That is well done and interesting, did you test to use a permanent magnet across the spark gap? Result?
Imhotep's Radiant Oscillator Video
I tried putting a spark gap together on the weekend...but having no experience with them....i probably did it wrong..as i was getting no sparks.....will look at it again this weekend....as well as some different grounding solutions that tesla mentions....
Originally posted by Gauss View PostAnyone uses the pancake bifilar transformer coils? Should make a big difference. But watch out if a thunderstorm approaches...
yes we need to get the spiral up and runing BUT first watch this bloke it great!
hi guy's better result if you connect the negative pole of the charge battery to the negative pole of source battery like the Gray circuit
Efficient power supply suitable for ... - Google Patents
i think overunity at the right frequency
bye and sorry for my english luca
The power of resonance
Ground resonance can occur in model helicopters, full size helicopters and everything in between. Resonance in flight is typically not encountered because the mass of the helicopter does not encounter external forces to excite the oscillation. In flight divergent oscillations are quite possible and have been documented. Prediciting ground resonance is difficult but possible. Reference the NASA Langley Technical Report Server and search for "ground resonance" for further mathematical analysis. Ground resonance is mitigated in full size helicopters by employing the use of damping vibration isolators to attach the landing gear to the airframe. The dampeners are tuned to absorb energy at the proper frequencies of ground resonance and typically can prevent this destructive event
YouTube - Ground Resonance - Side View
Well done but the secondary should be wound like a cone, remember the vortixe counter rotating! But a good start is the pancake.
Originally posted by Bodkins View PostYouTube - Pancake spiral tesla coil first fire
Originally posted by Gauss View PostWell done but the secondary should be wound like a cone, remember the vortixe counter rotating! But a good start is the pancake.
And how good been the Results??Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
YouTube - TESLA'S RADIANT ENERGY WIRELESS TRANSMISSION - UPDATE 11
Update 11 - surges in circuit....
Tesla's Radiant Energy Wireless Transmission - Update 11
Originally posted by nat1971a View PostYouTube - TESLA'S RADIANT ENERGY WIRELESS TRANSMISSION - UPDATE 11
"I say that if a TEN year old can do this and win, what the **** is wrong with the whole World?"
~ John Bedini ~ 8 Mar 2000 - http://www.keelynet.com/bedmot/bedmot.htm
