  • Dont now about how far apart
    And shes not going to run it for you YET!!!
    But if you look at this patent and think about triggering the third coil i think she will.
    PAT2PDF - Free PDF copies of patents: Download and print!
    patents number 600457
    • more radiant information
      Take a look at this for more insight
      Jules Guillot -- Atmospheric Electric Generator -- Article & 2 French Patents
      • Lidmotor, Thanks a lot for sharing your " Quiet Imhotep Relay Charger". As long as it charges and draws less, we will somehow manage to improve what we are doing as we go. The best thing here is that we have a lifetime to do it and we enjoy what we do.
        braden
        , thanks a lot for the info. I have seen this kind of antenna just last week for the first time and now here.
        • i think i need a spark gap vacum with two magnets north and south to blow the the spark field. is this what you are trying to say? i dont think reed switches will work for this. Thexton Ignition Spark Tester w/ Adjustable Gap | Brandsplace
          Scalar vortex? YouTube - Scalar Energy Vortex
          Been doing some other experiments to do with reed switches.
          Lidmotor position and height and the poles increase battery power we are looking for magnetic currect not a chemical battery.
          YouTube - Bodkins 14 earth battery
          repeated the test with the metal rod insulted same result.
          • You are right Bodkins, to "clean" the cold current from electrons you need a strong permanent magnet to blow away the electrons. Don´t forget that the "receiver" of the cold current should be at 90 deg. angle from the spark gap and possibly concentric cylinders are good receivers(like Gray conversion tube) and some wire with dielectric insulation going ut at a right angle to the spark gap. Many things to test there... Split the positive could be a good idea(LV and HV anodes) but start out with unipolar pulses, should be ok.
            • Originally posted by Gauss View Post
              Gauss do a diagram of your ideas i work better with visuals
              http://www.iwwwfb.org/Abstracts/iwww...wwwfb17_42.pdf
              cone spiral coils?
              • P197 Electrical experimenter Feb 1919
                Tesla advises “Imagine the earth to be a bag of rubber filled with water, a small quantity of which is periodically forced in and out of the same by means of a reciprocating pump
                if the strokes of the later are effected in intervals of more than one hour and 48 minutes sufficient for the transmission of the impulse thru the whole mass the entire bag will expand and contract.”
                I was quite curious about the 1 hour and 48 minutes. So in an attempt to understand this better I threw a fairly large rock into a very small calm pond and watched the ripples. As they hit the shore they reflected back and interfered with each other creating more intense frequent waves.
                Try the experiment for a better understanding. The pond represents the ether and the shore represents the outer atmosphere. The rock represents the oscillator with an insulated plate or sphere attached.
                • Tesla was sending out a series of pulses which reinforced
                  one another, resulting in a tremendous cumulative effect.
                  Pulse splashs in the water timed to push the wave/ether back down at its highest point.
                  this helps me
                  YouTube - Scalar EM Tesla Coil Longitudinal Waves
                  • Yeah so his wireless transmitter is really just in startup mode for the first 1 hr and 48 minutes...I wonder if this applies to a smaller transmitter.....
                    Its like warming the engine up before going full throttle
                    • Sorry about the visuals and drawings Bodkins, my problem is time, at the moment my hands are tied 99% of the daytime... Please look at the Gray patent or the Baraka document: Tesla-Moray - The Secret of the Joe Cell, 22pp
                      Every guy has some good ideas, you just need to combine them. Baraka has completely forgotten about the important design of the "receiver" but you can see the receiver cable coming out 90 deg. from the spark gap along the concentric cylinders. So the important question is the geometry and materials of the receiver, I am sure you can get it right though. The concentric cylinders remind me of the flat pancake coils used in the Tesla coil.
                      Anyway, all of you should speak to a journalist about what you are doing and the kind of threats you feel, the more people the better, that way you will be more safe and if something happens it will help the development. And document as much as possible with other people in case something happens.
                      Now that Youtube closed Aaron out, why not put that BIG news(together with stories of other threats and murder stories of Meyer, Gray, Mallowe etc) on the frontpage of this site to get more members in here??!
                      That is good PR if you ask me. Normally these kind of events triggers twice as many people to do something. We should at least honour the people who died for this technology and use them for our good purposes.
                      • The Wireless Power Transmission System
                        • I cant help thinking this is transmission of power in some way? need to get the receiver in resonance better.
                          YouTube - Bodkins 13 BEDINI IMHOTEP TESLA
                          what do think people?
                          This is the greatest set of videos i have ever seen
                          YouTube - resonance
                          YouTube - resonance2
                          YouTube - resonance4
                          I use holistic care everday, its the care of the hole person the past the future and time we are In
                          I See the person in all the time in there life. you resonance in there life as a refletion of them. a open path of energy.
                          Well it works for me
                          • Bodkins
                            In the Borderlands video, they were finding two resonant frequencies... one they called a "transverse wave" the other a "longitudinal wave"... I wonder if this is the same phenomena... one is sub-light the other is faster than light.
                            According to the article posted above...
                            "Because lines of flux exist between two opposite charges a dipole transmitting antenna is not needed. Curry proposed a dipole in order to create a wave of the proper length to be propagated through the medium. However, in electrostatics it is not necessary for flux lines to detach and close upon themselves to propagate an electric field. The field is established by the flux lines between the two points of charge. Curry misunderstood the nature of the electrostatic field. Once the field is established, a change in pressure on the charge will cause a variation in charge at the other end of the field - a displacement current.
                            Also, Tesla points out that a dipole is not needed to receive even low frequency signals in an electrostatic system. Tesla pictured his receivers with electrodes spaced a quarter wavelength apart but this was to charge an unpowered receiver as rapidly as possible. The receiver's capacitor would see maximum voltage changes, and, thus, would gain sufficient charge to power a device, if the ground electrodes had such a spacing. If, though, "the impulses are... are alternating, but sufficiently long in duration" they can be received by a single electrode that is turned on and off with the same period as the transmitter. Because the field's flux lines do not radiate but start at the transmitter and terminate on the receiver, the receiving structure does not have to be a specific shape or length."
                            • Bodkins, you are right on track to success, just keep going!
                              I got an idea about the grounding geometry for the cold current. Has anyone seen the Lichtenberger geometries? That kind of a grounding geometry should be worthwhile testing, many thin cables going deep into ground in different directions just like the nerve fibres of your body(1-wire system). Remember the stories of the grounding of Wardenclyffe, Tesla put 50% of his time underground digging channels...
                              Lichtenberg figure - Wikipedia, the free encyclopedia
