes....another piece of trivia for ya.
                  If we all work together we can win. (sounds like russell crowe in gladiator)
                  Nat
                  • Absolutely Amazing
                    " A very effective battery conditioner / charger should be possible at low cost by modulising to increase power. "
                    Hoppy, Thank you for sharing results of your experimentation. I see this relay charger as the most practical/low cost item right now and it can be found anywhere in the world and can be built even by people who even have no idea what an "Ohm's Law" is.
                    " Agongon--I like your new circuit diagram. I'll have to try it. "
                    Lidmotor, Yes Lid, that's precisely why we are here. We try until we all succeed. The world is our laboratory and humanity is our inspiration. Goodluck to all your experimentations.
                    " And after reading his[Meyl] book you will not microwave anything that you eat - ever again.... "
                    Gauss, Thanks for this info. I am reminded again and my community.
                    " ABSOLUTELY AMAZING ~ and only using 8mA...!!!"
                    byjoveoldchap, Wow, considering its size. This relay charger is something that's worth experimenting more, cheap, only 4 parts basically and you have the system running...and parts can be found easily anywhere in the globe.
                    Imhotep in his web site Imhotep's Lab Interactive FAQ • View topic - Oscillator Spikes showed the high voltage spike that is truly amazing. Lidmotor in his video showed his tiny solar power cell powering his relay.
                    " I do want to spread a word of warning the back rush of energy is much stronger than that of the fan or the IROL, so please exercise caution. It will give you a good buzz."---Imhotep
                    Indeed, the imagination(creative power) is the limit. Goodluck everyone
                    • Visualization on your haven’t actualised is very good to my eyes!
                      Agongon, I think Bodkins needs a slap
                      "I say that if a TEN year old can do this and win, what the **** is wrong with the whole World?"
                      ~ John Bedini ~ 8 Mar 2000 - http://www.keelynet.com/bedmot/bedmot.htm
                      • "The sphere is found everywhere in nature."
                        @bodkins / ALL
                        nat1971a said,
                        "The sphere is found everywhere in nature.".
                        Yeah........ even in the Loo...!!! chuckle
                        ( oops! sorry )
                        • Hi!
                          Regarding the sheeting of the capacitor that means a very thin layer of silver above the dieletric plates of the capacitor to limit the vortex losses.
                          New idea: try to rotate your sphere on the roof. Second idea could be to put a helical part inside the sphere so you have one primary receiver and then the secondary is the helix where the dielectric current really becomes massive(read free energy secrets of cold electricity by Lindemann, really good read AFTER Meyl). As far as I understand counter rotating vortices are the building blocks of the universe. A sphere rotating slowly and the helical inside rotates quickly in the other direction. Compare with the Wimshurst machine, counter rotation is the key and only one direction will work. Maybe you could attach some wings to the sphere and use the wind to get rotation. Just an idea.
                          How about a wiring diagram Nat?
                          • HV Fan Transformer
                            I just want to share my findings. The attached photo has details. I haven't put to use the voltage spikes yet.The nameplate of the fan says that it uses 300 mA[0.30A]of current as per original configuration.
                            • "...the relay contact giving fast leading edge pulses "
                              Originally posted by Hoppy View Post
                              I have tried out the Imhotep relay radiant oscillator and can run it down to around 7mA with the help of a magnet on the opposite end of the relay pole piece. The type of diode makes a lot of difference and I found that a UF4007 worked a lot better than an IN4007.
                              The charging is good for such a low powered 'buzzer' type oscillator and I could see no spark damage to the contacts over a long period of running.
                              This is a Bedini SG style charging circuit with the relay contact giving fast leading edge pulses resulting in good radiant energy production. I think that this circuit could be paralelled up to produce a more powerful charger.
                              Another observation is that charging can be improved by increasing supply voltage with virtually no change in supply current and no sign of contact arcing even in a darkened room.
                              Hoppy
                              Thankyou Hoppy and Agongon and everyone here for your input.
                              Every reported observation helps others to discover more!
                              • Circuit diagram for Tesla's wireless RADIANT ENERGY transmission
                                Circuit diagram for Tesla's wireless RADIANT ENERGY transmission using imhotep fan & CFL's and according to Tesla run motors
