Originally posted by nestor
“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
Nikola Tesla
http://www.imhotepslab.com
Condenser-Info
Thank you, Imhotep.
Based on your info I did some search about old-fashioned car ignition systems that use mechanical interrupter contacts to switch the coil. Based on what I have learned so far about this I would say a suitable capacitor to do the job should have a voltage rating of some hundred volts, should be robust enough to take sharp voltage pulses without heating or damage and, according to my sources, should have a capacitance around 0.22 microfarads. I plan to play with different values (say between 0.5 muF and 0.1 muF). Playing with these values a little bit may be an opportunity for some tuning.
Works great, very flexible.
The circuit is simply relay works in wide range, only need get enought energy to conmutation and go well, I tested one 6VDC, but contacts are some weaks, I changed it by one 12VDC good quality, and work great, my snubber is 4.7uf x 220 ohms ( I have no 100 ), coil car is a HITACHI CR6-800 external resistor.
Brightness depend much by bulb quality, so I need to find in the market, my Phillips are some big parpading so much.Your time is limited, so don't waste it living someone else's life. Don't be trapped by dogma — which is living with the results of other people's thinking. Don't let the noise of others' opinions drown out your own inner voice. And most important, have the courage to follow your heart and intuition. They somehow already know what you truly want to become. Everything else is secondary.
Steve Jobs. Apple CEO
Peter and Imhotep, Thanks for the quick response to our questions. Peter I'm glad that you answered my question about the Model T coil and why it is different. I played around with my oscillator today and saw what you meant about having to have things balanced to get the most out of the design. Imhotep I am just amazed that you came up with this. Sometimes simple things are the best. I did try a reed switch in place of the relay and saw a reduction in the amp draw. I ran my SSG, tapped into the drive battery to drive the oscillator, and triggered it by placing the reed switch near the SSG rotor. My rheostat controled the situation so that the reed didn't burn out. Down side was that when you dial down the drive voltage, you not only dim the light, but the charging goes down also. The best thing though, was that the swarm of bees left the room. That relay really makes a buzz. Lots of work could be done on this project to get everything just right for a particular need.
Originally posted by **~Imhotep~** View PostThe condenser is used in older points and condenser and coil or magneto circuits. It was originally designed to suppress the spark on the points and I am utilizing it to suppress the arc on the relay, so that it will last longer. As I stated earlier I could not find the exact uf and power handling capabilities but any lawn mower kit that comes with points and condenser can be used. Good luck
I think that it might be something related to the capacitance I used, I used 330uF, 100uF, 10uF and the smaller the capacitor got the brighter the light was, the problem is with the capacitor, I suppose. I have got some 1600V 0.02uF Caps, I'll try those. I'll also change my relay to a 9V or even a 6V one to see if it makes any difference. I didn't know that those bulbs consume double the rated energy. In this case your circuit ROCKS! I'll make a measurement with my amp-meter!
Thanks for your useful insights, I am very optimistic on this.
@Peter and Others
If we want to design a custom coil for this purpose for lighting around 10 tubes, what's your suggestions?
Elias
I would imagine if you match the primary dc resistance and secondary dc resistance you might be able to use the newer coil packs which most of them are 4 or 6 cylinder versions and im not sure, but i believe they dual fire and actually you would have 2 or 3 coils, if you can get a good service manual with schematics of the ignition it will show you how the packs are wired and you should be able to possibly use it to fire 2 or 3 bulbs. Thats something i will be trying in the future. I also wanted to dual fire either with 2 coils or with a coil pack so if you dont do it, i will be in the future and ill let you know. Dont worry if your results are as efficient as mine or exact its all a journey. And remember your getting energy recovery so as your draining one your charging another. good luck
Originally posted by robur View Postit is not very possible to pbtain the coil from this year as you mention outside of usa or canada
is it possible to use or modify any modern ignition coil?“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
Nikola Tesla
Nikola Tesla
The 1500volt capacitor i used inside the bulb there is 2 wires coming off each side of the tube and one wire i hooked to the center of the screw socket and the other wire to one side of the 1500 volt cap that i pulled off the cfl circuit. I ran the other side of the cap to one of the filament wires on the second filament and then the other wire coming out of that filament i ran to the ground screw base of the bulb. You will easily be able to tell which one it is, it will have 1500 or 1800 and it will be close to the wire wrap area where you took off the wires for the tube, there is usually 2 or 3 of them on the circuit boards. There is also a transformer (or it at least looks like a transformer) Its actually a choke. What they do with the cfl they feed one wire with the pulse through the filament through that cap to the other side through one wire through the second filament and then back out the other side and through the choke back to the FETS inside the little circuits. I have completely back engineered the circuits and understand them completely. You can take one of the caps and it will help smooth the light output. The reason it was not included because I wanted to have everyone get the rough circuit completed, before complicating it and changing it. Some of the more advanced ppl in the forums im sure will have many modifications you being one of them. Please report any improvements or changes. As far as the snubber, I used a 1 uf 160 volt and i also used a 4.7uf i didnt use any larger ones, the smaller ones helped suppress the arc and i used resistance from 100 to 1000 ohms. The relays made a big difference the older ones worked much better than the newer ones. but that particular blue one from radio shack that peter picked out works really well with that coil. Ive not been able to inspect the contacts cause it is a sealed relay, which is probaly better and to quiet it down they dont get to hot, so i wrapped them with a little bit of clothe to muffle them.
@Peter and Others
Elias“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
Nikola Tesla
Lamp Efficiency
Everybody,
OK, let's talk about efficiency. In order to do this, you have to understand a few things about AC power. The first thing is, there are THREE kinds of power present in commercially available AC electricity. The first kind is called REAL POWER, measured in WATTS. The second kind is REACTIVE POWER, measured in Volt-Amperes-Reactive. The third kind is called APPARENT POWER, measured in Volt-Amperes. Contrary to popular belief, the kind of power the public utility sells you is NOT real power measured in watts, but apparent power measured in Volt-Amperes. The difference between Apparent Power and Real Power is the Power Factor, which also represents the amount of Reactive Power present.
If you have a Kill-A-Watt meter, you can follow along and prove all of this to yourself. A resistive load, like a filament light bulb draws only Real Power and no Reactive Power. Therefore, the Real Power and the Apparent Power are EQUAL. However, an inductive load draws Real power AND Reactive Power, so the total amount of Apparent power needed to run an inductive load (like the power supply in the CFL) is more than the total Watts showing on the meter.
The simple test is to take an ordinary filament type of light bulb and a compact fluorescent light bulb (CFL) and run this test with your Kill-A-Watt meter. First, plug the filament bulb into the meter and read the WATTS. Then read the Volt-Ampere reading, and finally, the Power Factor. In this test, if your light bulb is rated at 75 watts, the meter will read 75 watts, 75 Volt-Amperes, and a Power Factor of 1.
Next, plug in the CFL bulb. Let's say the CFL is rated for 18 watts, and is designed (and sold to you) to replace a 75 watt filament bulb. Everybody repeats the LIE that these CFL's run on just 25% as much power as the bulbs they replace. But what do they really do, and what are you really charged to run them? The Kill-A-Watt meter tells the truth! The meter says that the CFL rated for 18 watts draws..... 18 watts! So far, so good. Unfortunately, the CFL, due to it's inductive power supply, is operating at a power factor of about .55, so it draws about 33 Volt-Amperes of Apparent Power. Since Apparent Power is what the utility company is SELLING you, the CFL actually costs almost twice as much to run as you have been lead to believe.
In the coming weeks, Imhotep will be providing a "fix' for this also, so even the CFL's you run in the normal way will cost less to run.
In the meantime, Imhotep's circuit really is running these CFL's for a small fraction of the normal cost, AND recovering about half of that, as well.
If you have modified the GE 42 watt CFL for this circuit, like Lidmotor shows, and can light it to high brightness on 12 volts @ 1.2 amps AND recover about half of this power to charge a battery, then the real cost of lighting the light is about 7.2 watts. Since this is DC from a battery, that is the Real Power consumed. This same CFL, running from the AC line, will draw more than 76 Volt-Amperes of Apparent Power (42 watts @ .55 PF). That means that Imhotep's circuit SAVES you over 90% of the real cost of running the light!
Now, that's what I call IMPRESSIVE!!!
PeterLast edited by Peter Lindemann; 08-04-2008, 05:30 AM.
Thank you for the additional research and the great lesson is reading the TRUE energy usage. I will being doing a video as you say in a very short time that will be showing everybody how to correct the situation and save everyone money! Again you are the master, you are very busy and so very generous with all of your time, I cant begin to thank you for all the help you have given me. Both me and Shiva are very appreciative.
The simple test is to take an ordinary filament type of light bulb and a compact fluorescent light bulb (CFL) and run this test with your Kill-A-Watt meter. First, plug the filament bulb into the meter and read the WATTS. Then read the Volt-Ampere reading, and finally, the Power Factor. In this test, if your light bulb is rated at 75 watts, the meter will read 75 watts, 75 Volt-amperes, and a power factor of 1.
Next, plug in the CFL bulb. Let's say the CFL is rated for 18 watts, and is designed (and sold to you) to replace a 75 watt filament bulb. Everybody repeats the LIE that these CFL's run on just 25% as much power as the bulbs they replace. But what do they really do, and what are you really charged to run them? The Kill-A-Watt meter tells the truth! The meter says that the CFL rated for 18 watts draws..... 18 watts! Unfortunately, it is also operating at a power factor of about .55 and draws about 33 Volt-Amperes of Apparent Power. Since Apparent Power is what the utility company is SELLING you, the CFL actually costs almost twice as much to run as you have been lead to believe.
In the coming weeks, Imhotep and I will be providing a "fix' for this, so even the CFL's you run in the normal way will cost less to run.
In the meantime, Imhotep's circuit really is running these CFL's for a small fraction of normal cost, AND recovering about half of that, as well.
If you have modified the GE 42 watt CFL for this circuit, like Lidmotor shows, and can light it to high brightness on 12 volts @ 1.2 amps AND recover about half of this power to charge a battery, then the real cost of lighting the light is about 7.2 watts. This same CFL, running from the AC line, will draw more than 76 Volt-Amperes (42 watts @ .55 PF). That means that Imhotep's circuit SAVES you over 90% of the real cost of running the light!
Peter“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
Nikola Tesla
Thanks Peter this was really informative.
I recall that it is used to compensate for the power factor by matching capacitors if the load is inductive, and inductors if the load is capacitive.
This simple technique is used in factories for power factor correction by using large capacitors in the front end, because of the large amount of inductive loads they use. (i. e. Electric Motors)
I wonder if this can be applied to the CFLs? And are CFLS capacitive or inductive? the tube seems to be more like a capacitor.
I think that this can be found out by using an oscilloscope and measuring the phase difference between V and I.
Elias
Lamp Efficiency
I just checked 4 of my spare CFL bulbs I have on store for replacement of defective bulbs.
All had the CE mark used in the EU countries. One was produced in China, the other had no mark of county of origin.
All had a power factor of 1.00 and a consumption of 9, 11, 20 and 23 Watts as specified.
When I did some rotoverter experiments, I also checked my freezer. adding a capacitor to achieve 0.98 power factor saved 15%.
Thank you Peter for your clarifications on the rotoverter some time ago.
Talking rotoverter, Hector mentioned that when resonance is achieved, the magnet field extends quite strongly outside the motor.
With my home made "ignition coil" I took a neo magnet and I was surprised to find that I could feel the magnet vibrate at 20cm distance from the core welding rods.Closer the vibrations were strong, My circuit oscillates around 300 Hz.
After a few minutes of running the circuit. the welding rods heat up. so I guess this is one reason my circuit consumes 3 amps at 8 volts supply from a Li-Ion pack. My bulb is rated 23 Watts. It is brighter now, but less than half the brightness of a similar normal powered bulb. It is hard to see the true brightness of the CFL on a video. Is your brightness the same as the ordinary similar bulb ?
I must visit a scrap yard to get an ignition coil. To my knowledge, no modern cars around me uses these ignition coils anymore. For emission control all is now computer controlled. My own car has no distributor or high tension wire. but individual ignition coils directly upon each spark plug, so the high tension area is sealed inside the top, protected from moisture and salt.
Another option is to make a better coil myself, but I will wait until I get time to make a winding machine able to handle very thin wires. In all not so easy to do.
Eric
Coil Types
hello
i am posting this again as my previous post was overlooked.
I live in the United Kingdom
The coil of your type is not avaliable here so i would like to address the problem of the coil type.
is it possible to modify modern coil or use any other type of modern coil that is avaliable off the shelf?
thank you
i hope i will be answered.
Most of our auto parts stores here in the us stock the older parts for older vehicles. If you cannot locate one....
Your best best is to try to use one of the coil packs, they are more expensive, you can order coils online also. It does not necassarly have to be a 67 camero, but you wont get the exact same results. You might even get better results. What you want to look for is very simply, a ignition coil, every car has one that has a spark plug. I would even check around to the local junk yards. The coil packs as i said would probably work as well, but your results will be different.
This is all a journey, a learning process for everyone. Do not worry if you cannot get the SAME exact parts, but dont expect the same exact results. Like i said it could even work better. Let us know how your search goes in the meantime I will have Shiva look into whats available in the Uk. she does have contacts there, but it takes a few days to get information back and forth. good luck
thank you
i hope i will be answered.“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
Nikola Tesla
