With the Schumann resonance, I believe 7.83 hz is actually the average and that it can be +- 4hz so from around 4hz to 12hz or so...basically the same as the basic brainwave ranges.
There has been talk a long time of the Earth field weakening but speeding up in frequency up to 13+...has anyone seen this documented by actual science?
maybe I'm being controversial, but just quoting tesla. And who said longitudinal compression waves travel at the speed of light? Tesla says the natural medium behaves as an incompressable gas.. incompressable.. push a bit here and another bit has to move instantly, regardless of how far away it is.. Time delay of .08484 might be due to less aether present in mass than in vacuum. Or electronic field of earth 'bending' straight lines of aether. It's my opinion that aether imparts motion to mass towards electric field direction. Hence gravity and inertia.
Ps 555 timer doesn't oscillate fast enough to keep wavelength of compression short enough to get high output in receiving coil.
About the weakening magnetic field yes I have read a lot about it and the imminent pole shift that people speculate about. How about the weakening magnetic field due to the stronger solar radiation during the last 20 years? The rising temperature and more volcanoes have reduced the HHO inside the planet.
The HHO magnetic field balances the solar radiation, one or the other is dominant regulating temperature up and down. And when the sun is too strong and melts the north pole a massive hurricane(two counter rotating vortices just like a jet crossflow CVP) sends 120 metres of ocean into the skies(at the same time as the other vortex drills some freezing stratospheric parts into the ocean), the water freezes instantaneously and falls down at our heads(3 miles of ice, imagine not a bug will survive this north of Africa or Mexico latitudes). Trigger point: 26,5 C surface water. Breaker: when there is ice everywhere. Terracycles - not perfect but good explanation.
Then we start the heating process over again with new species around due to all the radioactivity going on.
Implosion engine, that is what we need to start building, just like Schauberger said. And our circuits in here with pulsed HV to solenoids etc they are just the miniature spitting image of a hurricane, the hurricane also has a frequency and a magnetic field and a very high potential. All parts included.
Considerring my theory about HHO below ground(at 4C - just like Schauberger predicted...) responsible for 95% of the earth magnetic field, imagine the crust getting thicker by neutrino conversion year by year, what will happen when HHO is "finished" inside? How is H and O produced at the beginning of a planet΄s life cycle? We know they can convert into any other material by implosion(ie HHO welding) but how do you produce O and H? That is a key question.
"Water does not have the characteristics of the living, but without water there is no life.......
Water does not have the.....expressions of life ( growth,fertilization, reproduction, metamorphosis, nourishment,metabolism and so on), but these all only become possible through water........
What is it that enables water to accomplish this?
By renouncing every self quality it becomes the creative substance for the generation of all forms.
By renouncing every life of it's own it becomes the primal substance for all life. By renouncing every fixed substance it becomes the carrier of all substance transformation. By renouncing every rthythm of it's own it becomes the carrier of each and every rthythm."
Theodore Schwenk
I got back today and was resetting all on my fq generator when last 555 smoked; replacement 157 km far! Thus I tried something different, anyway not too happy with weak 555 circuits. Then I got some strange actions and readings, so I started unplugging and pulling out from breadboard until only this relevant things were left.
Now this I can not explain, except maybe somehow the coil has gone into self-oscillation. I would love to see if someone else can duplicate this and really be happy to understand the why! I broke all up, used other parts and still got the same results.
See attached circuit.
Parts: 1x 2N2222A, 4x 2N3055, 1x12Vdc battery, 1xHitachi ignition coil, 1x Philips CFG gas tube (all controll board removed) and earth(ground/dirt) wire.
Stats: Battery disconected: 12.24 v, Running 12.16V
Running: Amp from Battery + terminal 0.86 Amp (sometimes up to 1.16A)
Volt at 2N2222A Emitter - 3.03V
Volt at Master 2N3055 Emitter - 2.59V
Volt at coil + 1.87V
Amp at coil + 1.18A
Frequency - connected at + of coil: 5.962k Hz
Same reading without (electrionic) Hz meter connected for distance of up to 42 cm from coil/light - Horizontal. By accident and strange thing: Vertical above the coil the frequency is only 263 Hz and reading up to 220 cm from coil - meter not connected.
Coil does have VERY faint resonance 'whisper'.
All components cold.
No condensor (capacitor) anywhere, no resistor, no diode.
Spark at light about 1.5 to 2.0 mm, blue purple colour.
No feeling anywhere - neither schock on any component.
Touching the 2222 transistor E seems to lighten the bulb a few points.
The light is nearly (85% ??) same is the same light in my roof which is 18W 220V AC.
Oscilloscope shows a strange hoop like wave - similar to Australian Kangaroo! or like standard coil symbol.
PS. Afterthought and went to check: Adding second light INCREASED glow in both lamps to be more than one lamp alone - that is the first light went more bright and second also same bright. With one light a barely noticeable flikker, with two tubes both are very smooth light. Third light seems to keep same brightess as with two - i.o.w. More 'light' in total.
DESCRIPTION:
12v Battery, positive terminal our to parallel supply all 5 transistors connect to Comuter.
Negative terminal got to negative of coil and one point of light bulb.
1st Transistor 2N2222 Base not connected anywhere, but remove and system fails!?
2N2222 Emitter connects to Master 2N3055 Base.
Master 3055 emitter connects to 3x 2N3055 transistors at Base - in parallel.
Earth wire (dirt/land/soil) connects to Emitter of 2N2222
Sorry for drawing on MS-Word 2003. Seems my Rhino 3D can not do PDF or JPEG. Will sort out soon.
Aromaz,
I will be duplicating this today. I have all my fingers crossed and all my toes that this thing will work. I am so tired of burning up 555 chips. I have always thought that a very simple oscillator circuit would make the CFL run quite nicely. The 2n2222 does the switching and the 2n3055s carry the load. The infinite base at the 2n2222 actually makes sense to me but I wonder if a high ohm pot there might let us vary the frequency? The earth ground at the Emitter is another question. Maybe this is causing the effect?
If I get this running I will post the results. Thanks,
First a warning: On my breadboard setup I did not had any electrical shock, but on the second and third builds of the same circuit there is a tingling feeling and sometimes little more towards a shock on the HV wire from coil.
Thank you theremart for the translation. What program did you use; or how?
Lidmotor, thanks for the idea, I will play with it today. However, I tried a few changes this morning but every thing so far cause a shut down.
I took more video, but my JVC and YouTube not happy to share this file. Will get video converter today. "Unknown error in uploading"
Here comes:
BTW my lab is in my boat factory on the first floor. All walls and floor is double layer plywood floor is 30mm thick. At 17h00 all is shut down and all main power switches off except for my office and night lights. No changes in this results till late night. Nearest microwave tower (mobile) is 3.5 km away. Will go test this on the farm this PM far away from anything.
These are my findings; I have now three systems running. One set has the transistors mounted on heat sinks, but because they are running cold, I have two more sets just lying on the table.
Connect one light no Earth is OK, with earth is 2x brighter.
(Brightness by eye only on this stage)
Connect two lights no earth = stronger on both, with Earth much stronger on both.
Connect three lights no earth = stronger than two lights, with earth all DIM a little.
Keep HV wire on one end of the three CFG tubes connected in series no connection on the other end, no earth; first tube reasonably bright, second low and third almost none. Add earth (to 2222) and all three brighten up.
Then I took an 18 Watt fluorescent tube, connected negative from battery and it light up. Other end not connected to anything. However, low power but then touching with finger along the glass tube, the part from connector to finger light up.
Back to three CFGs connected in series and the earth connected to 2222 Sparks: Periodically the spark gap can be as much as 12 mm on and off for maybe 30 minutes, then it goes down to 1 mm for some time and after a while suddenly picks up to 10-12 mm again. Seems to be an irregular waving action. Can also hear variation in the resonance singing of the coil though very soft.
Today will do more testing and taking many more measurements along. Attached a photo: Everything go, 3x CFG, 1x18w tube (warm light) and amp measure from battery positive terminal 0.35 amp! More light much less amp and most interesting the four lights each burns brighter than the one CFG alone without the earth.
Somewhere in this circuit we should be able to add at least a decent capacitor; if that can be done, I think the output voltage and spark gap will increase dramatically.
Photo 1: First set-up with one CFG and drawing 1.19 A.
Photo 2: Third setup for video and play today 3CFG all brighter than setup in previous photo, plus one fluorescent tube (warm light) BUT less amp! 0.36 Amp
Photo 3: Usually tidy but amazement, wonder and excitement End of round one. Will take me hours to clean up and sort out again. All this just because my last 555 smoked.
It seems this thing started by Imhotep has many more legs than he or Dr Lindeman could dream of!
I would recomend either open office or Abi word for docs both are free.
Thanks Mart,
mac user here, still filling in all the programs I need to function.
Aromaz, your circuit is interesting. You would get a largish gain from that Darlington configuration id imagine, along with increased current capabilities and lower internal resistance with 3 transistors in parallel. I have been meaning to try this for a while now, but I have been busy with mosfets. I see that your coil is also placed in the negative leg of the circuit....
Im not quite sure of the triggering however, the 2n2222 would block any flow
to the base of your first 2n3055 I thought. And since nothing is connected to the base of the 2n2222 ...? Or does your 555 trigger this?
Just a little hint guys for those blowing up 555s. You can just as easily run your opto isolator in there so your 555 is protected. You then already have your small npn triggering transistor which can trigger a parallel string of 2n's or whatever. I can draw something up if you need to see it.
I'm a bit slow. I think you've made the whole circuit a colpitts oscillator, thus dispensing with the need for a signal generator. When you add cfl's, you're changing the frequency of oscillations.
