Computer controlled ethonol pump at your house!
See my experiments here...
You do not have to prove something for it to be true. However, you do have to prove something for others to believe it true.Tags: None
Reply to Mart
Hi Mart,
That's one big bread machine! Expensive, too. Actually, it is not much more than a portable still (distiller) with a pump and nozzle attached. I have an electric distiller that I use at my cottage, and as a matter of fact it is running right now. I bought that at Sears a few years ago. It was about $50 then, and it is a one gallon capacity. Of course I'm making drinking water from lake water, but the same unit could easily be used to distill alcohol. Perhaps I'll make some and try it out in my lawnmower. If that works well enough, I might try running my 50 hp Johnson outboard on it.
Notice they say the product is "not fit for human consumption."
Rickoff"Seek wisdom by keeping an open mind to alternative realities, questioning authority, and searching for truth. Only then, when you see or hear something that has 'the ring of truth' to it, will it be as if a veil has been lifted, and suddenly you will begin to hear and see far more clearly than ever before." - Rickoff
RE: Still
RickoffSee my experiments here...
Here is a website that may be of interest to you. FREE MOONSHINE RECIPES For moonshine--er--uh--ethanol. Good Luck. Stealth
This is totally hands-on manual method, you build it, you make it,
which mean you choose the size of batches ..
Welcome to Alcohol Can Be a Gas! | Permaculture & Alcohol Can Be A GasRemember to be kind to your mind ...
still
i built a valved reflux still which produces ethanol 95% pure with one distillation
energy required to run it is quite high but if you use lower than atmosphear pressure this can be reduced
Home Distiller • View forum - Column Distillation and Design
have a look at this site for some info
Those are some good websites. There is so much info on making ethanol, it should be a cinch for anyone that wants to learn to make their own. Although most vehicles don't run well on pure ethanol, by mixing with gasoline they will run very well. Another thing is that ethanol doesn't get the fuel mileage that gasoline gets. Good Luck. Stealth
