Yes 12v and have fryed the 2n3055 this morning so need to rebuild again!!!
Mart
I what to run the opposite on the other end of my bulbs.moving the energy for one ignition coil to another.
Basicly inverting the first 2n3055 signal so you get one charging the other one then swop it,
Like energy Tennis with a gound on each side.
Hi guys. I've been conversing with bodkins on page 2 and 3 of earth battery thread, gotten off topic. There's details there relevant to radiant oscillator thread and water spark plug thread. :-)
i have been tinkering with my new discovered spark gap....quite odd....i put in place a proper solid brass sphere spark gap....and it doesnt work...however if it connect only one up...everything on the bench starts to hiss
then i went back to my magnet wire spark arrangement and place them close to each other with two connecting....now they glow purple in colour....like a plasma colour....
am starting to wonder if this is what tesla refers to as the weak dielectric he mentions in the radiant energy patent and others
I dont now where to got with the spark/ground stuff do we keep it here? but this is imhotep light stuff if anyones new to it they will be lost??
Forget that next video uploading to here!!!!
Last night I was working with a double contact relay and ignition coil. One contact when in default on position would trigger the coil in relay to open the switch, turning it off - where it would then return via the force of the little internal spring to 'on' position. I had intended to have the other contact going off-on being setup in same manner but instead driving ignition coil primary, not relay coil. I accidentally wired the negative from relay coil thru (backward facing 1n4004 diode) to pos of ignition coil, and pos of relay coil to 90v neon to neg ignition coil. and I had a 1000v diode from ignition coil secondary to ignition coil primary negative. the system produced only 60v when measured from primary negative or secondary positive, and barely lit neon to ground. But it barely registered current draw on amp meter. My relay is made of clear plastic; lots of sparking on contacts. When I realised low voltage was because I had wired it 'incorrectly', I disconnected negative wire to relay and got up to walk away. Then I noticed the meter still connected was showing negative 1 volt. When it got to negative 10v, I got my camera ready. But when I returned, volts were back to 0. Don't know if I disturbed anything? I'll try it again tonight and try get it on video...
Ps I was measuring voltage difference with respect to ground.. It was higher than voltage diff from primary neg and secondary pos, which was a mere couple of volts. Also, when it was off, ie negative to battery disconnected - I touched positive and meter showed 3v.. Thought that was odd, as ignition coil not oscillating so should show zero?
Where did you get your spheres?!!! I've been wanting to oscillate a metal sphere for ages but can't find any. The sphere shape restricts electron movement so should help only release pure voltage..
"But, he said the proof of the whole thing is the fact that Cold Electricity will run anything, you don’t have to have the frequency,[and] you don’t have to have the voltage. It just has to be in that certain range. I said, “What voltage do you have here?” “Well,” he said, “it runs somewhere between 1200-1400 volts.” So he had a little battery stepping it up through that little trickle charger."
My setup is creating interference on the radio and stopping the cd player now....so i can see what happened to gray...he got shut down pretty quick because of it.....
