Wierd WIERD and more wierd
DANGER READ ALL OF THIS:
Folks, I ran one system all night, as you will see on a video later, this one was with the single 3055 slave only - and making HV wire very cold, 3055 very hot. Anyway, as I sat down to think of some changes I got shocks - literally biting hurting shocks this time. If grabbing firm on point, no feelings but mate – to get your finger to and from that contact point hurts. Everywhere! I assure you it was nowhere near this at anytime in the past 5 days.
Next thing I shut all down or some 30 minutes and then got it back up again. Still the same. Out comes the scope – which is usually kept on a shelf some 3 meters away. Switched on and immediately notice a different wave form – and the scope is going mad. There are crazily plenty of spikes all over the place. Now; the probe is not connected anywhere. Even when moving scope away 2 to 3 meters – those crazy waves are still there. It took me to move the scope nearly 8 meters away from the single 3055 system before the scope calmed down. When I am close to the scope, it registers waves, when I move away for more than 1 meer, scope goes flat line. When connecting on almost any place in the circuit - it magnifies the craziness. With toroid, everything just goes off scale.
When I switched the singe system off, it took nearly an hour before the scope settles down, placed 60 cm from coil. When switched on again the scope immediately goes crazy.
Me, myself: I have a splitting headache now – real migraine like. Yes I know the dangers, but then it does not really matter to me anymore cause I am now living nearly 3 months longer than what was given to me by medical doctors 15 months ago - hope I will make it 3 or 30 years!.
Another change: the frequency is down to 2.800 up to 3.200 kHz – from past few days all the time around 6.000 kHz. Also the basic wave form is very different from the galloping kangaroo.
Still, all these systems I have are free floating Dynamic Resonance.
Earlier I in the morning my computer hanged up a bit but I wrote it off as normal from electric spikes when factory comes on line in morning. However, after my first set of shocks, I got back and find the computer frozen. Reset and all is OK, posted the previous message. Gone back to lab – Note: My computer is in another office and about 4 meters away from the test table. As usual I played a bit and came back to computer to read about 2222 – hanged up computer. No signal at mobile on my table. Gone back and disconnected EVERYTHING, reset computer and all was OK. This was done 4 times in past one hour and every time I activated the mono set that was running all night – all electronics hangs up. I can run the other original systems; no problems.
Here are some still photos of scope shots. Sorry for the poor quality, but camera also kept on switching off. Later today I will dedicate all my efforts on getting my camera and YouTube talking. After everything is off a while, all electronice seems to be working normal.
Be warned: There are more weird things here and definitely it supercharged all the environment in my lab. After system is down some time and scope is flat line, I found if I am walking around near the scope it picks up wave size and frequency.
This was not the case for past four days with the 2222-3055 > 3x 3055 transistors. Lidmotor, I which you had a scope there. Try with your small radio and see what you can learn from that.
Now note one more thing. The connections are as follow (See photo below):
Battery positive to 2222 emiter to 3055 emitter to slave 3055 emitter to + of coil. Negative from battery to negative of coil only. HV from coil to 32w long tube phillips fourecent light one pole, other pole connects to earth. Last connection is also from ground to emitter of 2222. This system is COMPLETELY OPEN. The only connection from battery negative is to coil negative. No other negative connections at all anywhere from that line/terminal to any part of the whole system.
