  • wiki submission
    Originally posted by Aromaz View Post
    That is what happens when you participate in an encyclopedia based on majority vote...it overrules facts or reality.
    Tell me exactly how to contribute to give my KEEP opinion versus their DELETE? I looked at it:
    Wikipedia:Articles for deletion/Dynamic Resonance Theory - Wikipedia, the free encyclopedia
    but didn't see where I could give my vote.
    • negative transistors
      Aaron, I have MJL's in stock will swop them just now.
      Hi Aromaz,
      I looked through the last several pages of posts and watched a bunch of vids from everyone. Very exciting!
      I think I remember Bedini posting that the MJL's went negative at 1amp at least. BUT, these circuits are a bit different so it is worth a shot. That shows that they DO have the capability to go negative like the 2N2222's. If I can find my notes, I'll post what the 3rd for sure and possibly 4th transistor was that also could go negative.
      • Answers to Aaron
        Hi Aromaz,
        Have you charged a cap by putting it in place of the cfl?
        I did, see my posting # 1296. And tried later again few options, can not understand why, but soonest a cap or diode goes in, system terminates.
        Is there a difference in brightness if you have the cfl on the + side of the coil? There are applications where switching on the positive on these kinds of circuits will actually give you better results than switching on the negative.
        None I could see. Once ren made a remark about circuit being wrong way around - then I tried turning and swopping - no difference in same light setup or amp draw..
        You mention HV on the battery terminals. You are definitely getting radiant. I posted some youtube vids before of me charging caps with 1 wire from a circuit...that circuit is a very simple Imhotep oscillator with the relay....I never showed the circuit but that is what it was!
        The 1 wire transmission was a SINGLE WIRE from EITHER terminal of the input or output battery...through some diodes (plug style) to a cap and it charge the cap. Anyway, I can always repost that and a schematic if anyone is interested but that is probably old news by now.
        I did see that and dupicated it, >> Somewhere around page 20 I will estimate. However this circuit behaves seriously different.
        As a note, I could only get this effect enough to feel with my fingers with batteries that have been heavily "modified" though many experiments and it just goes to show that impedance / basically - balancing gas pressures on the circuit from the input/output is crucial or these things cannot be found by most.
        You say you felt hv at the terminals of the battery but when the ground was removed. When the ground is there, I bet it is STILL there (at the battery), just most if being sucked away. Your batteries are receiving a radiant kickback from the ignition coil through the entire circuit.
        Lidmotor find with ground connected there are no HV. His system in that video was quite modified. Unfortunately he does not have a scope. On my original and somewhat modified version later there is HV everywhere. When just starting up, not so serious, but it seems the longer the system runs, the stonger the HV becomes. I want to go back to that setup and redo properly to see.
        With the voltage increasing, the first thing I would check is the condition of the battery in the volt meter. In some smaller meters, if the voltage drops too much in the battery, it will show higher and higher voltages when the opposite is true.
        I am mostly using one MMeter, but before I post or accept a fact I do verify with at least two others. My believe is that any new idea/truth has to be verified by at least tow independant other sources. In life and mechanical. One of the meters is always digital. Once I fell into an excitement trap due to meter error. Now I have 7 digital meters; all different brands and 4 analog meter in my lab.
        I do not doubt you have higher voltages. I have had this even off of some Bedini circuits and other projects, but it is something to rule out.
        The battery charge is still not completely verified, except for the HV at terminals. I am playing aorund and chinging the circuit too much to see what cen do. I did not yet set a system to run for battery monitor. At present the battery idea is far on the back burner. I am more curious to follow this circuit through with earth/aether charge and get continues flow from Tom Bearden's "Sea of Energy"
        I am now getting through to YouTube and is busy to edit and cvompile my video's in a more presentable format. Trust to start posting them tomorrow. Late PM in Thailand has very slow internet connection - even with our high speed. There are two things I noticed from my video's and Lidmotos/Bokins - my lights birn quite stronger and much less flikker.
        When I am up to date with videos, I will also look more into the actual components I have r.e. manufacturer. etc. There are still a heck of a lot observations which I want to follow through. Much more than I would logically think possible from such simple circuit - and not yet noticed by the other participants.
        Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
        • Wikipedia
          Skip it, they will delete - not said by them, I only saw later - because it is ORIGINAL CONTENT and not PROVEN. I am moving it over to the more experimental side-leg of "WikiInfo"
          But I kind of liked the insults, made me feel more worthy to sit at the feet of Master Tesla and others.
          • Magnitized
            Hi Aromaz,
            Can you see if anything in the vicinity of that ignition coil has become magnetized? Paperclips, staples, etc... any small things like that? And if so, from how far away?
            SORRY Slap me inthe face!! Oversight from me yesterday - A VERY STUPID oversight because my ultimate hope is to get magnets occillate i.e. Floyd Sweet. I was not too well nearer to end of day.
            Will run same setup again in about two days. What was a fact is that it seems everything - even loose lying copper cables on the table got electrically ( ? Static ?) charged. Gave small spike and bite when I touched them When I walked with the scope and probe, all metal objects - even aluminum bowls, acrylic and steel sheet emmited stronger resonance/oscillations when I bring the probe near to them - voltage, though in various wave forms and frequencies. IT IS WAY OUT TOO EARLY TO CLAIM THIS - but I think somehow this HV emmitions created a resonance in other objects, even their resonance were different. How this could be possible I do not know and this phenomena has not been duplicated or verified. I got seriousiously scared when I found everything charging up with voltage and my computer/phone acting strange.
            Today I am back at original Imhotep Radiant Oscillator and redo some of the experiments just to make a series of video for my own and publish from me on YouTube of the items I have changed or different findings than those published by our excellent partners here on Energetic Forum.
            • Wave Form
              Aaron or someone else.....
              Could someone with more 'know about' please explain for me what they see / understand or suspect when looking at the original 'Galloping Kangaroo" wave form - see my posting # 1293
              Then the same basic wave form is also present in the photo on posting #1337, but with incredible spikes. The spikes I understand, but I am sure the exact wave form will tell us an interesting story.
              There seems to be two kicks, on slower about 30% upwards, and about 70% up there is another rise which flats off a bit before it climbs more. Then also the 'sea wave' effect of some two or thee higher waves and many smaller waves in between. These waves are us begging to tell their story! Truely even in my dreams they disturb my peace.
              • Thanks Gnino
                Originally posted by gnino View Post
                in different setup of Aroma circuit i found this scope shot
                I an very happy to see more scopes around. I am trying to get this more analyzed. Though your first photo show fairly standard shot, what the heck does the second photo? There we seems to have an inverted wave what I found but then a kind of echo? and the extreme spike.
                What circuit did you use there - if you do not mind?
                • Hi this is my fist post, although I kept reading topic from its first days. I would like to thank you all for sharing your ideas. Please have a look at this [url=http://www.hohlov.nnov.ru/] it looks familiar to idea used in Aromaz circuit.
                    I had good safe fun all day today playing with the circuit. I finally got down to just (2) transistors and named the circuit "Bodkins Kick starter " because of the way it has to be jolted into running. It is amazing that all this designing is happening because we were burning out parts.
                    YouTube - Bodkins Kick Starter 2 Transistor CFL circuit
                    Lidmotor
                    Great Video Lidmotor
                    Could you please post the circuit.
                    I tried it but I must be doing something wrong.
                    I couldnt get it to self oscillate the light would just come on for a second when I tried to jump start it.
                    • slayer007 connect the base to ground or a anntena and the jump start
                      Hi Lidmotor,
                      When the intake and exhaust of these circuits are matched just right for the most pressure, you will get this. I'm excited about all of your and everyone else's discoveries here in this thread. I haven't kept up on it super close but I glance it often. A convergence is afoot
                      Today 08:51 AM
                      lidmotor remenber the cap you had a long time ago connecting the front and the backend rheostat on the back too??????????
                      RealityMaker niceone looks like a crazey switcher
                      • Kick Starter
                        Hi Lidmotor,
                        Today 08:51 AM
                        Slayer-- Here is the circuit that I used yesterday. You might have to go back to the original Aromaz circuit posted earlier, get it running, and then start pulling parts off. Your ignition coil might be alittle different. Also this would only run if I had the right CFL configuration. I think that it is an impedance thing. Try hooking different bulbs together in series. The variable resistor (rheostat) was a must to control the drive power. You can probably use a 12 volt tail light bulb instead and get it to work.
                        Bodkins-- I will be trying ALL my tricks on this thing. This is very exciting. When I read Aaron's comments about charging a cap with one lead it really got me thinking of the possibilities here. I may go back to the original circuit with the 2n2222 and study this negative resistor idea. I am going to have to get a scope. This is very frustrating not being able to see these wave forms. It is like being inside the boat in a storm-- you can hear the waves but you really want to see what is happening---as scary as that is.
                        Aaron and Ren-- Your input here is much appreciated by everyone envolved. Ren you had excellent words of advice about cleaning things up a bit to rule out wrong conclusions. Repeatability is very important or this is just a waste of time.
                        Aromaz--- I am anxious to see your videos.
                        Nat--- I will start on the receiver this week.
                        Lidmotor
                        PS---PS---PS!!!!!! There is an error on the below circuit!! There is no connection between the base of the second transistor and the collectors. SOOO SORRY for the mistake. I will post the circuit again without the mistake.
                        • Thank you Lidmotor
                          I'll be trying this today.
                          I'd like to see adout picking up the BEMF from the coil.
                          Great work guys thanks to every one.
                          • 555 dump of the Imhotep's relay.
                            Just finished this video..
                            http://www.youtube.com/my_videos
                            Nice to be able to start getting more control over the 555. But the strange thing is to me is when I turn on the relay the rate of the 555 goes up.... From watching other people usint the 555 it seems that it is sensitive to other circuits around it...
                            I now have the solar powered Solid State Bedini running 24/7 with a fuse it is very sweet to have multiple batteries on the backend all charging up at the same time.
                            See my experiments here...
                            • "Kick Starter" Circuit correction
                              Lidmotor
                              Here is the correct circuit without the connection from the base to the collectors. Sorry for the mistake. It is wrong in the video also.
                              • hv effects
                                My first guess is that the HV projections are simply using all those objects as conductive paths to earth ground. But maybe not.
                                If those things are remaining charged after your circuit is off, then that has been seen by Tesla and others too. There have been results like this where all the metal objects even in different parts of the building have become magnetized and that magnetism held. Different from electrical charge like with HV shocks.
                                If you haven't read Secrets of Cold War Technology by Gerry Vassilatos, I would highly recommend reading chapter 1 on Tesla. That one chapter I believe explains just about everything that I have read on this thread...almost.
                                That book was used as a "Rosetta Stone" to basic concepts of the Gray Patents.
                                Used copies are about $200 on Amazon but you can find it elsewhere.
                                Maybe spiral bound avail here:
                                TeslaTech Resource Center |Secrets of Cold War Technology | 220037
                                You might find it online somewhere. It is the only thing I really ever read on Tesla and it connected the dots on just about everything.
