I'm starting this thread since i know some of you are not familiar with wave energy.
Unfortunately i am no master in this field (or any other for that matter) but i will try my best to explain the concept behind an OWC or oscillating water coumn which is just one of many devices created to extract energy from ocean waves.
The oscillating water column (OWC) operates much like a wind turbine
via the principle of wave induced air pressurization. Some sort of closed containment housing (air chamber) is placed above the water and the passage of waves changes the water level within
the housing. If the housing is completely sealed, the rising and falling water level will increase and decrease the air pressure respectively within the housing. With this concept in mind, we can
place a turbine on top of the housing through which air may pass into and out of. Air will flow
into the housing during a wave trough and will flow out of the housing during a wave crest.
Because of this bidirectional air flow, the turbine must be designed to rotate in only one direction
no matter the direction of air flow. The Wells Turbine was designed for this type of application
and is used in most OWC devices today.
