Originally posted by Inquorate
Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
Setup
will post ohms and capacitance etc tomorrow. Missus saying I'm not allowed back downstairs tonight. The copper thing is electromagnet.. Just 5cm ferrite rectangle with 0.25 mm copper (clear insulation) wire turned around it from coil negative, to help quench spark gap. It probably not necessary to get effect.. ?? Thanks for taking such an interest Aromaz. It's got me stumped.Atoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
Originally posted by Aromaz View PostTotally baffled. Add to our collective special folder: “Weird”
No possible way I found any relation elsewhere on internet - yet.
Been looking for past 3 days about this since you described it.
with torsion. I thought it might explain the wood observation of Inquorate.
How, I can't explain, but wood is more like a sponge (to be squeezed) than metal is.
I've read where wood shows detected torsion effects 70 seconds
after the experiment had ended, much much longer than metal does.
Torsion is always involved / part of the energy (and any energy!).
@Inquorate, thank you for trying the twig thing.
Just looking for something other than: light, sound, spark or color to observe.
Very interesting your WOOD effect, confirmed, showed us a new CLUE ..
a puzzle piece, what's the picture this piece fits into ?
If the twig moves at all, it might only move a couple of degrees. You
probably would not notice a movement unless the twig had stopped moving
before turning on the circuit. This I found out after more reading elsewhere.
Also, most of what I've read indicates any detector alone does not work
without being vibrated (how isn't told) or something else.
See Experimental detection of the torsion field
to understand how much of a pain this detection is.
@all - Food for thought VACUUM SPIN FIELDS
Worth pointing out is: Not Your Average Construction Projects at
the bottom of the page, of link above, to see not-your-run-of-mill
detectors of all kinds.
RandyRemember to be kind to your mind ...
Here are a few noteworthy quotes from Tesla's IEE lecture.
When an ordinary low frequency discharge is passed through moderately rarefied air, the air assumes a purplish hue. If by some means or other we increase the intensity of the molecular, or atomic, vibration, the gas changes to a white color. A similar change occurs at ordinary pressures with electric impulses of very high frequency. If the molecules of the air around a wire are moderately agitated, the brush formed is reddish or violet; if the vibration is rendered sufficiently intense, the streams become white. We may accomplish this in various ways. In the experiment before shown with the two wires across the room, I have endeavored to secure the result by pushing to a high value both the frequency and potential; in the experiment with the thin wires glued on the rubber plate I have concentrated the action upon a very small surface—in other words, I have worked with a great electric density.
A most curious form of discharge is observed with such a coil when the frequency and potential are pushed to the extreme limit. To perform the experiment, every part of the coil should be heavily insulated, and only two small spheres—or, better still, two sharp-edged metal discs (d d, Fig. 11) of no more than a few centimetres in diameter—should be exposed to the air. The coil here used immersed in oil, and the ends of the secondary reaching out of the oil are covered with an airtight cover of hard rubber of great thickness. All cracks, if there are any, should be carefully stopped up, so that the brush discharge cannot form anywhere except on the small spheres or plates which are exposed to the air. In this case, since there are no large plates or other bodies of capacity attached to the terminals, the coil is capable of an extremely rapid vibration. The potential may be raised by increasing, as far as the experimenter judges proper, the rate of change of the primary current. With a coil not widely differing from the present, it is best to connect the two primaries in multiple arc; but if the secondary should have a much greater number of turns the primaries should preferably be used in series, as otherwise the vibration might be too fast for the secondary. It occurs under these conditions that misty white streams break forth from the edges of the discs and spread out phantom-like into space.
Edit: Sorry, I forgot to include the link.
"Experiments with Alternate Currents of High Potential and High Frequency" by Nikola TeslaLast edited by broli; 12-14-2008, 10:35 PM.
Broli wrote: -
2The message is clear. Push the potential and frequency as high as possible and INSULATION INSULATION INSULATION INSULATION."
Other than get a grand display, what can we achieve in practical and useable terms by doing this?
Hoppy
Hoppy
These experiments are the initial phase of visualizing the aether. And sending power wirelessly over long distances with extremely low losses.
The second phase includes taping in the already streaming aether that bombards earth from all direction. Which incidentally leads to free energy.
The third phase is hopefully a way to manipulate the aether in such a way to produce so called anti gravity.
If we keep talking about the point of obvious things we waste valuable time that could have been spent on doing constructive things to reach our collective goals.
Originally posted by broli View PostOther than keeping it easy and telling you to read Tesla stuff. I'll be more elaborate.
Hoppy
hi guys this is shiva. I had a spare second and was reading through some of the threads and noticed the "missing" posters were out. Didn't realize so much time had passed since our last posting in either of the forums. Let me get everyone up to date real quick
Imhotep is still working on his new room for his experiments. As much as I love to have it all in my living room the holidays are approaching and I will need the living room for guest. We got a little behind a bit as the economic downfall hit home early last month as I was laid off from my work. So Im having to work 3 times as many hours to make the same money. So that has taken up alot of my time so I havent been able to read through the forums as post as much as I have wanted.
But we are keeping our heads high and looking towards the future and January 20th when our new president takes office. We have high hopes for the renewable energy field. I sense it will be a big energy revolution. And we hope to see more support for inventors such as imhotep and yourselves get the credit and help that we all deserve. Imhotep will be getting back into his experiments soon, as I have greedily taken up most of his time having him help me around the house as I am a bit overwhelmed right now. I will be taking the holiday tho and catching up on both the website and our movies and forum post. I will be sitting him down this week in front of the computer so he can catch up on his reading and questions that we have gotten in the past few weeks. I again do apologize for the lack of response its just be a bit crazy here in imhotep land
Just throught that I would drop everyone a line so that everyone would not be worried. The MIBs dont have us yet..
**~Shiva~**“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
Nikola Tesla
http://www.imhotepslab.com
Hi Shiva & Imhotep
Hi guys,
Good to hear from you and happy holidays to you both. As you can see we have been hard at work. Thank you both for setting this big wheel in motion.
I was asked to post the circuit that I used in my last video. GBluer (AKA Slayer007) has a thread called "Pulse Generator" and this circuit was used to drive his BEMF booster. I redid it a little and made it also drive the CFL and makes the big purple arcs. I found the pulse width modulator (PMW) circuit online. It is a CapeCanaveralLab design. I think that getting the pulse width and frequency right is important to this project. This circuit may help us learn more about that. Some of these parts and their location may look a little funny ("Thats funny") but the build was a trial and error thing and this is what worked. On the charger circuit I think that a charge controller may be needed--it puts out that much punch. It will hold a big cap at 50 volts under a 110 v night light load.
LidmotorLast edited by Lidmotor; 10-05-2011, 08:23 PM.
Dielectric
@lidmotor - reply to your youtube comment re wood ground /
Not capacitance, but also not earth... An earth to where? Wood is a dielectric. Did you notice in video where I touched the glass on my desk and the spark started jumping the gap as well? Gotta be a dielectric 'arial', ??
@Aromaz - tank cap is 250 gram jam jar, salt water, 2 layers of Alfoil around outside, electrical tape 2 layers. 0.5mm copper wire (scraped off insulation) length of jar into salt solution. The spark wasn't jumping as far after 3 days, maybe salt 'rusted' this wire.... Baking soda good alternative to consider. The electromagnet is pointing north to spark gap. However, lidmotor has noticed same phenomena so exact replication probably not necessary..Atoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
